Hi
i just changed an internet provider
i used to connect with PPoE; username + password that i put in KDE connections settings.
i now got a TP-Link modem/router on which i put the ISP provided credentials in the router’s set up page.
i did it on a windows PC through the address 192.168.1.1 and then windows automatically got connected to the internet(no need to put those credentials inside Windows itself like i used to do).
now here on Linux i get no available connections,i have no internet and unable to access the router’s setup page(192.168.1.1/192.168.0.1).
i remember that with my previous modem/router i also couldn’t access the setup page but didn’t care much since i had internet.
here’s the related thread:
inxi
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=a445c87d-e6a9-47fd-9601-614f3b3e7781 rw quiet apparmor=1
security=apparmor resume=UUID=29e42246-1548-46dd-91f5-17d1f76c7bfd
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX705GD_FX705GD v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX705GD v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX705GD.306 date: 05/25/2020
ID-1: BAT0 charge: 54.1 Wh (100.0%) condition: 54.1/64.1 Wh (84.4%)
volts: 16.3 min: 15.6 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: full cycles: 41
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4069 high: 4102 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4099 2: 4101 3: 4102
4: 4054 5: 4057 6: 4031 7: 4100 8: 4049 9: 4049 10: 4031 11: 4058 12: 4100
bogomips: 52815
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:4 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x429d built: 2018 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 476.94 GiB used: 66.41 GiB (13.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3512GJ size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK11.C temp: 44.9 C scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%) used: 66.41 GiB
(14.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 49.0 C pch: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 294 Uptime: 24m wakeups: 1 Memory: 15.48 GiB used: 2.68 GiB
(17.3%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: pm: pacman pkgs: 1417 libs: 401
tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.21
