After updating, Inkscape has become extremely crashy. Just copy/pasting elements easily reproduces this problem.
Anything in logs? ![]()
- Open Inkscape
- Draw a square
- Select it and do a CTRL + X
- Do CTRL + V
- Crash
CMSSystem::load_profiles: /usr/share/color/icc/colord/Crayons.icc is not an ICC file!
CMSSystem::load_profiles: /usr/share/color/icc/colord/x11-colors.icc is not an ICC file!
CMSSystem::load_profiles: ICC profile with duplicate name: Lab identity built-in:
/usr/share/color/icc/krita/Lab-D50-Identity-elle-V2.icc
/usr/share/color/icc/krita/Lab-D50-Identity-elle-V4.icc
(org.inkscape.Inkscape:2423508): Gtk-CRITICAL **: 11:40:40.844: invalid accelerator string ''
(org.inkscape.Inkscape:2423508): Gtk-CRITICAL **: 11:40:40.844: gtk_application_accels_get_actions_for_accel: assertion 'accel_key.key != 0' failed
(org.inkscape.Inkscape:2423508): Gtk-WARNING **: 11:40:40.846: Unable to parse accelerator '': ignored request to install 1 accelerators
** (org.inkscape.Inkscape:2423508): WARNING **: 11:40:41.470: You have a huge number of font families (1084), and Cairo is limiting the size of widgets you can draw.
Your preview cell height is capped to 27.
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.474: broker.vala:159: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.475: broker.vala:159: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.475: broker.vala:159: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.475: broker.vala:159: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.475: broker.vala:159: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.476: broker.vala:159: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.476: broker.vala:159: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
(org.inkscape.Inkscape:2423508): libenchant-WARNING **: 11:40:41.476: broker.vala:159: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
Inkscape is always crashing whenever one tries to copy/paste and sometimes even moving elements in the canvas.
It works fine for me, but there is a slight delay when pressing Ctrl-C before it gets responsive again and data can be pasted. Might be then that your copy crashes.
It seems from the clipboard content that it produces XML data while copying objects. Might be something about converting “whatever it handles on the canvas” to XML and shoving it onto the clipboard that causes the delay.
I’m guessing the developers will hear about it, if it’s a wide spread issue.
It could of course also be something strange going on with your machine.
I get a crash with inkscape if I have python-webencodings and python-tinycss2 installed, and no crash if I remove them. I don’t (yet) know if not having them causes any other problems. Since I’m not currently needing inkscape I’ve not investigated.
Just tested it with the latest update of OS and applications on KDE Plasma 6.3.x
No issues at all. works as expected.
Inkscape - Version:
If others cannot reproduce the issue, then Inkscape is not “broken”. Please edit your topic title to be clear and concise about the issue. Also please edit your first post to include information for helpful volunteers to be able to help you.
Please see:
You topic will be hidden from the public until you make appropriate edits. Anyone with the link can still view the topic and users that are subscribed will still receive notifications of replies.
EDIT: Topic is now public again.
changed the topic, but this is something caused after the upgrade since it didn’t happen before…
Thank you for editing the topic title. It is no longer hidden.
Tracked by Inkscape https://gitlab.com/inkscape/inkscape/-/issues/5528
FYI: Plasma 6.3.3 (running on Archlinux) I don’t get the crash.
I am unable to duplicate this, with either CTRL + C or CTRL + X. Not even doing CTRL +V immediately after doing CTRL + C or X
KDE Plasma Version: 6.3.2
KDE Frameworks Version: 6.11.0
Qt Version: 6.8.2
Kernel Version: 6.12.17-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 4 × Intel® Pentium® CPU N3540 @ 2.16GHz
Memory: 7.6 GiB of RAM
Graphics Processor: Intel® HD Graphics
Manufacturer: Notebook
Product Name: W54_W94_W955TU,-T,-C
Does it crash on X11 or wayland session?
It happens on Wayland, the crash occurs for me both with Inkscape 1.4 (native) and Inkscape 1.3.2 (AppImage).
No crash on Inkscape 1.4 (e7c3feb100, 2024-10-09) X11
And no crash on Rpi5 with the same version.
inxi -zv8
Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b32fec85-6680-4f13-90d2-4704491d2a55 rw quiet splash
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Dell product: Inspiron 5680 v: 2.2.0
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0PXWHK v: A00 serial: <superuser required> part-nu: 0874
uuid: <superuser required> UEFI: Dell v: 2.2.0 date: 12/05/2019
Device-1: hid-34:88:5d:ef:05:49-battery model: Keyboard K380 serial: N/A
charge: N/A status: N/A
System RAM: total: 16 GiB available: 15.41 GiB used: 3.18 GiB (20.6%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: DIMM3 type: no module installed
Device-2: DIMM1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: 80AD000080AD
part-no: HMA81GU6AFR8N-UH serial: <filter>
Device-3: DIMM4 type: no module installed
Device-4: DIMM2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 900 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 76831
sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Dell driver: nvidia
v: 550.144.03 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0
driver: X: loaded: N/A failed: nvidia gpu: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: Unknown-1 mapped: HDMI-0 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 102 size: 480x270mm (18.9x10.63") modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Dell
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 0cf3:e009
class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter> status:
discoverable: no active: no pairing: yes class-ID: 6c0104
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.28 TiB used: 62.12 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SD9SN8W256G
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1012 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C2
dev-links: cdrom
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 38.46 GiB (4.2%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: b32fec85-6680-4f13-90d2-4704491d2a55
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: 3EE6-D124
ID-3: /run/media/joel/Extreme SSD raw-size: 232.88 GiB
size: 232.88 GiB (100.00%) used: 23.66 GiB (10.2%) fs: exfat dev: /dev/sdd1
maj-min: 8:49 label: Extreme SSD uuid: 009A-05D2
ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 931.39 GiB fs: ntfs label: DATA
uuid: F8E6926FE6922DBE
ID-3: /dev/sdb1 maj-min: 8:17 size: 500 MiB fs: vfat label: ESP
uuid: 4E50-6438
ID-4: /dev/sdb2 maj-min: 8:18 size: 128 MiB fs: <superuser required>
ID-5: /dev/sdb3 maj-min: 8:19 size: 222.99 GiB fs: ntfs label: OS
uuid: 9874822F74821064
ID-6: /dev/sdb4 maj-min: 8:20 size: 1.13 GiB fs: ntfs label: WINRETOOLS
uuid: 4068EE0D68EE0210
ID-7: /dev/sdb5 maj-min: 8:21 size: 12.67 GiB fs: ntfs label: Image
uuid: 06ACAA10ACA9F9F7
ID-8: /dev/sdb6 maj-min: 8:22 size: 1.06 GiB fs: ntfs label: DELLSUPPORT
uuid: B06CBA8A6CBA4B3C
Device-1: 1-8:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Device-2: 1-9:3 info: Microdia USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 0c45:767e class-ID: 0301
Device-3: 1-12:4 info: Qualcomm Atheros type: bluetooth driver: btusb
power: 100mA chip-ID: 0cf3:e009 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
Device-1: 2-8:4 info: SanDisk Extreme Portable SSD type: mass storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:558c class-ID: 0806
serial: <filter>
System Temperatures: cpu: 58.0 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (rpm): cpu: 1205 fan-2: 739 gpu: nvidia fan: 32%
Packages: pm: pacman pkgs: 1081 libs: 320 tools: pamac
1: https://gsl-syd.mm.fcix.net/manjaro/testing/$repo/$arch
2: https://mirror.aarnet.edu.au/pub/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 290
1: cpu: 44.1% command: firefox pid: 3427 mem: 767.3 MiB (4.8%)
2: cpu: 31.4% command: firefox pid: 3642 mem: 279.7 MiB (1.7%)
3: cpu: 29.7% command: firefox pid: 3516 mem: 110.6 MiB (0.7%)
4: cpu: 21.0% command: WebContent pid: 4251 mem: 982.7 MiB (6.2%)
5: cpu: 2.5% command: [nv_queue] pid: 744 mem: 0.00 MiB (0.0%)
Memory top: 5 of 290
1: mem: 982.7 MiB (6.2%) command: WebContent pid: 4251 cpu: 21.0%
2: mem: 767.3 MiB (4.8%) command: firefox pid: 3427 cpu: 44.1%
3: mem: 321.4 MiB (2.0%) command: remmina pid: 1038 cpu: 0.5%
4: mem: 279.7 MiB (1.7%) command: firefox pid: 3642 cpu: 31.4%
5: mem: 278.1 MiB (1.7%) command: inkscape pid: 3870 cpu: 1.8%
Processes: 290 Power: uptime: 1h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: ghostty inxi: 3.3.37
inxi -zv8 Rpi5
Kernel: 6.13.7-1-MANJARO-RPI5 arch: aarch64 bits: 64 compiler: gcc v: 14.2.1
clocksource: arch_sys_counter parameters: reboot=w coherent_pool=1M
8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory
numa_policy=interleave numa=fake=8 system_heap.max_order=0
smsc95xx.macaddr=D8:3A:DD:98:5C:5E vc_mem.mem_base=0x3fc00000
vc_mem.mem_size=0x40000000 root=PARTUUID=ecae37b0-02 rw rootwait
console=ttyAMA10,115200 console=tty3 selinux=0 quiet splash
plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N
dwc_otg.lpm_enable=0 usbhid.mousepoll=8 audit=0
Distro: Manjaro ARM base: Arch Linux
Type: ARM System: Raspberry Pi 5 Model B Rev 1.0 details: N/A rev: d04170
serial: <filter>
System RAM: total: N/A available: 7.87 GiB used: 3.47 GiB (44.1%)
igpu: 4 MiB
RAM Report: message: No RAM data found using udevadm.
Message: No ARM data found for this feature.
Info: model: N/A variant: cortex-a76 bits: 64 type: MCP arch: ARMv8
family: 8 model-id: 4 stepping: 1
Topology: cpus: 1x clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 512 KiB desc: d-4x64 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 1700 min/max: 1500/2400 scaling: driver: cpufreq-dt
governor: ondemand cores: 1: 1700 2: 1700 3: 1700 4: 1700 bogomips: 432
Features: aes asimd asimddp asimdhp asimdrdm atomics cpuid crc32 dcpop
evtstrm fp fphp lrcpc pmull sha1 sha2
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: CSV2, BHB
Device-1: bcm2712-hdmi0 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:107c701400 class-ID: hdmi
Device-2: bcm2712-hdmi1 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:107c706400 class-ID: hdmi
Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev dri: vc4
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_txp,vc4_v3d,vc4_vec
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) 32ML600 serial: <filter>
built: 2019 res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.647
y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314
y: 0.329 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
modes: 1920x1080, 3840x2160, 1680x1050, 1400x1050, 1600x900, 1280x1024,
1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 97
API: EGL v: 1.5 hw: drv: broadcom v3d drv: broadcom vc4 platforms:
device: 0 drv: v3d device: 1 drv: swrast gbm: drv: v3d surfaceless: drv: v3d
x11: drv: vc4 inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.1 vendor: broadcom mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: V3D 7.1.7.0 device-ID: 14e4:ffffffff
memory: 7.68 GiB unified: yes
x11: xdpyinfo,xprop
Device-1: bcm2712-hdmi0 driver: vc4_hdmi bus-ID: N/A
Device-2: bcm2712-hdmi1 driver: vc4_hdmi bus-ID: N/A
API: ALSA v: k6.13.7-1-MANJARO-RPI5 status: kernel-api
Server-1: PipeWire v: 1.4.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Raspberry Pi RP1 PCIe 2.0 South Bridge driver: rp1 v: kernel
port: N/A bus-ID: 0001:01:00.0 chip-ID: 1de4:0001 class-ID: 0200
IF-ID-1: end0 state: down mac: <filter>
Info: services: NetworkManager, smbd, sshd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
Device-1: bcm7271-uart driver: bcm7271_uart bus-ID: N/A
chip-ID: brcm:107d50c000 class-ID: serial
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.0
lmp-v: 9 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 297.95 GiB used: 36.85 GiB (12.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SR64G size: 59.48 GiB block-size:
physical: 512 B logical: 512 B type: Removable tech: SSD serial: <filter>
scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: MZ9LQ256HBJD-00BVL size: 238.47 GiB block-size: physical: 512 B
fw-rev: FXM71V1Q temp: 26.9 C scheme: MBR
ID-1: / raw-size: 59 GiB size: 58 GiB (98.31%) used: 36.79 GiB (63.4%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: ROOT_MNJRO
uuid: 648a048c-3fe6-4346-baf2-168881b675bb
ID-2: /boot raw-size: 457.8 MiB size: 457.5 MiB (99.94%)
used: 67.5 MiB (14.8%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
label: BOOT_MNJRO uuid: 1C25-B6F5
Kernel: swappiness: 60 (default) cache-pressure: 80 (default 100) zswap: no
ID-1: swap-1 type: zram size: 11.8 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4 max-streams: 4 dev: /dev/zram0
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 457.8 MiB fs: vfat
label: BOOT_MNJRO uuid: 07F8-50A4
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 238 GiB fs: ext4
label: ROOT_MNJRO uuid: 58fc87fa-3acd-4ba5-a031-38b9ea7e6ed8
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 4 rev: 2.0
chip-ID: 046d:c548 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.0
Device-1: 3-2:2 info: Microdia USB DEVICE type: keyboard,mouse
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.0
System Temperatures: cpu: 52.6 C mobo: N/A
Fan Speeds (rpm): cpu: 3149
Packages: 1044 pm: pacman pkgs: 1041 libs: 272 tools: pamac,yay pm: flatpak
pkgs: 3
1: https://codingflyboy.mm.fcix.net/manjaro/arm-unstable/$repo/$arch
2: https://southfront.mm.fcix.net/manjaro/arm-unstable/$repo/$arch
3: https://mirrors.jlu.edu.cn/manjaro/arm-unstable/$repo/$arch
4: https://repo.ialab.dsu.edu/manjaro/arm-unstable/$repo/$arch
5: https://mirrors.sonic.net/manjaro/arm-unstable/$repo/$arch
6: https://mirror.telepoint.bg/manjaro/arm-unstable/$repo/$arch
7: https://mirrors.dotsrc.org/manjaro/arm-unstable/$repo/$arch
8: https://manjarolinux-mirror.cloud.mu/arm-unstable/$repo/$arch
Processes:
CPU top: 5 of 252
1: cpu: 26.0% command: firefox pid: 1490 mem: 533.9 MiB (6.6%)
2: cpu: 13.9% command: firefox pid: 1843 mem: 296.6 MiB (3.6%)
3: cpu: 7.2% command: xfce4-terminal pid: 2398 mem: 53.5 MiB (0.6%)
4: cpu: 6.7% command: inkscape pid: 1456 mem: 254.9 MiB (3.1%)
5: cpu: 4.9% command: firefox pid: 1650 mem: 264.3 MiB (3.2%)
Memory top: 5 of 252
1: mem: 533.9 MiB (6.6%) command: firefox pid: 1490 cpu: 26.0%
2: mem: 296.6 MiB (3.6%) command: firefox pid: 1843 cpu: 13.9%
3: mem: 264.3 MiB (3.2%) command: firefox pid: 1650 cpu: 4.9%
4: mem: 254.9 MiB (3.1%) command: inkscape pid: 1456 cpu: 6.7%
5: mem: 163.6 MiB (2.0%) command: firefox pid: 1713 cpu: 1.0%
Processes: 252 Power: uptime: 14m suspend: services: power-profiles-daemon,
upowerd, xfce4-power-manager Init: systemd v: 257 default: graphical
tool: systemctl
running-in: xfce4-terminal inxi: 3.3.37
Just to add another voice to this cacophony;
→ Plasma 6.3.2 on Wayland, Kernel 6.12.17-1, AMD RX-580 graphic, Breath, Inkscape 1.4 (e7c3feb100, 2024-10-09) native.
I cannot reproduce the crash.
Please provide system information previously requested.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Privacy: Those with privacy concerns, note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. ![]()
As mentioned above, there is an open inkscape issue tracking this, with reports of several people able to reproduce a crash. There is perhaps little to gain in collecting Manjaro-specific info here; if people have anything to add maybe add it to the inkscape issue.
