I have a problem, I installed manjaro in ssd and zorin in cpu. My laptop is a Samsung rv 415, amd300 2 Gb of ram. I select manjaro in grub but is not opening only zorin. What I can do with it?
Welcome to Manjaro!
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. - Please provide the above after booting your original install USB.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
