I can not access my second drive (HDD)
I am telling ya all thing.
1.I installed Manjaro
2.I have 2 disk. A ssd a hdd. SSD and HDD is ext4.
3.I installed erase and install option with. Just SSD mounted as root.
4.HDD is mounted as just drive.
5.But I can not access. For example: I can not creating new file on it.
I tried this command:
sudo chown myusername /dev/sda1
lsblk         ✔
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0 465,8G  0 disk
└─sda1   8:1    0 465,8G  0 part /run/media/caner/db5e4d93-0478-4aab-b34e-cea7b62ff3e7
sdb      8:16   0 223,6G  0 disk
├─sdb1   8:17   0   300M  0 part /boot/efi
├─sdb2   8:18   0 214,5G  0 part /
└─sdb3   8:19   0   8,8G  0 part [SWAP]
Is a device file, so you don’t chown/chmod it. You chown/chmod the mountpoint.
sudo chown $USER:$USER /run/media/caner/db5e4d93-0478-4aab-b34e-cea7b62ff3e7
/run is a temporary filesystem, it’s a place where software can put stuff without affecting the rest of the system. You should mount it elsewhere using fstab or systemd unit files.
I had a similar issue the other day, I have the KDE partition manager I created the partition using this. Don’t know if this will help you out, but worth a shot.
