Hello, everyone,
this is my first post on the forum and I am a new Manjaro user.
The distro is beautiful even if it immediately started to give me some problems, which I hope to solve soon.
I installed first Manjaro and snap-store on usb and everything worked well, now that I formatted my computer switching completely to manjaro I don’t understand why it doesn’t work.
Practically if I open the snap-store menu it doesn’t open, if I try to start it from terminal it shows me this message:
snap-store
01:10:31:0449 Gtk Failed to load module “canberra-gtk-module”
01:10:31:0466 Gtk Theme parsing error: gtk.css:1:0: Failed to import: Errore nell’aprire il file /var/lib/snapd/hostfs/usr/share/themes/Breath/gtk-3.0/gtk.css: Permission denied
01:10:31:0467 Gtk Failed to load module “colorreload-gtk-module”
01:10:31:0500 Gs enabled plugins: odrs, rewrite-resource, snap, icons, key-colors, key-colors-metadata
01:10:31:0500 Gs disabled plugins: appstream, desktop-categories, desktop-menu-path, dpkg, dummy, fedora-langpacks, fedora-pkgdb-collections, fwupd, generic-updates, hardcoded-blacklist, hardcoded-popular, modalias, os-release, packagekit, packagekit-history, packagekit-local, packagekit-offline, packagekit-proxy, packagekit-refine, packagekit-refine-repos, packagekit-refresh, packagekit-upgrade, packagekit-url-to-app, provenance, provenance-license, repos, systemd-updates
01:10:31:0584 Gs /etc/PackageKit/Vendor.conf file not found
01:10:31:0770 Pango pango_font_get_hb_font: assertion ‘PANGO_IS_FONT (font)’ failed
Errore di segmentazione (core dump creato)
I tried to find the box that tells me where to enter the code, but the only similar thing I found and how to format the text, I hope I haven’t made any mistake, in case you can tell me and I’ll try to improve next time.
Also I didn’t find in the forum a section for new users and welcome, so I take the opportunity to greet you all here directly in my first post.
I followed several guides in these 24 hours, trying to purge completely both snapd and snap-store, in the end I was able to use terminal snap (before it didn’t work) but not to open directly snap-store, do you think it’s possible to fix this situation?
I leave you some of the different guides I followed, some of them are in my language.
Thank you in advance to everyone.
PS sorry, i can’t include link in my post, i don’t know why.
