Kernel:
6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=703239bb-c1c4-4e3f-bd2c-3aca6e2b19fb rw quiet
Desktop:
KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: Acer product: Nitro ANV15-51 v: V1.14
serial: Chassis: type: 10 serial:
Mobo: RPL model: Sportage_RTH v: V1.14 serial:
part-nu: 0000000000000000 uuid: UEFI: INSYDE v: 1.14
date: 06/21/2024
System RAM: total: 16 GiB available: 15.33 GiB used: 7.09 GiB (46.2%)
Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: no module installed
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s volts: curr: 1
width (bits): data: 64 total: 64 manufacturer: A-DATA Technology
part-no: AI1V56WCSV1-B1DS serial:
Info: model: 13th Gen Intel Core i7-13620H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4124
Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:a7a8 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 550.144.03
alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ bus-ID: 0000:01:00.0
chip-ID: 10de:28a1 class-ID: 0300
Device-3: Quanta ACER HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0408:403a
class-ID: fe01 serial:
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
