I currently use manjaro gnome lts, and try to install nvidia driver to my machine
GPU: nvidia geforce gtx 1650ti: turing series
CPU: intel core i5-10300H
when I try to install appropriate driver (nvidia-open) to my machine. I had that error
make[1]: Leaving directory '/home/a-ismoilov/.cache/yay/nvidia-open-beta/src/open-gpu-kernel-modules-530.41.03/src/nvidia'
cd kernel-open/nvidia/ && ln -sf ../../src/nvidia/_out/Linux_x86_64/nv-kernel.o nv-kernel.o_binary
make -C kernel-open modules
make[1]: Entering directory '/home/a-ismoilov/.cache/yay/nvidia-open-beta/src/open-gpu-kernel-modules-530.41.03/kernel-open'
make[2]: Entering directory '/home/a-ismoilov/.cache/yay/nvidia-open-beta/src/open-gpu-kernel-modules-530.41.03/kernel-open'
make[2]: *** /lib/modules/6.1.31-2-MANJARO/build: No such file or directory. Stop.
make[2]: Leaving directory '/home/a-ismoilov/.cache/yay/nvidia-open-beta/src/open-gpu-kernel-modules-530.41.03/kernel-open'
make[1]: *** [Makefile:82: modules] Error 2
make[1]: Leaving directory '/home/a-ismoilov/.cache/yay/nvidia-open-beta/src/open-gpu-kernel-modules-530.41.03/kernel-open'
make: *** [Makefile:59: modules] Error 2
make: Leaving directory '/home/a-ismoilov/.cache/yay/nvidia-open-beta/src/open-gpu-kernel-modules-530.41.03'
==> ERROR: A failure occurred in build().
Aborting...
-> error making: nvidia-open-beta-exit status 4
could you please help to install driver
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Olli
16 June 2023 07:01
2
cscs
16 June 2023 07:19
3
Is here a reason you are doing it this way?
Manjaro provides tools for handling drivers.
this commands, said that i already install drivers but I did not
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4c81f2d7-1d74-4301-b557-d2f56bf1b970 rw quiet splash apparmor=1
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk1xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8742 v: 02.50 serial: <superuser required> UEFI: Insyde
v: F.41 date: 09/05/2022
ID-1: BAT1 charge: 26.8 Wh (65.5%) condition: 40.9/52.5 Wh (78.0%)
volts: 12.7 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: charging
System RAM: available: 7.57 GiB used: 5.83 GiB (77.1%)
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 900 high: 901 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 900 8: 901 bogomips: 40009
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: Hewlett-Packard driver: N/A
alternate: nouveau non-free: 530.xx+ status: current (as of 2023-05)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-3: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b627
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 09:00.0
chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 0bda:b00c
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 82.88 GiB (34.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC511 HFM256GDJTNI-82A0A size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS0 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 82.88 GiB (35.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 4c81f2d7-1d74-4301-b557-d2f56bf1b970
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 3F3E-D711
Device-1: 1-1:4 info: Shenzhen Rapoo 2.4G Wireless Device
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 24ae:2013 class-ID: 0301
Device-2: 1-5:2 info: Chicony HP Wide Vision HD Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b627 class-ID: 0e02
Device-3: 1-14:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 60.0 C pch: 67.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 289 Uptime: 4h 24m wakeups: 44310 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1430 libs: 374 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
this is my system informations, I really appreciate the answare, thanks
Welcome to the forum!
a-ismoilov:
nvidia-open-beta
That AUR package is designed for the NVIDIA beta driver on Arch and will not work on Manjaro.
There is no driver installed.
What commands? Please post the output of:
mhwd --listinstalled
Thank you @Yochanan . I am very greatfull to be here.
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
this is what I have, when I enter that command
The correct profiles report installed, however it seems some package might not be anymore.
pacman -Qs nvidia
pacman -Qs nvidia
local/egl-wayland 2:1.1.11-4
EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/lib32-opencl-nvidia-390xx 390.157-4
OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl 530.41.03-3
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 530.41.03-4
MHWD module-ids for nvidia 530.41.03
local/mhwd-nvidia-390xx 390.157-6
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.182.03-2
MHWD module-ids for nvidia 470.182.03
local/nvidia-utils-beta 530.41.03-1
NVIDIA drivers utilities (beta version)
local/opencl-nvidia 530.41.03-4
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
this is what i have
a-ismoilov:
xf86-video-nouveau
That’s the reverse-engineered open-source driver that should not be installed if you’re using the NVIDIA proprietary driver.
Remove it:
sudo pacman -R xf86-video-nouveau
Then uninstall / reinstall the proper MHWD profile:
sudo mhwd -r pci video-hybrid-intel-nvidia-prime && sudo mhwd -a pci nonfree 0300
If there are errors, that probably means you did other things along the way you did not tell us about.
I install nvidia-utils but computer did not boot again
When you do random things on your own and don’t tell us what you did, we can’t help.
