How can i fix this issue
Did you search the forum before posting? The solution can be found at:
Edit: sorry @MeuKey - I just saw that you did post in the above thread. Make sure that you don’t put the “XXXXXXXXXXX” in your /etc/default/grub file - that text is just meant to indicate that you should leave whatever else is already in the grub file there.
From the topic linked by scotty65 it seems upgrading the kernel solved your issue.
