I am unable to connect to wifi on 802.1x profiles on KDE
I am unable to connect to wifi on 802.1x profiles on KDE, tried kernels 6.0 and 5.15 to no avail.
Please check this [HowTo] Request support and provide that information.
Info for context,
Updated to latest testing branch and broke wifi connections for 802.1x profiles on PEAP/MSCHAPv2, personal profiles are working fine last I tested.
System information:
  Kernel: 5.15.77-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=b1546959-0789-4c29-bf9f-1e6131f1e467 rw rootflags=subvol=@
    ibt=off quiet
    cryptdevice=UUID=e7aee159-b224-46c7-8292-d082eac36827:luks-e7aee159-b224-46c7-8292-d082eac36827
    root=/dev/mapper/luks-e7aee159-b224-46c7-8292-d082eac36827
    resume=/dev/mapper/luks-018c771d-44dc-4846-a9d5-92dcab3c8904
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 21DCCTO1WW v: ThinkPad P1 Gen 5
  Mobo: LENOVO model: 21DCCTO1WW v: SDK0T76538 WIN
    serial: <superuser required> UEFI: LENOVO v: N3JET28W (1.12 )
    date: 10/18/2022
  ID-1: BAT0 charge: 31.0 Wh (33.5%) condition: 92.5/90.1 Wh (102.6%)
    volts: 14.9 min: 15.5 model: SMP 5B11B79217 type: Li-poly serial: <filter>
    status: discharging cycles: 19
  RAM: total: 62.48 GiB used: 6.06 GiB (9.7%)
  Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x422
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1645 high: 3806 min/max: 400/4700:4800:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 441 2: 3806 3: 622 4: 1199
    5: 3700 6: 3700 7: 659 8: 3562 9: 438 10: 2417 11: 1393 12: 3580 13: 458
    14: 828 15: 963 16: 922 17: 843 18: 813 19: 1498 20: 1064 bogomips: 112160
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
    driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24a0 class-ID: 0300
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-8:3 chip-ID: 04f2:b74f class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 model: BOE Display 0x0ae0 built: 2021 res: 2560x1600
    dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 2560x1600
  API: OpenGL v: 4.6 Mesa 22.2.2 renderer: Mesa Intel Graphics (ADL GT2)
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  Device-2: NVIDIA GA104 High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Sound API: ALSA v: k5.15.77-2-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
  IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
    chip-ID: 8087:0033 class-ID: e001
  Device-1: luks-e7aee159-b224-46c7-8292-d082eac36827 maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.8 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.8 TiB
  Device-2: luks-018c771d-44dc-4846-a9d5-92dcab3c8904 maj-min: 254:1
    type: LUKS dm: dm-1 size: 68.72 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 68.72 GiB
  Local Storage: total: 2.31 TiB used: 403.41 GiB (17.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA2T0TFH
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 7006P7LN temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB model: USB DISK 3.0 size: 462.07 GiB
    block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
    rev: PMAP scheme: MBR
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 403.39 GiB (21.9%)
    fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-e7aee159-b224-46c7-8292-d082eac36827 label: N/A
    uuid: b1546959-0789-4c29-bf9f-1e6131f1e467
    used: 21.8 MiB (7.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: D558-FC16
  ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
    used: 403.39 GiB (21.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  ID-4: /var/cache raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-5: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-1: swap-1 type: partition size: 68.72 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-018c771d-44dc-4846-a9d5-92dcab3c8904 label: swap
    uuid: 309244d8-eac9-4d28-b627-73c4afad4124
  ID-1: /dev/sda1 maj-min: 8:1 size: 461.57 GiB fs: vfat label: USB DISK
    uuid: 2D0A-E000
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00f9
    class-ID: ff00 serial: <filter>
  Device-2: 1-8:3 info: Chicony Integrated Camera type: Video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-3: 1-9:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
    type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
  Device-4: 1-10:5 info: Intel type: Bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-2:2 info: Kingston USB DISK 3.0 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 504mA
    chip-ID: 13fe:6400 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 52.0 C mobo: N/A
  Fan Speeds (RPM): fan-1: 2270
  Processes: 508 Uptime: 18m wakeups: 1724 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1396 libs: 346 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: tmux: inxi: 3.3.23
journalctl -u NetworkManager -f output:
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'ssid' value 'WLAN-SMU'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'scan_ssid' value '1'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'bgscan' value 'simple:30:-65:300'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'key_mgmt' value 'WPA-EAP FT-EAP FT-EAP-SHA384 WPA-EAP-SHA256'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'auth_alg' value 'OPEN'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'password' value '<hidden>'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'eap' value 'PEAP'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'fragment_size' value '1266'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'phase2' value 'auth=MSCHAPV2'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9456] Config: added 'identity' value '<REDACTED>'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9457] Config: added 'proactive_key_caching' value '1'
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9767] device (wlp0s20f3): supplicant interface state: inactive -> disconnected
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9768] device (p2p-dev-wlp0s20f3): supplicant management interface state: inactive -> disconnected
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9777] device (wlp0s20f3): supplicant interface state: disconnected -> inactive
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9777] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> inactive
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9838] device (wlp0s20f3): supplicant interface state: inactive -> scanning
Nov 09 16:21:18 CELAENO NetworkManager[712]: <info>  [1667982078.9838] device (p2p-dev-wlp0s20f3): supplicant management interface state: inactive -> scanning
Nov 09 16:21:20 CELAENO NetworkManager[712]: <info>  [1667982080.1963] device (wlp0s20f3): supplicant interface state: scanning -> authenticating
Nov 09 16:21:20 CELAENO NetworkManager[712]: <info>  [1667982080.1963] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> authenticating
Nov 09 16:21:20 CELAENO NetworkManager[712]: <info>  [1667982080.2252] device (wlp0s20f3): supplicant interface state: authenticating -> associating
Nov 09 16:21:20 CELAENO NetworkManager[712]: <info>  [1667982080.2252] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
Nov 09 16:21:20 CELAENO NetworkManager[712]: <info>  [1667982080.2435] device (wlp0s20f3): supplicant interface state: associating -> associated
Nov 09 16:21:20 CELAENO NetworkManager[712]: <info>  [1667982080.2436] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> associated
Nov 09 16:21:21 CELAENO NetworkManager[712]: <info>  [1667982081.6081] device (wlp0s20f3): supplicant interface state: associated -> disconnected
Nov 09 16:21:21 CELAENO NetworkManager[712]: <info>  [1667982081.6082] device (p2p-dev-wlp0s20f3): supplicant management interface state: associated -> disconnected
Nov 09 16:21:21 CELAENO NetworkManager[712]: <info>  [1667982081.7082] device (wlp0s20f3): supplicant interface state: disconnected -> scanning
Nov 09 16:21:21 CELAENO NetworkManager[712]: <info>  [1667982081.7082] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> scanning
Nov 09 16:21:43 CELAENO NetworkManager[712]: <warn>  [1667982103.7644] device (wlp0s20f3): Activation: (wifi) association took too long
Nov 09 16:21:43 CELAENO NetworkManager[712]: <info>  [1667982103.7645] device (wlp0s20f3): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 09 16:21:43 CELAENO NetworkManager[712]: <warn>  [1667982103.7652] device (wlp0s20f3): Activation: (wifi) asking for new secrets
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6532] device (wlp0s20f3): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6535] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6536] device (wlp0s20f3): Activation: (wifi) connection 'WLAN-SMU' has security, and secrets exist.  No new secrets needed.
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'ssid' value 'WLAN-SMU'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'scan_ssid' value '1'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'bgscan' value 'simple:30:-65:300'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'key_mgmt' value 'WPA-EAP FT-EAP FT-EAP-SHA384 WPA-EAP-SHA256'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'auth_alg' value 'OPEN'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'password' value '<hidden>'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'eap' value 'PEAP'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'fragment_size' value '1266'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'phase2' value 'auth=MSCHAPV2'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'identity' value '<REDACTED>'
Nov 09 16:21:48 CELAENO NetworkManager[712]: <info>  [1667982108.6537] Config: added 'proactive_key_caching' value '1'
Nov 09 16:21:50 CELAENO NetworkManager[712]: <info>  [1667982110.7341] device (wlp0s20f3): supplicant interface state: scanning -> authenticating
Nov 09 16:21:50 CELAENO NetworkManager[712]: <info>  [1667982110.7342] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> authenticating
Nov 09 16:21:50 CELAENO NetworkManager[712]: <info>  [1667982110.7625] device (wlp0s20f3): supplicant interface state: authenticating -> associating
Nov 09 16:21:50 CELAENO NetworkManager[712]: <info>  [1667982110.7626] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
Nov 09 16:21:50 CELAENO NetworkManager[712]: <info>  [1667982110.7780] device (wlp0s20f3): supplicant interface state: associating -> associated
Nov 09 16:21:50 CELAENO NetworkManager[712]: <info>  [1667982110.7780] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> associated
Nov 09 16:21:51 CELAENO NetworkManager[712]: <info>  [1667982111.4153] device (wlp0s20f3): supplicant interface state: associated -> disconnected
Nov 09 16:21:51 CELAENO NetworkManager[712]: <info>  [1667982111.4154] device (p2p-dev-wlp0s20f3): supplicant management interface state: associated -> disconnected
Nov 09 16:21:51 CELAENO NetworkManager[712]: <info>  [1667982111.5149] device (wlp0s20f3): supplicant interface state: disconnected -> scanning
Nov 09 16:21:51 CELAENO NetworkManager[712]: <info>  [1667982111.5150] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> scanning
Nov 09 16:22:13 CELAENO NetworkManager[712]: <warn>  [1667982133.7645] device (wlp0s20f3): Activation: (wifi) association took too long
Nov 09 16:22:13 CELAENO NetworkManager[712]: <info>  [1667982133.7646] device (wlp0s20f3): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 09 16:22:13 CELAENO NetworkManager[712]: <warn>  [1667982133.7653] device (wlp0s20f3): Activation: (wifi) asking for new secrets
Nov 09 16:22:21 CELAENO NetworkManager[712]: <info>  [1667982141.8556] device (wlp0s20f3): supplicant interface state: scanning -> inactive
Nov 09 16:22:21 CELAENO NetworkManager[712]: <info>  [1667982141.8556] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> inactive
Despite keying the correct password several times, it keeps asking for new secrets and subsequently an error notification “No secrets were provided” will appear
For those who are having a similar issue, I replaced wpa_supplicant with wpa_supplicant-openssl1 from AUR and it works now.
@anon89812132 for your information!
