i7-1165G7 Manjaro detecting Speakers as Headphones (Seen in Gnome menu)
Recent Manjaro user, and while this has affected every other distro I tried, I thought I’d see what the Manjaro community made of this.
For some reason Gnome/whatever is underneath has decided that my laptop (ASUS UX363) speakers are headphones:
On first install/live test on Manjaro (https://download.manjaro.org/gnome/22.1.3/manjaro-gnome-22.1.3-230529-linux61.iso) it detected them properly, which made me commit to a full install, then after letting Manjaro upgrade itself, it decided that the laptop speakers were headphones.
This is so far only manifesting itself with the icon being wrong, but I wonder if there is something more fundamental wrong here.
Its an intel i7-1165G7 chipset so I wonder if something has gone awry between kernel or gnome versions?
If someone could direct me to how to diagnose this, I would be very happy!
do the speaker work and output sound even if they are shown up as headphones ?
Yes, they behave as normal.
next, can you post the output of
  Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=9bd7650f-8529-4ae3-b0df-7fde19e32ad7 rw quiet splash
    udev.log_priority=3
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Convertible System: ASUSTeK product: ZenBook UX363EA_UX363EA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX363EA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: UX363EA.325 date: 04/25/2023
  ID-1: BAT0 charge: 53.4 Wh (94.8%) condition: 56.3/67.3 Wh (83.6%)
    power: 13.3 W volts: 17.4 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: charging cycles: 297
  Device-1: hid-0018:04F3:2D4B.0001-battery model: ELAN9008:00 04F3:2D4B
    serial: N/A charge: N/A status: N/A
  System RAM: total: 16 GiB note: est. available: 15.32 GiB
    used: 6.6 GiB (43.0%)
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xAC
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 2800 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2800 2: 2800 3: 2800 4: 2800 5: 2800 6: 2800
    7: 2800 8: 2800 bogomips: 44864
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 13d3:56eb
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x4158 built: 2020 res: 1920x1080 dpi: 166
    gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
    modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.77 status: off tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 301.39 GiB (31.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 43.9 C
    scheme: GPT
  ID-1: / raw-size: 254.05 GiB size: 249 GiB (98.01%) used: 43.93 GiB (17.6%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 9bd7650f-8529-4ae3-b0df-7fde19e32ad7
  ID-2: /boot/efi raw-size: 512.7 MiB size: 511.7 MiB (99.80%)
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: C21F-0E78
  ID-3: /run/media/rob/OS raw-size: 697.88 GiB size: 697.88 GiB (100.00%)
    used: 257.45 GiB (36.9%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: OS uuid: 14AE1BD2AE1BAB6E
  ID-1: swap-1 type: file size: 16 GiB used: 351.2 MiB (2.1%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: AC1A-0C7D
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: RECOVERY
    uuid: 66BA0E10BA0DDE05
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 200 MiB fs: vfat label: MYASUS
    uuid: CAE0-B693
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:4 info: Razer USA Orochi V2 type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:0094 class-ID: 0300
    serial: <filter>
  Device-2: 3-5:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
  Device-3: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (rpm): cpu: 2800
  Processes: 315 Uptime: 10h 30m wakeups: 48599 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: 1090 pm: pacman pkgs: 1079 libs: 324 tools: gnome-software,pamac
  pm: flatpak pkgs: 11 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.29
okay, you’re using the pulse-audio “system” instead of pipewire. can you post the packages of pulse that are actually installed on your system
pamac search "pulse" | grep Insta
Thanks for the help, FYI this is a vanilla install for a minimal Gnome install, so I’ve only gone with the flow on this one.
libcanberra  1:0.30+r2+gc0620e4-3 [Installed]                              extra
libpulse  16.1-6 [Installed]                                               extra
pulseaudio-bluetooth  16.1-6 [Installed]                                   extra
pulseaudio-alsa  1:1.2.7.1-2 [Installed]                                   extra
pulseaudio  16.1-6 [Installed]                                             extra
these are mine packages after a standard install
libcanberra  1:0.30+r2+gc0620e4-3 [Installiert]                            extra
lib32-libcanberra  1:0.30+r2+gc0620e4-2 [Installiert]                   multilib
manjaro-pulse  20221015-2 [Installiert]                                    extra
libpulse  16.1-6 [Installiert]                                             extra
lib32-libpulse  16.1-6 [Installiert]                                    multilib
pulseaudio-zeroconf  16.1-6 [Installiert]                                  extra
pulseaudio-qt  1.3-1 [Installiert]                                         extra
pulseaudio-ctl  1.70-1 [Installiert]                                       extra
pulseaudio-bluetooth  16.1-6 [Installiert]                                 extra
pulseaudio-alsa  1:1.2.7.1-2 [Installiert]                                 extra
pulseaudio  16.1-6 [Installiert]                                           extra
you can try to install the missing ones and test on changes of your system. if there’s no change you can uninstall them anyway
pamd list-sources shows this:
6 source(s) available.
    index: 0
	name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor>
	driver: <module-alsa-card.c>
	flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: RUNNING
	suspend cause: (none)
	priority: 1030
	volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max rewind: 1 KiB
	sample spec: s16le 2ch 48000Hz
	channel map: front-left,front-right
	             Stereo
	used by: 1
	linked by: 1
	configured latency: 6.94 ms; range is 0.50 .. 341.33 ms
	monitor_of: 0
	card: 0 <alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic>
	module: 6
	properties:
		device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
		device.class = "monitor"
		alsa.card = "0"
		alsa.card_name = "sof-hda-dsp"
		alsa.long_card_name = "ASUSTeKCOMPUTERINC.-ZenBookUX363EA_UX363EA-1.0-UX363EA"
		alsa.driver_name = "snd_soc_skl_hda_dsp"
		device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "a0c8"
		device.product.name = "Tiger Lake-LP Smart Sound Technology Audio Controller"
		device.string = "0"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
    index: 1
	name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor>
	state: RUNNING
	priority: 1030
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 1 KiB
	             Stereo
	used by: 1
	linked by: 1
	monitor_of: 1
	module: 6
	properties:
		device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
    index: 2
	name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor>
	state: RUNNING
	priority: 1030
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 1 KiB
	             Stereo
	used by: 1
	linked by: 1
	monitor_of: 2
	module: 6
	properties:
		device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
    index: 3
	name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor>
	state: RUNNING
	priority: 1030
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 1 KiB
	             Stereo
	used by: 1
	linked by: 1
	monitor_of: 3
	module: 6
	properties:
		device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller Headphones"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
    index: 4
	name: <alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source>
	flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: RUNNING
	priority: 9032
	        balance 0.00
	volume steps: 65537
	muted: no
	current latency: 0.27 ms
	max rewind: 0 KiB
	             Stereo
	used by: 1
	linked by: 1
	module: 6
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = ""
		alsa.id = "HDA Analog (*)"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "_ucm0001.hw:sofhdadsp"
		device.buffering.buffer_size = "65536"
		device.buffering.fragment_size = "16384"
		device.access_mode = "mmap+timer"
		device.profile.name = "HiFi: hw:sofhdadsp: source"
		device.profile.description = "Headphones Stereo Microphone"
		alsa.mixer_device = "_ucm0001.hw:sofhdadsp"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Headphones Stereo Microphone"
	ports:
		[In] Mic2: Headphones Stereo Microphone (priority 200, latency offset 0 usec, available: unknown)
			properties:
	active port: <[In] Mic2>
  * index: 5
	name: <alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source>
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: RUNNING
	priority: 9031
	volume: front-left: 23644 /  36% / -26.57 dB,   front-right: 23644 /  36% / -26.57 dB
	        balance 0.00
	base volume: 30419 /  46% / -20.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.44 ms
	max rewind: 0 KiB
	             Stereo
	used by: 1
	linked by: 1
	module: 6
	properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "DMIC (*)"
		alsa.device = "6"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "_ucm0001.hw:sofhdadsp,6"
		device.profile.name = "HiFi: hw:sofhdadsp,6: source"
		device.profile.description = "Digital Microphone"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Digital Microphone"
	ports:
		[In] Mic1: Digital Microphone (priority 100, latency offset 0 usec, available: unknown)
			properties:
	active port: <[In] Mic1>
I wonder if there is a magic id to pretty name file somewhere that is deciding they are headphones based on some kind of end of string regex give that I see this:
Do we know what governs these names?
there are several threads for tiger-lake audio here in the forum. one thing is all common, you should/must install the package sof-firmware (after this reboot).
sof-firmware is already present.
In pavucontrol I see that “Port” is named “Headphones”
Any idea where I can choose what the “Port” name is?
nope i’m on plasma
Please post more information about audio device
pactl list cards
pactl list sinks
pactl list cards sinks
Sink #0
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output
	Driver: module-alsa-card.c
	Sample Specification: s16le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 6
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "HDMI3 (*)"
		alsa.device = "5"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "_ucm0001.hw:sofhdadsp,5"
		device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
		device.profile.description = "HDMI / DisplayPort 3 Output"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
	Ports:
		[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, not available)
	Active Port: [Out] HDMI3
	Formats:
		pcm
Sink #1
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output
	Owner Module: 6
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "HDMI2 (*)"
		alsa.device = "4"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "_ucm0001.hw:sofhdadsp,4"
		device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
		device.profile.description = "HDMI / DisplayPort 2 Output"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
	Ports:
		[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, not available)
	Active Port: [Out] HDMI2
	Formats:
		pcm
Sink #2
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output
	Owner Module: 6
	Mute: no
	Volume: front-left: 65535 / 100% / -0.00 dB,   front-right: 65535 / 100% / -0.00 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "HDMI1 (*)"
		alsa.device = "3"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "_ucm0001.hw:sofhdadsp,3"
		device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
		device.profile.description = "HDMI / DisplayPort 1 Output"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
	Ports:
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, not available)
	Active Port: [Out] HDMI1
	Formats:
		pcm
Sink #3
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller Headphones
	Owner Module: 6
	Mute: no
	Volume: front-left: 64876 /  99% / -0.26 dB,   front-right: 64876 /  99% / -0.26 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
		device.profile.name = "HiFi: hw:sofhdadsp: sink"
		device.profile.description = "Headphones"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Headphones"
	Ports:
		[Out] Headphones: Headphones (type: Headphones, priority: 200, availability unknown)
	Active Port: [Out] Headphones
	Formats:
		pcm
pactl list sinks
Sink #0
	State: SUSPENDED
	Owner Module: 6
	Mute: no
	        balance 0.00
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "5"
		alsa.card = "0"
		device.bus = "pci"
	Ports:
	Formats:
		pcm
Sink #1
	State: SUSPENDED
	Owner Module: 6
	Mute: no
	        balance 0.00
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "4"
		alsa.card = "0"
		device.bus = "pci"
	Ports:
	Formats:
		pcm
Sink #2
	State: SUSPENDED
	Owner Module: 6
	Mute: no
	        balance 0.00
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "3"
		alsa.card = "0"
		device.bus = "pci"
	Ports:
	Formats:
		pcm
Sink #3
	State: SUSPENDED
	Owner Module: 6
	Mute: no
	        balance 0.00
	Properties:
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
	Ports:
	Formats:
		pcm
apologies for typo on 1st command - response shows data for sinks same as 2nd command not cards
is there another port for ‘Speakers’ that you can switch to in pavucontrol ?
There is usually only one analog output channel shared by Headphone and Speaker ports and
PulseAudio would usually switch between ports when headphones are plugged in or unplugged
Have you tried different desktop environments?
What did other distributions suggest to deal with this?
This is so far only manifesting itself with the icon being wrong, , but I wonder if there is something more fundamental wrong here.
The notification always shows a speaker icon for audio and does not change to show headphone icon
the other controls showing headphone icon are specific to Gnome DE
No, just Headphones
Not yet, what was odd is the intial Gnome Manjaro was showing the speaker icon, I’ll try that and another Manjaro DE Live “CD” when I get the chance
Clear Linux I think was ok, I’ve tried a few and didn’t make proper notes
Unfortunately I’m very unknowledgeable about how the sound and or even hardware detection works, so to me it feels deeper than the DE if its the “Port”, will have to read up
I’ve tried the following Live “CDs”, both Gnome.
clear-39400-live-desktop.iso
Same as Manjaro
pop-os_22.04_amd64_intel_31.iso
Same as Manjaro, however the power menu in the top right showed the speaker icon, which I think is what I thought was it “working properly”, however I changed the volume with the hot keys and the “Headphones” text was displayed on that modal.
I will download Manjaro Plasma Minimal and see if there is any difference.
Tried Manjaro Plasma (KDE) Minimal (manjaro-kde-22.1.3-minimal-230529-linux61.iso)
The Speakers are still identified as Headphones, so there is something deeper going on.
Anyone got any ideas where to look?
please post more information about audio device
sudo alsa-info.sh --upload
Had to install alsa-utils, here is the link:
http://alsa-project.org/db/?f=84daae5bf1954aeebdcbd78c52cc1813376e6d66
please reboot, enter your bios and check if there are some audio-settings. it could be that the speakers are disabled by default.
if not please try this:
create a file with the following entry
# /etc/modprobe.d/snd_intel_dspcfg.conf
options snd-intel-dspcfg dsp_driver=1
and save it to /etc/modprobe.d/snd_intel_dspcfg.conf (you’ll need sudo rights to store).
reboot and report again the following
any changes ? even if not please report the output of the pactl-command. you can delete this file if the module-parameter had no effect.
please enter your bios and check if there are some audio-settings. it could be that the speakers are disabled by default.
