After the update, I lost my operating system. It starts up, but then stops and I’m left with a black screen, unable to get out of this situation.
Hi @bardo
Your post has been moved from the Testing Update announcement thread to a dedicated topic.
Please avoid posting in categories that have nothing to with your issue; especially, not the Update Announcement threads.
Instead, choose an appropriate category when first creating a topic; or when editing the tile; and choose from the dropdown of Support category selections.
In order to help others help, more information is needed;
Please provide system information as described (below) for a start, and also tell how you performed the update; whether it was via the terminal or a TTY; which package manager you used; any errors you might have noticed during the update; and anything else you think might be relevant.
With that information, I’m sure someone will help when they are able. In the meantime, checking the Known Issues and Solutions section of the respectibe Update announcement is highly recommended.
Please rename the topic title to better reflect your issue. ![]()
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi --filter --verbosity=8
or the short form:
inxi -zv8
- inxi man pages (Arch Manual)
Highly Recommended
Required Reading
Technical Resources
I can’t log into the operating system, so all I can say is what I remember: I ignored the problem with nvidia utils 530 and updated with "sudo pacman -Syu. Everything installed. I restarted the system and was left with a black screen.
Right now I’m typing from Ubuntu.
Thank you.
Thank you.
… let me help you with the formatting:
three backticks (```) in a separate line before your output
and three backticks in a separate line at the end
or highlight all your output and click on this symbol </> in the top row of the edit window
I’ll do this for you now.
you have in the links above on how to chroot… boot into manjaro live usb, make sure you are connected to the internet, open terminal and chroot:
manjaro-chroot -a
rerun update:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here, if there are no errors and you are up to date, post output from:
ldconfig - (this should return nothing, if there are more than lets say 20 lines, dont bother to post, just let me know)
ls /etc/X11/* /etc/modprobe.d
pacman -Qm
mhwd -l && mhwd -li
and use formatting…
In some case Nvidia drivers need the following workaround in /etc/environment to launch properly:
MESA_LOADER_DRIVER_OVERRIDE=zink
It doesn’t work, it doesn’t find anything
Boot from a Manjaro live ISO - the command:
manjaro-chroot is only available there - not in Ubuntu
If the -a (automatic) variant doesn’t work, you can assemble the file system yourself
by mounting the / partition
to /mnt for example
and then the EFI partition to it to /mnt/boot/efi
and then
manjaro-chroot /mnt
Your nvme drive has got a GPT partition scheme
Your hdd’s are MBR
That could be a problem.
And, for what it’s worth:
ID-4: /media/rui/0ee3c73e-a415-4901-aca0-1d17f553ada2 raw-size: 322.11 GiB
size: 316.86 GiB (98.37%) used: 301.5 GiB (95.2%) fs: ext4 dev: /dev/sda1
is completely full.
tune2fs -m0 /dev/sda1 could alleviate that situation a bit
Blockquote I already entered live Manjaro. I already gave the command manjaro-chroot -a, it searched for grub in sdc, but my drive is nvme0n1p2, so it can’t find anything.
the automatism doesn’t work for you, apparently
so you need to tell it where the / (root) and the EFI is - like I described
inxi -zv8
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2314 quiet
systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Micro-Star model: MAG Z390 TOMAHAWK (MS-7B18) v: 1.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 1.50 date: 03/26/2019
System RAM: total: 16 GiB available: 15.56 GiB used: 2.1 GiB (13.5%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KHX2400C15/8G serial: <filter>
Device-3: ChannelB-DIMM0 type: no module installed
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-9700 bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 816 high: 931 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 931 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 48016
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 545.xx+ status: current (as of 2024-02; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c82
class-ID: 0300 temp: 44.0 C
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: nouveau
gpu: nouveau display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2021 res: 1920x1080 hz: 144 dpi: 93 gamma: 1.2 chroma: red: x: 0.659
y: 0.337 green: x: 0.298 y: 0.608 blue: x: 0.145 y: 0.059 white: x: 0.314
y: 0.329 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1280x1024, 1280x720, 1024x768, 800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV137 device-ID: 10de:1c82
memory: 3.9 GiB unified: no
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager
Local Storage: total: 2.29 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SS0328D temp: 36.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: MSI model: M371 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFMC0.0 temp: 34.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: HD753LJ
size: 698.64 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1113 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAKX-001CA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Generic model: Flash Disk
size: 15.23 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 8.07 scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24F1MT rev: 1.00
dev-links: cdrom
Message: No partition data found.
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: ext4 label: N/A
uuid: 8b27b1f8-cc01-41be-b530-e90f87b44954
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 97.66 GiB fs: ext4 label: N/A
uuid: e3d686e7-ae42-45c3-bc74-4254fd246731
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 139.34 GiB fs: ext4 label: N/A
uuid: 1e530827-995e-479a-8f24-d0011a9009d5
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 501.3 MiB fs: ext4 label: N/A
uuid: abb9b0da-eea8-497f-930a-d457bd2794e0
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 500 MiB fs: vfat label: N/A
uuid: D34E-42AC
ID-6: /dev/nvme1n1p1 maj-min: 259:7 size: 1.05 GiB fs: vfat label: N/A
uuid: B7A0-11C5
ID-7: /dev/nvme1n1p2 maj-min: 259:8 size: 464.8 GiB fs: ext4 label: N/A
uuid: 1f26a145-9e89-4220-8f5f-90667975fd1f
ID-8: /dev/nvme1n1p3 maj-min: 259:9 size: 434.57 GiB fs: ext4 label: N/A
uuid: 435dd6a7-2deb-4c20-ac3f-5ac192ef7314
ID-9: /dev/nvme1n1p4 maj-min: 259:10 size: 29.3 GiB fs: ext4 label: N/A
uuid: 40fbeb8f-8c9d-45ce-8186-2d1723fc1ae8
ID-10: /dev/nvme1n1p5 maj-min: 259:11 size: 1.79 GiB fs: vfat label: N/A
uuid: 54B1-02C7
ID-11: /dev/sda1 maj-min: 8:1 size: 322.11 GiB fs: ext4 label: N/A
uuid: 0ee3c73e-a415-4901-aca0-1d17f553ada2
ID-12: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-13: /dev/sda5 maj-min: 8:5 size: 279.4 GiB fs: ext4 label: N/A
uuid: bdd3a1c2-9869-4f8c-9838-ce18d3bbd711
ID-14: /dev/sda6 maj-min: 8:6 size: 4 GiB fs: ext4 label: N/A
uuid: 60577d90-a009-47d3-adec-e1a177f648ae
ID-15: /dev/sda7 maj-min: 8:7 size: 93.13 GiB fs: ntfs label: N/A
uuid: 2175302668834263
ID-16: /dev/sdb1 maj-min: 8:17 size: 357.94 GiB fs: ntfs label: N/A
uuid: 046037B76037ADF4
ID-17: /dev/sdb2 maj-min: 8:18 size: 53.46 GiB fs: ext4 label: N/A
uuid: 77209002-c468-474d-8b68-d9fadfb717ce
ID-18: /dev/sdb3 maj-min: 8:19 size: 54.37 GiB fs: ext4 label: N/A
uuid: 2b71eb0a-08ad-4fed-bd50-2ce19b88efa4
ID-19: /dev/sdc1 maj-min: 8:33 size: 3.43 GiB fs: iso9660
ID-20: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: D55B-58EB
Device-1: 1-3:2 info: HP HP Wireless Keyboard and Mouse
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 03f0:5341 class-ID: 0301
Device-2: 1-7:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7b18 class-ID: 0300
serial: <filter>
Hub-2: 1-13:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-13.3:5 info: Alcor Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 39.0 C pch: 54.0 C mobo: N/A gpu: nouveau
temp: 44.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 921
Packages: pm: pacman pkgs: 1164 libs: 330 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.seahost.de/manjaro/stable/$repo/$arch
2: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
3: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
4: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.koddos.net/manjaro/stable/$repo/$arch
8: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
9: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
10: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
11: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
12: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
14: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
15: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
16: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
17: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
18: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
19: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
20: http://manjaro.ucom.am/stable/$repo/$arch
21: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
22: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
24: https://mirror.easyname.at/manjaro/stable/$repo/$arch
25: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
26: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
27: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
28: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
30: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
31: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
32: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
33: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
34: https://muug.ca/mirror/manjaro/stable/$repo/$arch
35: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
36: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
37: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
38: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
39: https://mirror.23m.com/manjaro/stable/$repo/$arch
40: https://manjaro.ynh.ovh/stable/$repo/$arch
41: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
43: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
44: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
46: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
48: https://mirror.zetup.net/manjaro/stable/$repo/$arch
49: http://manjaro.grena.ge/stable/$repo/$arch
50: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
51: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
52: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
53: https://manjaro.kurdy.org/stable/$repo/$arch
54: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
55: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
56: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
57: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
58: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
59: http://manjaro.mirror.ac.za/stable/$repo/$arch
60: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
61: https://mirrors.manjaro.org/repo/stable/$repo/$arch
62: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
63: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
64: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
65: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
66: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
67: https://repo.skni.umcs.pl/manjaro/stable/$repo/$arch
68: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
69: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
70: https://mirror1.cl.netactuate.com/manjaro/stable/$repo/$arch
71: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
72: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
73: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
74: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
75: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
76: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
77: https://mirrors.gethosted.online/manjaro/repos/stable/$repo/$arch
78: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
79: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
80: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
81: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
82: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
83: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
84: https://mirror.init7.net/manjaro/stable/$repo/$arch
85: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
86: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
87: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
88: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
89: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
90: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
91: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
92: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
93: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
94: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
95: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
96: https://mirror.dc.uz/manjaro/stable/$repo/$arch
97: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
98: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
99: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
100: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
101: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
102: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
103: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
104: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
105: http://mirror.fcix.net/manjaro/stable/$repo/$arch
106: https://mirrors.netix.net/manjaro/stable/$repo/$arch
107: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
108: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
109: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
110: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
111: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
112: https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/stable/$repo/$arch
113: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
114: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
115: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
116: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
117: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
118: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
119: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
120: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
121: https://repos.silknet.com/manjaro/stable/$repo/$arch
122: https://manjaro.kyberorg.fi/stable/$repo/$arch
123: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
124: https://mirror.funami.tech/manjaro/stable/$repo/$arch
125: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
126: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
127: https://linorg.usp.br/manjaro/stable/$repo/$arch
128: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
129: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
130: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 365
1: cpu: 23.9% command: firefox pid: 1860 mem: 457.5 MiB (2.8%)
2: cpu: 11.7% command: firefox pid: 2035 mem: 276.5 MiB (1.7%)
3: cpu: 5.6% command: [kworker/u16:4-loop3] pid: 98 mem: 0.00 MiB (0.0%)
4: cpu: 4.2% command: Xorg pid: 1307 mem: 93.7 MiB (0.5%)
5: cpu: 3.0% command: [kworker/u16:1-events_power_efficient] pid: 13
Memory top: 5 of 365
1: mem: 457.5 MiB (2.8%) command: firefox pid: 1860 cpu: 23.9%
2: mem: 276.5 MiB (1.7%) command: firefox pid: 2035 cpu: 11.7%
3: mem: 117.9 MiB (0.7%) command: firefox pid: 2110 cpu: 0.3%
4: mem: 112.5 MiB (0.7%) command: firefox pid: 2087 cpu: 0.3%
5: mem: 98.4 MiB (0.6%) command: xfwm4 pid: 1427 cpu: 1.7%
Processes: 365 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.33
[manjaro@manjaro ~]$
open new terminal and run again:
manjaro-chroot -a
and post output from it…
and format it properly, you were instructed on how to do it…
manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> Detected systems:
--> 0) LinuxMint
--> 1) ManjaroLinux
--> 2) Ubuntu
--> 3) ManjaroLinux1
--> 4) LinuxMint1
--> 5) ManjaroLinux2
==> Select system to mount [0-5] :
what is that output… how many manjaros do you have installed?
this is proper formatting:
use:
your output here
just like its described above…
or:
your output here
Don’t use “Blockquote”.
Use “Preformatted text” for posting terminal output.
I have done it once again for you
I have old drives and old manjaros that no longer work.
I know that the manjaro that stopped working is on the nvme1n1p5 partition.
Instructions given might have been unclear; use ``` or ~~~ only for code or command output; your text comments can be typed normally, without any boxes.
Corrected for you. No charge.
manjaro-chroot -a
--> 0) LinuxMint
--> 1) ManjaroLinux
--> 2) Ubuntu
--> 4) LinuxMint1
3
==> Mounting (ManjaroLinux1) [/dev/nvme1n1p3]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.795 Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/
0.352 France : https://manjaro.syxpi.fr/manjaro/
1.531 United_States : https://mirrors.sonic.net/manjaro/
..... Netherlands : https://mirror.bouwhuis.network/manjaro/
0.270 Global : https://mirrors.manjaro.org/repo/
::INFO Writing mirror list
::Global : https://mirrors.manjaro.org/repo/testing
::France : https://manjaro.syxpi.fr/manjaro/testing
::Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/testing
::United_States : https://mirrors.sonic.net/manjaro/testing
::Netherlands : https://mirror.bouwhuis.network/manjaro/testing
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 144.4 KiB 902 KiB/s 00:00 [######################] 100%
extra 8.5 MiB 16.8 MiB/s 00:01 [######################] 100%
multilib 145.1 KiB 907 KiB/s 00:00 [######################] 100%
resolving dependencies...
Packages (9) ca-certificates-mozilla-3.114-1 gettext-0.26-1
install-grub-2:2.12.r350.g0e367796-2 less-1:679-1
linux612-6.12.40-1 linux615-6.15.8-1 man-pages-6.15-1
nspr-4.37-1 nss-3.114-1
Total Download Size: 293.18 MiB
Total Installed Size: 321.86 MiB
Net Upgrade Size: 0.31 MiB
:: Proceed with installation? [Y/n] s
[manjaro /]# pacman-mirrors -f 5 && pacman -Syyu
0.600 Germany : http://ftp.uni-kl.de/pub/linux/manjaro/
1.657 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
0.810 United_States : https://southfront.mm.fcix.net/manjaro/
0.520 Austria : https://mirror.easyname.at/manjaro/
2.574 South_Africa : https://manjaro.mirror.ac.za/
::Austria : https://mirror.easyname.at/manjaro/testing
::Germany : http://ftp.uni-kl.de/pub/linux/manjaro/testing
::United_States : https://southfront.mm.fcix.net/manjaro/testing
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/testing
::South_Africa : https://manjaro.mirror.ac.za/testing
core 144.4 KiB 397 KiB/s 00:00 [######################] 100%
extra 8.5 MiB 11.2 MiB/s 00:01 [######################] 100%
multilib 145.1 KiB 345 KiB/s 00:00 [######################] 100%
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
==> Starting build: '6.15.8-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [microcode]
-> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.15-x86_64-fallback.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
(5/6) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.15-x86_64.img
Found initrd fallback image: /boot/initramfs-6.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Found Linux Mint 21.3 Virginia (21.3) on /dev/nvme0n1p2
Found Manjaro Linux (23.1.4) on /dev/nvme0n1p3
Found Ubuntu 24.04.2 LTS (24.04) on /dev/nvme1n1p2
Found Linux Mint 17.3 Rosa (17.3) on /dev/sda1
Found Manjaro Linux (18.0.4) on /dev/sda5
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(6/6) Updating the info directory file...
/etc/X11/mhwd.d:
nvidia.conf nvidia.conf.nvidia-xconfig-original
/etc/X11/xinit:
xinitrc xinitrc.d xserverrc
/etc/X11/xorg.conf.d:
00-keyboard.conf 90-mhwd.conf
/etc/modprobe.d:
mhwd-gpu.conf
