Hi guys! it seems i lost the terminal after yesterday’s big update. anyone knows how shall I proceed from here? nothing happens when i type ctrl alt t.
i’m running on i5 on a rog maximus ranger. a relatively new hardware installation.
Thanks!
Forum search is your friend - and so is reading update announcements
The accompanying topic to the update announce
contains a link to this topic
and if you did bother to search you would have discovered plenty issues almost identical to yours …
If you lost it, like you said you did, you can lure it back with a byte or two to eat.
I assume you refer to Gnome Terminal. Your locale settings are changed because of the update. Steps to fix it:
- Install another terminal like Deepin Terminal
- Uncomment the correct locale in
/etc/locale.gen - Run
sudo locale-gen - Reboot
i’m sitting right now with a rod and a byte in front of the screen but nothing happens… LOL
Great! I’ll do that! Thanks!
a Bit of patience. Then many bits.
