“EFI variables are not supported on this system. grub-install error: efibootmgr failed to register the boot entry: No such file or directory”
This is the problem can anyone help me?
I have no idea what this means…
I am trying to install by cancelling everything else on SSD, is there something wrong I am doing?
As @cryptocurious said, you should rebuild the partition table. You can actually just do that in the LiveISO with Calamaras (the installer). In manual partition section, you should be able to change the partition table to GPT. Note: This will wipe everything on that drive.
I’m afraid it didn’t work for me. I think I’ve done everything suggested in this and other similar threads … including disabling secure boot in the bios and reformatting to GPT in gparted. But I still get the dreaded bootloader error when trying to install onto an Acer laptop. Messages like “grub install returned non-zero exit status 1”, “Could not prepare Boot variable: interrupted system call grub-install”, “efi bootmgr failed to register the boot entry.”
Surely it shouldn’t this problematic to install Manjaro from the official image? What am I missing?
Any help gratefully received, otherwise I’ll never get this laptop off the live usb.
