I am having sudden reboots
Hi everyone,
I’m experiencing sudden and unwanted reboots that started once i tried to upgrade my kernel from 6.10.5-1 to 6.11.0rc3-2. The first time it occurred i immediately downgraded the kernel back to the 6.10 version, but the issue persisted.
Here’s my system info:
  Kernel: 6.10.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=b560ea44-98cd-4bf3-a8e5-3425c7297647 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 82YU v: Lenovo V15 G4 AMN
    serial: <superuser required> Chassis: type: 10 v: Lenovo V15 G4 AMN
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_82YU_BU_idea_FM_V15 G4 AMN uuid: <superuser required>
    UEFI: LENOVO v: L1CN32WW date: 06/14/2023
  ID-1: BAT0 charge: 26.3 Wh (77.4%) condition: 34.0/38.0 Wh (89.5%)
    power: 26.3 W volts: 8.6 min: 7.7 model: BYD2022 L22B2PG2 type: Li-poly
    serial: <filter> status: charging cycles: 165
  Info: model: AMD Ryzen 3 7320U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0xA0 (160) stepping: 0
    microcode: 0x8A00008
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 973 high: 1286 min/max: 900/6375 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1286 2: 900 3: 900 4: 900
    5: 900 6: 900 7: 900 8: 1100 bogomips: 38341
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: AMD Mendocino vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1,
    Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1506 class-ID: 0300 temp: 45.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:54b1
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1550 built: 2022
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
    raphael_mendocino LLVM 18.1.8 DRM 3.57 6.10.5-1-MANJARO)
    device-ID: 1002:1506 memory: 500 MiB unified: no
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 24.1.6-arch1.1
    device-ID: 1002:1506 surfaces: xcb,xlib
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.10.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c822
    class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Info: services: NetworkManager,wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:c123
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
    status: discoverable: no pairing: no
  Local Storage: total: 238.47 GiB used: 117.31 GiB (49.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZAL4256HBJD-00BL2
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 7L1QHXC7 temp: 49.9 C
    scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 117.31 GiB (50.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 48.9 C mobo: N/A gpu: amdgpu temp: 45.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB note: est. available: 7.09 GiB used: 3.48 GiB (49.1%)
  Processes: 276 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
    image: 2.82 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1853 libs: 403 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.35
At the moment i have removed all other kernels from my system, except for 6.10.5-1. I can’t really tell now if the issue was resolved by this, and i have no clue of what could be causing this.
Any help would be greatly appreciated.
UPDATE: I am still having this issue with both 6.1 and 6.6 kernels, although not as frequently as i was before. Searching for this topic on google, i found several posts on this forum that described similar issues, with computer freezing or rebooting without any notice. I read somewhere on a official Arch website that this was an issue that ryzen cpus had, particularly the 5000 series (i’m running on a 7000). I’m really frustrated by this, because changing kernels worked for some days, and now i’m stuck with the same problem again :face_with_spiral_eyes:.
As always, any kind of help is appreciated, and i’d like to thank in advance anyone that might try to help me solve this issue.
Hi @ricvigi,
Thank you for the information. Unfortunately the provided inxi output can’t really tell us why it’s rebooting, for that we needz logz, but you can provide 'em:
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
Provide them in the same format you provided your ``inxi` output, and we can see what there is to see.
Hi @Mirdarthos,
Thank you for the reply. As of now, i have downgraded to a 6.9 kernel (more precisely 6.9.0-4-rt5-MANJARO), and i did not encounter any sudden reboots since then (let’s hope it stays like this). journalctl --priority=warning..crit --no-pager --boot=-1 gives the following (very long) output:
Aug 27 12:33:40 myuser kernel: TSC synchronization [CPU#0 -> CPU#2]:
Aug 27 12:33:40 myuser kernel: Measured 1904813316 cycles TSC warp between CPUs, turning off TSC clock.
Aug 27 12:33:40 myuser kernel:  #1 #3 #5 #7
Aug 27 12:33:40 myuser kernel: mtrr: your CPUs had inconsistent fixed MTRR settings
Aug 27 12:33:40 myuser kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Aug 27 12:33:40 myuser kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20240322/dswload2-326)
Aug 27 12:33:40 myuser kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240322/psobject-220)
Aug 27 12:33:40 myuser kernel: ACPI Error: Needed [Integer/String/Buffer], found [Region] (____ptrval____) (20240322/exresop-469)
Aug 27 12:33:40 myuser kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [LEqual] (20240322/dswexec-433)
Aug 27 12:33:40 myuser kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.WLAN._STA due to previous error (AE_AML_OPERAND_TYPE) (20240322/psparse-529)
Aug 27 12:33:40 myuser kernel: ACPI Error: Needed [Integer/String/Buffer], found [Region] 00000000ac9058d4 (20240322/exresop-469)
Aug 27 12:33:40 myuser kernel: ACPI Error: Method execution failed \_SB.PCI0.GPP2.WLAN._STA due to previous error (AE_AML_OPERAND_TYPE) (20240322/uteval-68)
Aug 27 12:33:40 myuser kernel: Unstable clock detected, switching default tracing clock to "global"
                              If you want to keep using the local clock, then add:
                                "trace_clock=local"
                              on the kernel command line
Aug 27 12:33:40 myuser kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Aug 27 12:33:40 myuser kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 27 12:33:40 myuser kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 14398482
Aug 27 12:33:40 myuser kernel: ext4_test_bit(bit=5137, block=57147421) = 0
Aug 27 12:33:40 myuser kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 15118307
Aug 27 12:33:40 myuser kernel: ext4_test_bit(bit=4066, block=60293141) = 0
Aug 27 12:33:41 myuser systemd-journald[354]: File /var/log/journal/4f9378c7ad384a52835990150f5d7436/system.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support bap plugin
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support bass plugin
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support mcp plugin
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support vcp plugin
Aug 27 12:33:42 myuser bluetoothd[504]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support micp plugin
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support ccp plugin
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support csip plugin
Aug 27 12:33:42 myuser bluetoothd[504]: src/plugin.c:init_plugin() System does not support asha plugin
Aug 27 12:33:42 myuser bluetoothd[504]: Failed to set mode: Failed (0x03)
Aug 27 12:33:45 myuser dbus-broker-launch[500]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Aug 27 12:33:45 myuser dbus-broker-launch[606]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Aug 27 12:33:45 myuser dbus-broker-launch[606]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Aug 27 12:33:45 myuser dbus-broker-launch[606]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Aug 27 12:33:47 myuser sddm-greeter-qt6[602]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Aug 27 12:33:47 myuser sddm-greeter-qt6[602]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.21'
Aug 27 12:33:48 myuser sddm-greeter-qt6[602]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Aug 27 12:33:49 myuser systemd-journald[354]: File /var/log/journal/4f9378c7ad384a52835990150f5d7436/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 27 12:33:49 myuser dbus-broker-launch[702]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Aug 27 12:33:49 myuser dbus-broker-launch[702]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Aug 27 12:33:49 myuser dbus-broker-launch[702]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Aug 27 12:33:49 myuser ksplashqml[706]: Texture 0x73c4f8325fe0 () used with different accesses within the same pass, this is not allowed.
Aug 27 12:33:50 myuser kded6[777]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Aug 27 12:33:50 myuser kded6[777]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Aug 27 12:33:50 myuser kded6[777]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Aug 27 12:33:50 myuser plasmashell[825]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:50 myuser gmenudbusmenuproxy[887]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:50 myuser xembedsniproxy[891]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:50 myuser plasmashell[825]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 27 12:33:50 myuser plasmashell[825]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 27 12:33:50 myuser kconf_update[927]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Aug 27 12:33:50 myuser kconf_update[927]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Aug 27 12:33:50 myuser kconf_update[927]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Aug 27 12:33:50 myuser kconf_update[927]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Aug 27 12:33:50 myuser kconf_update[927]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Aug 27 12:33:50 myuser kconf_update[927]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Aug 27 12:33:50 myuser kded6[777]: kf.coreaddons: "Could not load plugin from /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so: libgps.so.30: cannot open shared object file: No such file or directory"
Aug 27 12:33:50 myuser polkit-kde-authentication-agent-1[888]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:50 myuser kded6[777]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Aug 27 12:33:50 myuser bluetoothd[504]: Failed to set mode: Failed (0x03)
Aug 27 12:33:50 myuser kded6[777]: kf.bluezqt: PendingCall Error: "Failed"
Aug 27 12:33:50 myuser xdg-desktop-por[740]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Aug 27 12:33:50 myuser xdg-desktop-por[740]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Aug 27 12:33:50 myuser kded6[777]: kscreen.kded: PowerDevil SuspendSession action not available!
Aug 27 12:33:50 myuser plasmashell[825]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 27 12:33:50 myuser org_kde_powerdevil[889]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Aug 27 12:33:51 myuser kdeconnectd[1043]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Aug 27 12:33:51 myuser kdeconnectd[1043]: 2024-08-27T12:33:51 default: Error sending UDP packet: QAbstractSocket::NetworkError
Aug 27 12:33:51 myuser kdeconnectd[1043]: 2024-08-27T12:33:51 kdeconnect.core: Failed to open any MDNS client sockets
Aug 27 12:33:51 myuser kdeconnectd[1043]: 2024-08-27T12:33:51 kdeconnect.core: Failed to open any MDNS server sockets
Aug 27 12:33:51 myuser msm_kde_notifier[1039]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser pamac-tray-plasma[1071]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser bluetoothd[504]: Failed to set mode: Failed (0x03)
Aug 27 12:33:51 myuser kded6[777]: kf.bluezqt: PendingCall Error: "Failed"
Aug 27 12:33:51 myuser ksystemstats[953]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Aug 27 12:33:51 myuser kded6[777]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Aug 27 12:33:51 myuser kalendarac[1065]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser plasmashell[1184]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser pulseaudio[1096]: Failed to open connection to session manager: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser pulseaudio[1096]: Failed to load module "module-x11-xsmp" (argument: "display=:0 xauthority=/tmp/xauth_sUCVzH session_manager=local/myuser:@/tmp/.ICE-unix/775,unix/myuser:/tmp/.ICE-unix/775"): initialization failed.
Aug 27 12:33:51 myuser systemd[661]: app-pulseaudio@autostart.service: Failed with result 'exit-code'.
Aug 27 12:33:51 myuser akonadi_control[1213]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:33:51 myuser akonadi_control[1213]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 27 12:33:51 myuser plasmashell[825]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Aug 27 12:33:51 myuser plasmashell[825]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Aug 27 12:33:52 myuser plasmashell[825]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Aug 27 12:33:52 myuser plasmashell[825]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1724754832339: Unsupported image format
Aug 27 12:33:52 myuser plasmashell[825]: file:///usr/lib/qt6/qml/org/kde/plasma/workspace/calendar/MonthViewHeader.qml:50:26: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Aug 27 12:33:52 myuser dbus-broker-launch[500]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Aug 27 12:33:52 myuser plasmashell[825]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 27 12:33:52 myuser kdeconnectd[1043]: 2024-08-27T12:33:52 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
Aug 27 12:33:52 myuser akonadiserver[1244]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 27 12:34:00 myuser manjaro-settings-manager[1630]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:34:12 myuser manjaro-settings-manager[1630]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
Aug 27 12:35:05 myuser konsole[16165]: Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
Aug 27 12:35:07 myuser sddm-helper[655]: Signal received: SIGTERM
Aug 27 12:35:07 myuser sddm[570]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Aug 27 12:35:07 myuser sddm[570]: Auth: sddm-helper (--socket /tmp/sddm-auth-e4bba59e-6fdf-479d-8d2b-1da38fc453fe --id 1 --start /usr/bin/startplasma-x11 --user rick) crashed (exit code 1)
Aug 27 12:35:07 myuser sddm[570]: Auth: sddm-helper exited with 1
Aug 27 12:35:07 myuser sddm[570]: Signal received: SIGTERM
Aug 27 12:35:07 myuser kglobalacceld[731]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser ksmserver[775]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser plasmashell[825]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser kglobalacceld[731]: The X11 connection broke: I/O error (code 1)
Aug 27 12:35:07 myuser kwin_x11[778]: The X11 connection broke: I/O error (code 1)
Aug 27 12:35:07 myuser kactivitymanagerd[886]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser xembedsniproxy[891]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser xdg-desktop-portal-kde[890]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser gmenudbusmenuproxy[887]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser polkit-kde-authentication-agent-1[888]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser org_kde_powerdevil[889]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser kalendarac[1065]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser kaccess[1063]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_newmailnotifier_agent[1335]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_contacts_resource[1323]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_maildispatcher_agent[1331]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_indexing_agent[1328]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_mailmerge_agent[1333]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser kscreen_backend_launcher[981]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser kdeconnectd[1043]: 2024-08-27T12:35:07 default: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser msm_kde_notifier[1039]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_followupreminder_agent[1324]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_migration_agent[1334]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_maildir_resource[1329]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser konsole[16165]: The X11 connection broke: I/O error (code 1)
Aug 27 12:35:07 myuser akonadi_control[1213]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser pamac-tray-plasma[1071]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_akonotes_resource[1320]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_birthdays_resource[1322]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_unifiedmailbox_agent[1341]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser manjaro-settings-manager[1630]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_mailfilter_agent[1332]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_imap_resource[1327]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_sendlater_agent[1340]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser systemd[661]: plasma-ksmserver.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser akonadi_archivemail_agent[1321]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser akonadi_ical_resource[1325]: The X11 connection broke (error 1). Did the X11 server die?
Aug 27 12:35:07 myuser systemd[661]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: plasma-kscreen.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: app-kaccess@autostart.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser pulseaudio[1096]: X11 I/O error handler called
Aug 27 12:35:07 myuser pulseaudio[1096]: X11 I/O error exit handler called, preparing to tear down X11 modules
Aug 27 12:35:07 myuser kded6[777]: The X11 connection broke: I/O error (code 1)
Aug 27 12:35:07 myuser kded6[777]: kf.notifications: Playing audio notification failed: Destroyed
Aug 27 12:35:07 myuser systemd[661]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: app-manjaro\x2dsettings\x2dmanager@588c16eae07746169f29a0a66afb9e2e.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: plasma-powerdevil.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser dbus-broker-launch[500]: Activation request for 'org.bluez' failed.
Aug 27 12:35:07 myuser pulseaudio[1096]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NameHasNoOwner:Could not activate remote peer 'org.bluez': activation request failed: unit is invalid
Aug 27 12:35:07 myuser systemd[661]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser pulseaudio[1096]: Error opening PCM device front:1: No such file or directory
Aug 27 12:35:07 myuser systemd[661]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: plasma-kded6.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: app-org.kde.konsole@1a0dfc1687b9495097bf3dcf0a597444.service: Failed with result 'exit-code'.
Aug 27 12:35:07 myuser systemd[661]: plasma-plasmashell.service: Failed with result 'exit-code'.
Aug 27 12:35:09 myuser dbus-broker-launch[500]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 27 12:35:09 myuser NetworkManager[502]: <warn>  [1724754909.0731] dispatcher: (11) failed (after 0.002 sec): Could not activate remote peer 'org.freedesktop.nm_dispatcher': activation request failed: unit is invalid
Aug 27 12:35:09 myuser kernel: watchdog: watchdog0: watchdog did not stop!
thanks for all the help
You could in fact I think you should, try kernel version 6.6, which is the latest LTS or 6.1, which is the latest SLTS.
The latest is only recommended if it contains a specific feature you require.
Edit:
Also, is there a specific reason you use the real-time kernel?
I had big issues with kernels below 6.6.5 (included, if i remember well), such that i couldn’t use my laptop’s keyboard and mousepad and i was forced to use external ones, so i’m trying to stick with the latest ones (where this bug is fixed) to avoid this issue (as far as i know this bug occurs only with my particular laptop model).
Also there is no particular reason, as far as i know, for which i should run a real-time kernel. I’ve been using it for some hours now, and i’m not having any issues, but at the same time i’m not really keen into switching kernel again at the moment (you can imagine why :D).
Did you notice anything that could give some hints on why i’m experiencing these sudden reboots in the logs i posted previously?
Ah, I understand yes.
Although, seeing as you can have multiple kernels installed, you can always install 6.1, boot into it to test, and if it doesn’t work reboot back into your current one. The fix might have been back-ported to the others, especially 6.1, since it is to be maintained for a looong time still.
More information on the kernel installation here:
Unfortunately no, I haven’t.
I’ll most definitely try!
Thank you guys for being so helpful :wink:
You might benefit from configuring some swap space:
A realtime kernel is used only in rare cases where they are actually needed – occasionally in professional audio production, for example, and even then, rarely – I suggest using the standard 6.9.x kernel on a typical desktop/laptop machine.
If i read your system info right, you are currently using X11
Since you have AMD GPU, you may want to try out Wayland.
Edit:
Do you experience sudden reboots in combination with demanding task?
In relation to a temp problem maybe?
Of course, the chances are low that this is really the case for you… because when your other Kernels running fine (besides input problems), it shouldn’t make sense right?
But who knows… the newer Kernel could do some optimisation around your system, that your CPU gain the chance for a higher possible workload… could be in relation for higher temps or more needed Vcore.
Of course, this advanced stuff should be only seen as option, when there is not a better solution.
Only one issue with that:
It does currently still show up with the mhwd command, though. :wink:
Also, this:
sensors should tell, probably need to install lm-sensors first.
I mean he posted some sensor data in his main topic… but idk if this was while idling or if he was watching a youtube stream for example then it would be okayish.
For only browsing (idle) temps this looks a little bid to warm… a normal idle system should have 35° from my experience.
Mine is currently:
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +49.0 C  (high = +100.0 C, crit = +100.0 C)
Core 0:        +46.0 C  (high = +100.0 C, crit = +100.0 C)
Core 1:        +45.0 C  (high = +100.0 C, crit = +100.0 C)
BAT1-acpi-0
Adapter: ACPI interface
in0:          12.37 V
thinkpad-isa-0000
fan1:        2479 RPM
CPU:          +49.0 C
… but it’s a laptop, on the quilt next to me so not all that well ventilated.
uff and your fan has really 2480 RPM right now and your system is doing nothing besides Firefox Forum usage?
How hot is your Room?
Currently a comparatively cool 26.6°C; it’s usually in the 30s. I’ve had it exceed 50°C a few times.
I have one of those laptop “tables” with cushion on the underside for use on a lap, which I’d largely forgotten about; suppose I ought to dust it off and start using it again.
There’s also some other programs open on other desktops, which might have some effect.
If this are your idle temps, you better don’t do Video Encoding with that device :hot_face:
2450 RPM should be really noisy. Maybe you have soon sudden reboots too :rofl:
I actually can’t hear it running. It only kicks in from time to time. I’d probably do stuff like video encoding down the Pub anyway, on a table. Although :cat2: isn’t distracting me, for a change!
Addendum: I just moved the machine over a bit and the fan stopped, temps staying about the same. Was probably blocking an inlet.
What I’d suggest to the OP is to have a Terminal open showing temps e.g.
watch -n5 sensors
Years back, I would have issues with an old Dell machine overheating just when messing with xscreensaver! New thermal paste helped, but it still ran hot.
The maximum TDP of the AMD Ryzen 3 7320U is 15 watts, but this can be reduced to 8 watts by the hardware manufacturer. The maximum operating temperature before the processor automatically clocks down is 100 degrees Celsius.
It’s AMD. You can cook on those things.
As mentioned, the EOL and real-time kernel are definitely the things that stand out. My Manjaro installs (using Nvidia GPUs) didn’t even boot the update that made 6.9 EOL.
TDP is same as mine (an Intel® Core™ i5-4300U). It rarely gets much above ambient plus 20-30°C with (for me) normal use.
Most of the time, Intel CPUs run a lot cooler.
My Ryzen 9 5950X will operate at about 91C under load. (And that’s after I did many things to help keep it cooler.)
Indeed. This is mine, taken just now as I sit here:
$ sensors
coretemp-isa-0000
Package id 0:  +25.0°C  (high = +82.0°C, crit = +100.0°C)
Core 0:        +25.0°C  (high = +82.0°C, crit = +100.0°C)
Core 1:        +23.0°C  (high = +82.0°C, crit = +100.0°C)
Core 2:        +24.0°C  (high = +82.0°C, crit = +100.0°C)
Core 3:        +24.0°C  (high = +82.0°C, crit = +100.0°C)
Core 4:        +25.0°C  (high = +82.0°C, crit = +100.0°C)
Core 5:        +24.0°C  (high = +82.0°C, crit = +100.0°C)
acpitz-acpi-0
temp1:        +16.8°C  (crit = +20.8°C)
temp2:        +27.8°C  (crit = +119.0°C)
temp3:        +29.8°C  (crit = +119.0°C)
nvme-pci-0900
Adapter: PCI adapter
Composite:    +24.9°C  (low  = -273.1°C, high = +76.8°C)
                       (crit = +78.8°C)
Sensor 1:     +24.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +29.9°C  (low  = -273.1°C, high = +65261.8°C)
Granted, my PC was just switched on, but by this afternoon CPU temperatures will be ±30°C - 32°C, and GPU ±34°C - 36°C.
