Hello! Please help me how to enlarge the screen size 125 and so on. Because 100% very bad at seeing small windows and texts, saw the forum and copied the link for the GNOME for Xorg extension [gsettings set org.gnome.mutter experimental-features “[‘x11-randr-fractional-scaling’]”]
I tried to register in the terminal and rebooted, and barely 2 more points remained, did not expand, what should I do ??
You’ll either need to use a Wayland session or install mutter-x11-scaling and gnome-control-center-x11-scaling.
If you choose the latter option, keep in mind it will not longer work once gnome-shell 40 arrives in the stable branch. After that, you’ll have to wait until Ubuntu adapts their patches for GNOME 40.
That only works natively on Ubuntu with the appropriate patches.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
