I have tried many times to install the driver but all failed
Thx
What have you tried? Please post inxi output as described below. Have you tried searching this forum for help with this issue?
In addition, I have come across this page as well as many others.
But from what I understand, you must install the t4u
drivers. And those are in the AUR:
$ pamac search t4u
rtl8822bu-dkms 5.8.7.4-1 AUR
Kernel module for Edimax EW7822ULC USB3, Asus AC53 Nano USB 802.11ac and TP-Link Archer T4U adapter. Patched for Linux v5.12.
So, you should just be able to build rtl8822bu-dkms
pamac build rtl8822bu-dkms
Edit:
If that doesn’t work, you should give more information as @jrichard326 indicated.
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=62ed7d2d-a00e-457f-b77f-481a1a9fc52d rw quiet apparmor=1
security=apparmor resume=UUID=2a02e95d-6e3c-41fb-87ca-96482bf5126a
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: ASRock model: H310CM-HDV serial: <filter>
UEFI: American Megatrends v: P4.20 date: 05/14/2019
RAM: total: 7.7 GiB used: 3.06 GiB (39.7%)
Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: EA
cache: L2: 9 MiB bogomips: 34814
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f82
class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
vendor: ASRock driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
IF-ID-1: enp0s20f0u5 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: vivo iQOO Z1x type: USB driver: rndis_host v: kernel bus-ID: 1-5:6
chip-ID: 2d95:600a class-ID: 0a00 serial: <filter>
Local Storage: total: 931.51 GiB used: 143.04 GiB (15.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00WN4A0
type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS122 rev: ZL0F dev-links: cdrom
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 143.04 GiB (15.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 62ed7d2d-a00e-457f-b77f-481a1a9fc52d
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: CC2E-F3FB
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 2a02e95d-6e3c-41fb-87ca-96482bf5126a
Device-1: 1-5:6 info: vivo iQOO Z1x type: Bluetooth,CDC-Data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-6:2 info: Logitech Wireless Receiver type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 046d:c542 class-ID: 0301
Device-3: 1-7:3 info: TP-Link Archer T4U ver.3 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
chip-ID: 2357:0115 class-ID: 0000 serial: <filter>
Device-4: 1-9:4 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 209 Uptime: 7m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1209 pacman: 1189 lib: 363 flatpak: 17
snap: 3 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
Sorry I am new to this forum.
What should I do next?
There is no other network device… is it not initialized or not plugged in?
I am very sure that the usb are plugged in. I have tried it in Windows and it worked. I don’t know why the system is not noticing the device. Thank you
Oh… I overead it… here:
So this device is reconized…
When I look for chipID: TP-Link Archer T4U ver.3 You will see some github repos with drivers, but when I investigate the official driver here: Download fĂĽr Archer T4U | TP-Link Deutschland then only the source code is provided which seems to be same as on GitHub - RinCat/RTL88x2BU-Linux-Driver: Realtek RTL88x2BU WiFi USB Driver for Linux and AUR (en) - rtl88x2bu-dkms-git
So installing this:
pamac build rtl88x2bu-dkms-git
Should do it. You need to reboot OR just modprobe the module and plugin in the device after installing.
The driver seems to have successfully installed
However, I cannot modprobe the module. The wifi are still not detected.
I am thankful for your support
tbh I have installed some drivers for wifi before in linux, but this time it really bothers me lol
modprobe: FATAL: Module rtl88x2bu-dkms-git not found in directory /lib/modules/5.13.15-1-MANJARO
What command did you use?
Maybe try this:
sudo modprobe 88x2bu
or possibly sudo modprobe 8812bu
sudo modprobe rtl88x2bu
The 88x2bu give me with no response and the other one is not found in the directory. Thank you
Giving no response may mean it was loaded successfully
Reboot and post output of inxi -N
again.
driver: r8169
Also inxi -Fazy --filter
You should see a driver loaded for your USB wifi adapter
Sorry aafsmarak but after reading through all of the instructions. I am finally able to fix the usb ( Maybe because file system, or I read something wrong)
I appreciate all of the help from this thread, your replies make the forum very welcoming
Now i am just trying to make the wifi connect to a 5 ghz one.
