If playback doesn’t begin shortly try restarting your device"
I am use Manjaro with Gnome and use google chrome for watch youtube video from last week I can not see youtube videos and I see
and
cat /etc/os-release         ✔  11s 
NAME="Manjaro Linux"
PRETTY_NAME="Manjaro Linux"
ID=manjaro
ID_LIKE=arch
BUILD_ID=rolling
ANSI_COLOR="32;1;24;144;200"
HOME_URL="https://manjaro.org/"
DOCUMENTATION_URL="https://wiki.manjaro.org/"
SUPPORT_URL="https://forum.manjaro.org/"
BUG_REPORT_URL="https://docs.manjaro.org/reporting-bugs/"
PRIVACY_POLICY_URL="https://manjaro.org/privacy-policy/"
LOGO=manjarolinux
and I see
cat /etc/lsb-release         ✔
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="25.0.0"
DISTRIB_CODENAME="Zetar"
DISTRIB_DESCRIPTION="Manjaro Linux"
Some firefox users have had similar issues, specifically with HEVC hardware rendering no longer being available. Perhaps Chromium-based browsers have a similar issue.
I’m afraid I have nothing to suggest. I’m sure someone will help when they are able.
Please provide system information as descibed (below), posted as preformatted text (see links given for instructions).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
thank you
inxi -zv8         ✔
  Kernel: 6.1.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=7df37fe0-544b-4b16-afca-3ca98d11d402 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME H310M-R R2.0 v: Rev X.0x
    UEFI: American Megatrends v: 2002 date: 12/08/2020
  System RAM: total: 24 GiB available: 23.35 GiB used: 11.38 GiB (48.7%)
  Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2666 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: CB8GU2666.C8ET
    serial: <filter>
  Device-2: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2666 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: CB16GU2666.C8ET
    serial: <filter>
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4401 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4401 2: 4401 3: 4401 4: 4401 5: 4401 6: 4401
    7: 4401 8: 4401 9: 4401 10: 4401 11: 4401 12: 4401 bogomips: 88824
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: DP-1,HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e92 class-ID: 0300
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model-id: RTK 0x1d1a serial: <filter> built: 2015
    res: 1024x768 dpi: 25 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 160x90mm (6.3x3.54") diag: 1168mm (46") ratio: 16:9 modes: 1024x768,
    1920x1080, 1400x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1366x768,
    1280x800, 1152x864, 1280x768, 1280x720, 832x624, 800x600, 640x480,
    720x400
  Monitor-2: HDMI-A-1 model-id: SGT 0x2360 serial: <filter> built: 2020
    res: 1920x1080 dpi: 94 gamma: 1.2 chroma: red: x: 0.655 y: 0.329 green:
    x: 0.220 y: 0.682 blue: x: 0.149 y: 0.051 white: x: 0.310 y: 0.329
    size: 522x294mm (20.55x11.57") diag: 600mm (23.6") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e92 memory: 11.4 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.309 layers: 1 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 630 (CFL GT2) driver: N/A device-ID: 8086:3e92
    surfaces: xcb,xlib,wayland
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: corectrl,nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  API: ALSA v: k6.1.131-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.1 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel 82576 Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 link-max: lanes: 4 port: e020 bus-ID: 01:00.0
    chip-ID: 8086:10c9 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
  Device-2: Intel 82576 Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 link-max: lanes: 4 port: e000 bus-ID: 01:00.1
  IF: enp1s0f1 state: down mac: <filter>
  Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Info: services: mld, NetworkManager, sshd, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 1.16 TiB used: 815.72 GiB (68.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-00BBHA0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 temp: 39 C scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31256GTND
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 61.3 temp: 33 C scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
    size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 802.63 GiB (86.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 7df37fe0-544b-4b16-afca-3ca98d11d402
    used: 612 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 2326-0454
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /run/media/mostafa/6A71-B3B8 raw-size: 14.32 GiB
    size: 14.31 GiB (99.90%) used: 13.09 GiB (91.5%) fs: vfat dev: /dev/sdc1
    maj-min: 8:33 label: N/A uuid: 6A71-B3B8
  ID-5: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-6: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-1: /dev/sdb1 maj-min: 8:17 size: 499 MiB fs: ntfs label: Recovery
    uuid: 0AB2CAE5B2CAD3FB
  ID-2: /dev/sdb2 maj-min: 8:18 size: 99 MiB fs: vfat label: N/A
    uuid: 38CB-279E
  ID-3: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sdb4 maj-min: 8:20 size: 237.87 GiB fs: ntfs label: N/A
    uuid: FE64CC0064CBBA23
  Device-1: 1-4:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 28a0:1185 class-ID: 0301
  Device-2: 1-6:3 info: China Resource Semico Keyboard type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1a2c:2124 class-ID: 0300
  Device-3: 1-7:6 info: SanDisk Ultra Flair type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:5591 class-ID: 0806
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 55.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2479 pm: dpkg pkgs: 0 pm: nix-default pkgs: 48 pm: nix-sys pkgs: 0
    pm: nix-usr pkgs: 0 pm: pacman pkgs: 2390 libs: 497
    tools: gnome-software,pamac,paru,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 41
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://mirrors2.manjaro.org/stable/$repo/$arch
    3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
  No nix channels found for user: mostafa
Processes:
  CPU top: 5 of 518
  1: cpu: 99.9% command: pipewire pid: 2311 mem: 14.1 MiB (0.0%)
  2: cpu: 11.7% command: chrome pid: 740648 mem: 362.9 MiB (1.5%)
  3: cpu: 4.9% command: chrome pid: 738901 mem: 274.6 MiB (1.1%)
  4: cpu: 3.0% command: postman pid: 6809 mem: 458.5 MiB (1.9%)
  5: cpu: 2.1% command: firefox pid: 388596 mem: 918.7 MiB (3.8%)
  Memory top: 5 of 518
  1: mem: 929.8 MiB (3.8%) command: nautilus pid: 356914 cpu: 0.0%
  2: mem: 918.7 MiB (3.8%) command: firefox pid: 388596 cpu: 2.1%
  3: mem: 896.1 MiB (3.7%) command: telegram-desktop pid: 592708 cpu: 0.7%
  4: mem: 553.2 MiB (2.3%) command: firefox pid: 394019 cpu: 0.2%
  5: mem: 550.7 MiB (2.3%) command: chrome pid: 738848 cpu: 1.2%
  Processes: 518 Power: uptime: 7d 6h 46m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 9.33 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 12 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.37
Have you ever specifically enabled hardware acceleration for video decoding?
I do not think so
How I can check it?
I only have Chomium, not Google Chrome - but I think the UI is similar.
If you go to Settings, you have a search box where you can look for acceleration or graphics or whatever keyword.
In Chromium the relevant setting is in the “System” category.
It was set to enabled by default - for me.
Looking at HEVC as the cause of this issue is possibly going down the wrong path. I recall a couple of threads a week or two ago that mentioned they couldn’t play videos, and the issue was resolved by installing the manjaro-pipewire meta-package, which removes the manjaro-pulse meta-package, and replaces some pulseaudio packages with their pipewire equivalents:
pamac install manjaro-pipewire
or
sudo pacman -Syu manjaro-pipewire
Removing pulseaudio including configuration files and unnecessary dependencies may also be required:
pamac remove -on manjaro-pulse
or
sudo pacman -Rns manjaro-pulse
You may need to reboot for the changes to take effect.
A similar issue & solution were mentioned recently in a Stable Updates announcement thread:
A couple of other threads since then have also had sound/playback issues resolved by replacing manjaro-pulse with manjaro-pipewire.
One thread did also mention that the helvum package also had to be installed:
