I have manjaro rolling. When I execute sudo systemctl restart tor.service or sudo systemctl start tor.service, I get this error:
Job for tor.service failed because the control process exited with error code. See "systemctl status tor.service" and "journalctl -xeu tor.service" for details.
What is the problem? I could use tor for some days ago.
The log file mentioned in the message yielded nothing?
Hi @RezaHoss,
There is only one version of Manjaro.
No-one would know without looking somewhere, and
It actually tells you where to look.
Please do as the message said, and provide the output for:
and
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or 3 (three) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
This is last part of journalctl -xeu tor.service:
░░ Subject: A start job for unit tor.service has failed
░░ Defined-By: systemd
░░ A start job for unit tor.service has finished with a failure.
░░ The job identifier is 5545 and the job result is failed.
And systemctl status tor.service:
× tor.service - Anonymizing overlay network for TCP
Loaded: loaded (/usr/lib/systemd/system/tor.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Tue 2023-01-03 19:28:43 +0330; 59min ago
Process: 10646 ExecStartPre=/usr/bin/tor -f /etc/tor/torrc --verify-config (code=exited, status=1/FAILURE)
CPU: 21ms
ژانویه 03 19:28:43 reza-manjaro systemd[1]: tor.service: Scheduled restart job, restart counter is at 5.
ژانویه 03 19:28:43 reza-manjaro systemd[1]: Stopped Anonymizing overlay network for TCP.
ژانویه 03 19:28:43 reza-manjaro systemd[1]: tor.service: Start request repeated too quickly.
ژانویه 03 19:28:43 reza-manjaro systemd[1]: tor.service: Failed with result 'exit-code'.
ژانویه 03 19:28:43 reza-manjaro systemd[1]: Failed to start Anonymizing overlay network for TCP.
NOTE: ژانویه is january
Why only the last part?
Where it says that it has failed - but not why.
That may be in there, but before what you shared.
anyway - if I read that correctly:
there seems to be something wrong with the configuration file
I was using tor with this config with no problem.
░░ The job identifier is 5444 and the job result is failed.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit tor.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
░░ Subject: A stop job for unit tor.service has finished
░░ A stop job for unit tor.service has finished.
░░ The job identifier is 5545 and the job result is done.
░░ Subject: Unit failed
░░ The unit tor.service has entered the 'failed' state with result 'exit-code'.
yet, this is the error message that I see ![]()
Surprisengly when I removed a bridge from torrc, the problem solved!
Hey man!
I have the exact same problem.
Could tell me exactly what you change to get past this error message?
