pawel
22 October 2022 11:09
1
In kernel 6.0.2-2 I have some issues with applications. The are constantly crashing:
discord
paลบ 22 12:44:15 d4rkw4v3 discord.desktop[10911]:
paลบ 22 12:44:15 d4rkw4v3 systemd-coredump[10915]: [๐ก] Process 3101 (Discord) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 00e2007671a5413021c42f09be4e4883a8d0356c
Module libtss2-sys.so.1 with build-id 1498ac4b48b90c1d3ac0f5f8f4d27d667bfc4771
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
firefox:
aลบ 22 12:43:32 d4rkw4v3 systemd-coredump[10559]: [๐ก] Process 10474 (WebExtensions) of user 1000 dumped core.
Module /usr/lib/firefox/liblgpllibs.so with build-id 839ed8065dbed3eb477af98b3387f05fc8ad79c0
Module libfreeblpriv3.so with build-id 0e4b8d449822b93d68dbed22ca5df37050c4f364
Module libsoftokn3.so with build-id b427cc44aa453f089bbf0998f2a86d82b50f5bfa
Module libplds4.so with build-id 26c6c93ab7e9b7022734be96a91d0959b4c84fe5
vivaldi
paลบ 22 12:43:26 d4rkw4v3 vivaldi-stable.desktop[10060]: [10055:10055:1022/124326.031553:ERROR:vivaldi_ui_web_contents_delegate.cc(78)] Quiting Vivaldi
paลบ 22 12:43:26 d4rkw4v3 vivaldi-stable.desktop[10060]: [10055:10055:1022/124326.013165:ERROR:vivaldi_ui_web_contents_delegate.cc(47)] UI Process abnormally terminates with status 3 after running for 2.57667 seconds!
paลบ 22 12:43:25 d4rkw4v3 systemd-coredump[10238]: [๐ก] Process 10123 (vivaldi-bin) of user 1000 dumped core.
Module libwidevinecdm.so with build-id e8b384278b62d82722bb2599c02fca53af063083
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
nautilus
paลบ 22 12:39:41 d4rkw4v3 systemd-coredump[8187]: [๐ก] Process 8150 (nautilus) of user 1000 dumped core.
Module libnss_systemd.so.2 with build-id 7742b911aa659b14561dade58e27806632303093
Module librsvg-2.so.2 with build-id c5d3f3e2ba0718c84f4f6f02974929f5459dde04
On the 5.19.16-2-MANJARO seams to work fine and stable. No crashing.
always error on linux-vdso โฆ
can you report
inxi -Fza
pawel
22 October 2022 13:48
3
inxi -Fza โโฏ
Kernel: 5.19.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=03335a16-f0fe-4254-b207-641660c2e2d3 rw quiet apparmor=1
security=apparmor resume=UUID=e728ef0b-9414-40e9-96f6-84db502863de
udev.log_priority=3
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: 1: GDM
v: 42.0 2: LightDM v: 1.32.0 note: stopped Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 6042
date: 04/28/2022
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2118 high: 2200 min/max: 2200/4000 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 1875
3: 1946 4: 2200 5: 2189 6: 2200 7: 2171 8: 2078 9: 2200 10: 1953 11: 1878
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 128057
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
s-diag: 1468mm (57.81")
Monitor-1: DP-0 pos: primary,top-left res: 3440x1440 dpi: 107
size: 819x346mm (32.24x13.62") diag: 889mm (35") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
bus-ID: 09:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
chip-ID: 1022:1457 class-ID: 0403
Sound API: ALSA v: k5.19.16-2-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vboxnet0 state: down mac: <filter>
Local Storage: total: 1.4 TiB used: 1.16 TiB (83.3%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: SanDisk model: ADATA SX6000PNP
size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9001b31
temp: 31.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 32A0T54A
temp: 28.9 C
ID-1: / raw-size: 200.85 GiB size: 196.63 GiB (97.90%) used: 173.25 GiB
(88.1%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:5
ID-1: swap-1 type: partition size: 25.19 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
System Temperatures: cpu: 38.0 C mobo: 25.0 C gpu: nvidia temp: 29 C
Fan Speeds (RPM): cpu: 0 case-1: 0 case-2: 835 case-3: 758 gpu: nvidia
fan: 32%
Power: 12v: 12.43 5v: N/A 3.3v: N/A vbat: N/A
Processes: 532 Uptime: 3h 2m wakeups: 5 Memory: 31.25 GiB used: 6.39 GiB
(20.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2638 pm: pacman pkgs: 2585
libs: 581 tools: gnome-software,pamac,yay pm: flatpak pkgs: 48 pm: snap
pkgs: 5 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.22
EDIT
And other kernels are deleted? Stayed only 5.19 and 6.0. I had linux510 linux515 lts versions
vmlinuz-5.19-x86_64
vmlinuz-6.0-x86_64
โญโ ๏ ๎ฐ ๏ฃ /boot ๎ฐโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ๎ฒ โ ๎ฒ at 15:56:11 ๏ โโฎ
โฐโ ll โโฏ
rwx------ 3 root root 4 KiB Thu Jan 1 01:00:00 1970 ๏ efi/
rwxr-xr-x 5 root root 4 KiB Sat Oct 22 12:58:04 2022 ๏ grub/
rwxr-xr-x 2 root root 4 KiB Thu Jun 17 20:37:36 2021 ๏ memtest86+/
rw-r--r-- 1 root root 50 KiB Sat Sep 24 20:04:36 2022 ๏
amd-ucode.img
rw------- 1 root root 36 MiB Mon Oct 17 16:58:51 2022 ๏
initramfs-5.19-x86_64-fallback.img
rw------- 1 root root 7 MiB Mon Oct 17 16:58:41 2022 ๏
initramfs-5.19-x86_64.img
rw------- 1 root root 36 MiB Mon Oct 17 16:59:03 2022 ๏
initramfs-6.0-x86_64-fallback.img
rw------- 1 root root 7 MiB Mon Oct 17 16:58:53 2022 ๏
initramfs-6.0-x86_64.img
rw-r--r-- 1 root root 23 B Sat Oct 15 15:40:00 2022 ๏
linux510-x86_64.kver
rw-r--r-- 1 root root 22 B Sat Oct 15 15:38:02 2022 ๏
linux515-x86_64.kver
rw-r--r-- 1 root root 22 B Sat Oct 15 15:36:02 2022 ๏
linux519-x86_64.kver
rw-r--r-- 1 root root 20 B Sat Oct 15 15:31:02 2022 ๏
linux60-x86_64.kver
rw-r--r-- 1 root root 10 MiB Mon Oct 17 16:58:38 2022 ๏
vmlinuz-5.19-x86_64
vmlinuz-6.0-x86_64
โญโ ๏ ๎ฐ ๏ฃ /boot ๎ฐโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ๎ฒ โ ๎ฒ at 15:56:12 ๏ โโฎ
โฐโ mhwd-kernel -li โโฏ
Currently running: 5.19.16-2-MANJARO (linux519)
* linux510
* linux515
* linux519
* linux60
this update not so good
pawel
23 October 2022 17:40
4
Hello, On kernel 5.19.16-2-MANJARO I have core dumps also. Also steam is crashing
systemd-coredump[9003]: Process 6043 (steamwebhelper) of user 1000 dumped core.
Module /home/swistak/.local/share/Steam/ubuntu12_64/steamwebhelper with build-id b133bc970a349fac9787be805f84c9b4f9be44ad
#15 0x000000000058b820 n/a (/home/swistak/.local/share/Steam/ubuntu12_64/steamwebhelper + 0x18b820)
#16 0x000000000055ba7b n/a (/home/swistak/.local/share/Steam/ubuntu12_64/steamwebhelper + 0x15ba7b)
Any ideas? It is very irritating. Only reboot fixing issues for a while
see this update your EFI motherboard
ASUS Prime motherboards are expertly engineered to unleash the full potential of AMD and Intel processors. Boasting a robust power design, comprehensive cooling solutions and intelligent tuning options, these ASUS motherboards provide daily users and...
add these parameters on boot kernel
โamd_iommu=on iommu=pt processor.max_cstate=5 systemd.unified_cgroup_hierarchy=true scsi_mod.use_blk_mq=1โ
sudo nano /etc/default/grub
sudo update-grub
pawel
24 October 2022 09:10
6
Hello,
Can You explain about parameters? Iโve found some of them so:
โ IOMMU Advisory for AMD Instinctโข - AMD Community
how check current value to see any difference?
โ
sudo cat module/processor/parameters/max_cstate
the value is 8
so What are the CPU c-states? How to check and monitor the CPU c-state usage in Linux per CPU and core? - GoLinuxHub in my opinion this state is better.
โ please explain
โ I have on Y
cat /sys/module/dm_mod/parameters/use_blk_mq
โ File: /sys/module/dm_mod/parameters/use_blk_mq
1 โ Y
EDIT:
The core dumps comes after failed update of the system. I had this issue (now is fixed but donโt know that is not connected] System Crash during update - #27 by pawel with glibc
and GPG
and certificates
Use a live USB and chroot into the system.
Run a full system update - exit chroot - and reboot.
this point is most significant ,
boot on USB iso , open a terminal
sudo manajro-chroot - a
if btrfs or zfs is installed use
sorry I am new to this, could you elaborate this more, with some detailed commands and explanations please?
if you use luks
in case you need to chroot
sudo su
cryptsetup luksOpen /dev/sdaX crypto ( here volume mapper encrypted )
cryptsetup luksOpen /dev/sdaY swap ( case out encrypted )
mount /dev/mapper/crypto /mnt
mount /dev/sda1 /mnt/boot/efi ( if you need Efi )
mount -t proc proc /mnt/proc
mount -t sysfs sys /mnt/sys
mount -o bind /dev /mnt/dev
mount -t devpts pts /mnt/dev/pts/
chroot /mnt
under chroot
pacman-mirrors -c all ( check for internet is ok )
pacman -Syyua
exit ( end chroot , have to be done )
then you can reboot
pawel
25 October 2022 13:10
10
Maybe I didnโt say before but the applications crashes are not always when Iโm trying to run the app. The applications stars but after a some time they have core dump suddenly and restarting.
I can update the system and open applications from installed manajaro.
For example pamac today:
journalctl --user -r | grep pamac โโฏ
paลบ 25 13:54:50 d4rkw4v3 systemd-coredump[19383]: Process 19345 (pamac-manager) of user 1000 dumped core.
Module libpamac-flatpak.so with build-id 0dc079843e63ab9faa571f151602de15f2f41673
Module libpamac-snap.so with build-id 7e044dd14c7f90f231badd6a585944aefd5117bb
Module libpamac.so.11 with build-id 59584de99432da492bef0cc946a43c7bafc79589
Module libpamac-gtk.so with build-id c409d6b8b9fcf897e83fb4b0e9482fdc8532f742
Module pamac-manager with build-id ed031747767d8f689f62ccaa81e099c730b92303
#7 0x00007fcbf3fbcafc pamac_aur_parse_db (libpamac.so.11 + 0x2dafc)
#8 0x00007fcbf3fbd1e1 pamac_aur_get_multi_infos (libpamac.so.11 + 0x2e1e1)
#9 0x00007fcbf3fcac29 pamac_database_initialise_pkgs (libpamac.so.11 + 0x3bc29)
#10 0x00007fcbf3fcaddf ____lambda15__gthread_func (libpamac.so.11 + 0x3bddf)
#4 0x000055cbbbfe940a n/a (pamac-manager + 0xd40a)
#7 0x000055cbbbfe94d5 n/a (pamac-manager + 0xd4d5)
I did refreshed pacman-mirrors and
sudo pacman -Syyu โโฏ
:: Synchronizowanie baz danych z pakietamiโฆ
core 163,0 KiB 2,53 MiB/s 00:00 [#################################################################################################################################################] 100%
extra 1834,1 KiB 44,8 MiB/s 00:00 [#################################################################################################################################################] 100%
community 7,4 MiB 84,7 MiB/s 00:00 [#################################################################################################################################################] 100%
multilib 174,6 KiB 8,53 MiB/s 00:00 [#################################################################################################################################################] 100%
:: Rozpoczynanie peลnej aktualizacji systemuโฆ
nie ma nic do zrobienia
nothing to do.
The system is updated but core dumps shows quite often.
installed kernel 5.15
Currently running: 5.15.74-3-MANJARO (linux515)
maybe the dump core crash will gone
pawel
25 October 2022 18:48
11
vivaldi crashed.
Process 131992 (vivaldi-bin) of user 1000 dumped core.
Reinstalled whole system, installed updates and applications still crashing.
