I don't know why the icons are shown with white background in budgie
I don’t know why the icons are shown with white background in budgie
Google translator:
This is my problem, I have tried to do a clean install, but it is the same, I have looked at similar problems, but I cannot find a solution, the programs that are open are SimpleScreenRecorder and flameshot.
I have noticed that the same does not happen with Telegram.
Welcome to the forum! :wave:
Since you’re a new user on this forum, I’d recommend you take a look at the link below and update your post accordingly.
That way, other users might be able to help out. :slightly_smiling_face:
Google translator:
Thank you, I’ll keep it in mind, sorry for the inconvenience :slight_smile: .
No problem.
It looks like you’re using Qt-based apps on a GTK-based desktop environment. Desktop themes based on GTK will not show proper icons for Qt-based apps.
A similar issue was already discussed on the legacy forum. See below:
https://archived.forum.manjaro.org/t/budgie-ugly-tray-icons-problem-qt-apps/89229
I’d recommend you take a look at Kvantum themes as mentioned on the link above.
thanks for the help, it worked fine, simply uninstalling Kvantum. :+1:t3: :100:
extra information:
Tried changing the Kvantum theme and it worked too.
You’re welcome. Glad it worked for you! :slightly_smiling_face:
