HI everybody.
I’m new to linux and I just installed manjaro alongside windows 10 in my Asus FX505gt with realtek audio card but I don’t have sound at all.
Tl;dr - Provide output of inxi -Fazy and make sure you disable fast boot, secure boot, whatever boot.
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7cb274d1-5c6e-4161-b599-d663892993b8 rw quiet udev.log_priority=3
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505GT.309 date: 11/06/2020
ID-1: BAT0 charge: 44.6 Wh (100.0%) condition: 44.6/48.1 Wh (92.7%)
volts: 12.7 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: Full cycles: 41
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 8 MiB
bogomips: 38408
Speed: 899 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 899 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: nvidia note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 10.66 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK
lanes: 4 type: SSD serial: <filter> rev: P1MA0V4 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 53.71 GiB size: 52.57 GiB (97.87%) used: 10.66 GiB (20.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 50.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 2700
Processes: 283 Uptime: 1h 21m wakeups: 1 Memory: 7.62 GiB
used: 2.18 GiB (28.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: 1140 pacman: 1129 lib: 294 flatpak: 0 snap: 11 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.08
It’s the full output and I’ve disabled Fast boot and Secure boot.
My problem fixed with installing sof-fromware by this command:
sudo pacman -S sof-firmware
Thanks to @ishaan2479 and hopeseekr on this Link.
