hello im a linux newbie. just installed manjaro kde and entered this command sudo journalctl -p 3 -xb and got this pretty long error message
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: x86/cpu: SGX disabled by BIOS.
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible v>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE>
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20210730/psargs->
May 01 11:16:51 manmohan-vivobookasuslaptopx512facx512fa kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (202107>
May 01 11:16:53 manmohan-vivobookasuslaptopx512facx512fa systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ Defined-By: systemd
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 308 and the job result is failed.
May 01 11:16:54 manmohan-vivobookasuslaptopx512facx512fa systemd[592]: Failed to start Update XDG user dir configuration.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 23 and the job result is failed.
May 01 11:17:03 manmohan-vivobookasuslaptopx512facx512fa bluetoothd[544]: Failed to set mode: Blocked through rfkill (0x12)
please help me understand this and one more thing i had also entered this command systemctl --failed and got this one more failed systemd service error
systemctl --failed INT ✘ 5m 50s
UNIT LOAD ACTIVE SUB DESCRIPTION
● pkgfile-update.service loaded failed failed pkgfile database update
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
please help what am i supposed to do now
