Hi folks, I’m having some trouble with hybrid-sleep, and wondered if anyone here could help.
All other functions of my laptop are working just great, including both standard sleep and standard hibernate, but I can’t make hybrid-sleep work. It enters the mode just fine, but upon trying to boot the laptop back up again, it simply lands on a black screen with fans running very rapidly. No ttys work - it’s not just a process appearing over the top of X. I’m using a Dell Inspiron 5401 laptop.
I’ve read Manjaro KDE multiple problem encountered after installing with Dell Inspiron. I7 16GB ram - Newbie Corner - Manjaro Linux Forum and How to Choose the Proper ACPI Kernel Argument, but changing the ACPI kernel arguments doesn’t seem to be helping. I also don’t see any ACPI errors in Grub’s (non-quiet) boot output.
Here’s a copy of the journalctl log, starting just before the suspend, and ending when I finally held the power button to turn it off:
-- Logs begin at Thu 2020-09-10 12:56:16 BST, end at Thu 2020-10-08 12:39:30 BST. --
Oct 08 12:30:03 curtis-laptop polkitd[863]: Registered Authentication Agent for unix-process:3453:39016 (system bus name :1.212 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Oct 08 12:30:03 curtis-laptop kded5[1387]: bluedevil: About to suspend
Oct 08 12:30:03 curtis-laptop ModemManager[909]: <info> [sleep-monitor] system is about to suspend
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.6700] manager: sleep: sleep requested (sleeping: no enabled: yes)
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.6702] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.6705] manager: NetworkManager state is now ASLEEP
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.6706] device (wlp2s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 12:30:03 curtis-laptop kded5[1387]: plasma-nm: Unhandled active connection state change: 3
Oct 08 12:30:03 curtis-laptop dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=860 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 08 12:30:03 curtis-laptop dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=860 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 08 12:30:03 curtis-laptop dbus-daemon[859]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Oct 08 12:30:03 curtis-laptop systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 08 12:30:03 curtis-laptop polkitd[863]: Unregistered Authentication Agent for unix-process:3453:39016 (system bus name :1.212, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
Oct 08 12:30:03 curtis-laptop org_kde_powerdevil[1576]: powerdevil: Pausing all media players before sleep
Oct 08 12:30:03 curtis-laptop dbus-daemon[859]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 08 12:30:03 curtis-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:03 curtis-laptop systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 08 12:30:03 curtis-laptop kernel: audit: type=1130 audit(1602156603.677:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:03 curtis-laptop kernel: wlp2s0: deauthenticating from 10:05:ca:ba:18:9f by local choice (Reason: 3=DEAUTH_LEAVING)
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=10:05:ca:ba:18:9f reason=3 locally_generated=1
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.6923] device (wlp2s0): supplicant interface state: completed -> disconnected
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.6925] device (wlp2s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Withdrawing address record for fe80::cd1a:1c44:bbae:6a04 on wlp2s0.
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::cd1a:1c44:bbae:6a04.
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7128] dhcp4 (wlp2s0): canceled DHCP transaction
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7128] dhcp4 (wlp2s0): state changed bound -> done
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7131] dhcp6 (wlp2s0): canceled DHCP transaction
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7131] dhcp6 (wlp2s0): state changed timeout -> done
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 10.14.196.211.
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Withdrawing address record for 10.14.196.211 on wlp2s0.
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7139] device (wlp2s0): set-hw-addr: set MAC address to 36:32:DD:28:3A:13 (scanning)
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:ba:18:9f 0
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:b4:8c:90 0
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:b4:8c:70 0
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:e7:d7:1f 0
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:ba:18:90 0
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:d0:14:9f 0
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-REMOVED 10:05:ca:b4:8c:7f 0
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 10.14.196.211.
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: New relevant interface wlp2s0.IPv4 for mDNS.
Oct 08 12:30:03 curtis-laptop avahi-daemon[857]: Registering new address record for 10.14.196.211 on wlp2s0.IPv4.
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7229] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7230] device (wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 12:30:03 curtis-laptop NetworkManager[860]: <info> [1602156603.7234] device (wlp2s0): set-hw-addr: reset MAC address to 28:CD:C4:C6:36:A7 (unmanage)
Oct 08 12:30:03 curtis-laptop kded5[1387]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
Oct 08 12:30:03 curtis-laptop kscreenlocker_greet[3461]: Qt: Session management error: networkIdsList argument is NULL
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Oct 08 12:30:03 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 08 12:30:03 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:76:9: Unable to assign [undefined] to QStringList
Oct 08 12:30:03 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75:9: Unable to assign [undefined] to int
Oct 08 12:30:03 curtis-laptop wpa_supplicant[1069]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Oct 08 12:30:03 curtis-laptop systemd[1]: Reached target Sleep.
Oct 08 12:30:03 curtis-laptop systemd[1]: Starting Hybrid Suspend+Hibernate...
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: UdevQt: unable to create udev monitor connection
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/MainBlock.qml:88:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 08 12:30:04 curtis-laptop systemd-sleep[3477]: Suspending system...
Oct 08 12:30:04 curtis-laptop kernel: PM: hibernation entry
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:64:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/SessionManagementScreen.qml:64:5: Unable to assign [undefined] to int
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/ActionButton.qml:33:5: Unable to assign [undefined] to int
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/KeyboardLayoutButton.qml:29:5: Unable to assign [undefined] to int
Oct 08 12:30:04 curtis-laptop kscreenlocker_greet[3461]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/Battery.qml:48:9: Unable to assign [undefined] to double
Oct 08 12:30:04 curtis-laptop org_kde_powerdevil[1576]: powerdevil: ACTIVE SESSION PATH CHANGED: "/"
Oct 08 12:30:04 curtis-laptop org_kde_powerdevil[1576]: powerdevil: Switched to inactive session - leaving unchanged
Oct 08 12:30:31 curtis-laptop kernel: Filesystems sync: 0.008 seconds
Oct 08 12:30:31 curtis-laptop kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
Oct 08 12:30:31 curtis-laptop kernel: OOM killer disabled.
Oct 08 12:30:31 curtis-laptop kernel: PM: Marking nosave pages: [mem 0x00000000-0x00000fff]
Oct 08 12:30:31 curtis-laptop kernel: PM: Marking nosave pages: [mem 0x0009f000-0x000fffff]
Oct 08 12:30:31 curtis-laptop kernel: PM: Marking nosave pages: [mem 0x4c030000-0x4c031fff]
Oct 08 12:30:31 curtis-laptop kernel: PM: Marking nosave pages: [mem 0x5f91f000-0x5f9a7fff]
Oct 08 12:30:31 curtis-laptop kernel: PM: Marking nosave pages: [mem 0x61fc8000-0x63ffefff]
Oct 08 12:30:31 curtis-laptop kernel: PM: Marking nosave pages: [mem 0x64000000-0xffffffff]
Oct 08 12:30:31 curtis-laptop kernel: PM: Basic memory bitmaps created
Oct 08 12:30:31 curtis-laptop kernel: PM: Preallocating image memory... done (allocated 715311 pages)
Oct 08 12:30:31 curtis-laptop kernel: PM: Allocated 2861244 kbytes in 0.99 seconds (2890.14 MB/s)
Oct 08 12:30:31 curtis-laptop kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Oct 08 12:30:31 curtis-laptop kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Oct 08 12:30:31 curtis-laptop kernel: ACPI: EC: interrupt blocked
Oct 08 12:30:31 curtis-laptop kernel: Disabling non-boot CPUs ...
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 1 is now offline
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 2 is now offline
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 3 is now offline
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 4 is now offline
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 5 is now offline
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 6 is now offline
Oct 08 12:30:31 curtis-laptop kernel: smpboot: CPU 7 is now offline
Oct 08 12:30:31 curtis-laptop kernel: PM: Creating hibernation image:
Oct 08 12:30:31 curtis-laptop kernel: PM: Need to copy 702472 pages
Oct 08 12:30:31 curtis-laptop kernel: PM: Normal pages needed: 702472 + 1024, available pages: 1334807
Oct 08 12:30:31 curtis-laptop kernel: PM: Hibernation image created (702472 pages copied)
Oct 08 12:30:31 curtis-laptop kernel: Enabling non-boot CPUs ...
Oct 08 12:30:31 curtis-laptop kernel: x86: Booting SMP configuration:
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Oct 08 12:30:31 curtis-laptop kernel: CPU1 is up
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Oct 08 12:30:31 curtis-laptop kernel: CPU2 is up
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Oct 08 12:30:31 curtis-laptop kernel: CPU3 is up
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
Oct 08 12:30:31 curtis-laptop kernel: CPU4 is up
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
Oct 08 12:30:31 curtis-laptop kernel: CPU5 is up
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
Oct 08 12:30:31 curtis-laptop kernel: CPU6 is up
Oct 08 12:30:31 curtis-laptop kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Oct 08 12:30:31 curtis-laptop kernel: CPU7 is up
Oct 08 12:30:31 curtis-laptop kernel: ACPI: EC: interrupt unblocked
Oct 08 12:30:31 curtis-laptop kernel: ath10k_pci 0000:02:00.0: unsupported HTC service id: 1536
Oct 08 12:30:31 curtis-laptop kernel: nvme nvme0: 8/0/0 default/read/poll queues
Oct 08 12:30:31 curtis-laptop kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Oct 08 12:30:31 curtis-laptop kernel: PM: Using 3 thread(s) for compression
Oct 08 12:30:31 curtis-laptop kernel: PM: Compressing and saving image data (703845 pages)...
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 0%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 10%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 20%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 30%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 40%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 50%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 60%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 70%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 80%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 90%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving progress: 100%
Oct 08 12:30:31 curtis-laptop kernel: PM: Image saving done
Oct 08 12:30:31 curtis-laptop kernel: PM: Wrote 2815380 kbytes in 2.40 seconds (1173.07 MB/s)
Oct 08 12:30:31 curtis-laptop kernel: PM: S|
Oct 08 12:30:31 curtis-laptop kernel: ACPI: Preparing to enter system sleep state S3
Oct 08 12:30:31 curtis-laptop kernel: ACPI: EC: event blocked
Oct 08 12:30:31 curtis-laptop kernel: ACPI: EC: EC stopped
Oct 08 12:30:31 curtis-laptop kernel: PM: Saving platform NVS memory
Oct 08 12:30:31 curtis-laptop kernel: ACPI: Low-level resume complete
Oct 08 12:30:31 curtis-laptop kernel: ACPI: EC: EC started
Oct 08 12:30:31 curtis-laptop kernel: PM: Restoring platform NVS memory
Oct 08 12:30:31 curtis-laptop kernel: ACPI: Waking up from system sleep state S3
Oct 08 12:30:31 curtis-laptop kernel: ACPI: EC: event unblocked
Oct 08 12:30:31 curtis-laptop kernel: usb 3-6: reset high-speed USB device number 3 using xhci_hcd
Oct 08 12:30:31 curtis-laptop kernel: acpi LNXPOWER:08: Turning OFF
Oct 08 12:30:31 curtis-laptop kernel: acpi LNXPOWER:07: Turning OFF
Oct 08 12:30:31 curtis-laptop kernel: acpi LNXPOWER:06: Turning OFF
Oct 08 12:30:31 curtis-laptop kernel: acpi LNXPOWER:02: Turning OFF
Oct 08 12:30:31 curtis-laptop kernel: acpi LNXPOWER:01: Turning OFF
Oct 08 12:30:31 curtis-laptop kernel: PM: Basic memory bitmaps freed
Oct 08 12:30:31 curtis-laptop kernel: OOM killer enabled.
Oct 08 12:30:31 curtis-laptop kernel: Restarting tasks ... done.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: The canary thread is apparently starving. Taking action.
Oct 08 12:30:31 curtis-laptop pipewire[1759]: [W][000000397.471825][main-loop.c:157 pw_main_loop_run()] main-loop 0x55a1891b70c0: iterate error -4 (Interrupted system call)
Oct 08 12:30:31 curtis-laptop systemd-logind[865]: Power key pressed.
Oct 08 12:30:31 curtis-laptop kernel: PM: hibernation exit
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Demoting known real-time threads.
Oct 08 12:30:31 curtis-laptop pipewire[1761]: [W][000000397.471938][main-loop.c:157 pw_main_loop_run()] main-loop 0x560d16d69e30: iterate error -4 (Interrupted system call)
Oct 08 12:30:31 curtis-laptop systemd-sleep[3477]: System resumed.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Successfully demoted thread 1869 of process 1513.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Successfully demoted thread 1760 of process 1759.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Successfully demoted thread 1623 of process 1483.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Successfully demoted thread 1614 of process 1483.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Successfully demoted thread 1483 of process 1483.
Oct 08 12:30:31 curtis-laptop rtkit-daemon[1522]: Demoted 5 threads.
Oct 08 12:30:31 curtis-laptop kernel: ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
Oct 08 12:30:31 curtis-laptop org_kde_powerdevil[1576]: powerdevil: ACTIVE SESSION PATH CHANGED: "/org/freedesktop/login1/session/_32"
Oct 08 12:30:31 curtis-laptop org_kde_powerdevil[1576]: powerdevil: Current session is now active
Oct 08 12:30:31 curtis-laptop systemd[1]: systemd-hybrid-sleep.service: Succeeded.
Oct 08 12:30:31 curtis-laptop systemd[1]: Finished Hybrid Suspend+Hibernate.
Oct 08 12:30:31 curtis-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:31 curtis-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:31 curtis-laptop systemd[1]: Reached target Hybrid Suspend+Hibernate.
Oct 08 12:30:31 curtis-laptop systemd[1]: Stopped target Sleep.
Oct 08 12:30:31 curtis-laptop systemd[1]: Stopped target Hybrid Suspend+Hibernate.
Oct 08 12:30:31 curtis-laptop systemd-logind[865]: Operation 'sleep' finished.
Oct 08 12:30:31 curtis-laptop kernel: audit: type=1130 audit(1602156631.290:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:31 curtis-laptop kernel: audit: type=1131 audit(1602156631.290:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.2968] manager: sleep: wake requested (sleeping: yes enabled: yes)
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.2969] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.2986] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Oct 08 12:30:31 curtis-laptop ModemManager[909]: <info> [sleep-monitor] system is resuming
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.2989] manager: NetworkManager state is now DISCONNECTED
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3463] device (wlp2s0): supplicant interface state: internal-starting -> disconnected
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3463] device (p2p-dev-wlp2s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3468] Wi-Fi P2P device controlled by interface wlp2s0 created
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3470] manager: (p2p-dev-wlp2s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3472] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3476] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <info> [1602156631.3481] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:31 curtis-laptop NetworkManager[860]: <warn> [1602156631.3507] sup-iface[dadbc4b87772b491,1,wlp2s0]: call-p2p-cancel: failed with P2P cancel failed
Oct 08 12:30:32 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Oct 08 12:30:33 curtis-laptop systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Oct 08 12:30:33 curtis-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:33 curtis-laptop kernel: audit: type=1131 audit(1602156633.490:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:33 curtis-laptop ModemManager[909]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.6/0000:02:00.0': not supported by any plugin
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9014] policy: auto-activating connection 'eduroam' (ac7a83c7-d085-41e5-93f2-f0db8ed15737)
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9018] device (wlp2s0): Activation: starting connection 'eduroam' (ac7a83c7-d085-41e5-93f2-f0db8ed15737)
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9019] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9021] manager: NetworkManager state is now CONNECTING
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9023] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9025] device (wlp2s0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9025] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9044] device (wlp2s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9047] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9049] device (wlp2s0): Activation: (wifi) connection 'eduroam' has security, and secrets exist. No new secrets needed.
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9049] Config: added 'ssid' value 'eduroam'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9049] Config: added 'scan_ssid' value '1'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9049] Config: added 'bgscan' value 'simple:30:-65:300'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9050] Config: added 'key_mgmt' value 'WPA-EAP WPA-EAP-SHA256 FT-EAP FT-EAP-SHA384'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9050] Config: added 'password' value '<hidden>'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9050] Config: added 'eap' value 'PEAP'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9050] Config: added 'fragment_size' value '1266'
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9050] Config: added 'phase2' value 'auth=MSCHAPV2'
[NM lines removed]
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9050] Config: added 'proactive_key_caching' value '1'
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: SME: Trying to authenticate with 10:05:ca:ba:18:9f (SSID='eduroam' freq=5500 MHz)
Oct 08 12:30:45 curtis-laptop kernel: wlp2s0: authenticate with 10:05:ca:ba:18:9f
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9608] device (wlp2s0): supplicant interface state: disconnected -> authenticating
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9608] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> authenticating
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: Trying to associate with 10:05:ca:ba:18:9f (SSID='eduroam' freq=5500 MHz)
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9620] device (wlp2s0): supplicant interface state: authenticating -> associating
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9620] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Oct 08 12:30:45 curtis-laptop kernel: wlp2s0: send auth to 10:05:ca:ba:18:9f (try 1/3)
Oct 08 12:30:45 curtis-laptop kernel: wlp2s0: authenticated
Oct 08 12:30:45 curtis-laptop kernel: wlp2s0: associate with 10:05:ca:ba:18:9f (try 1/3)
Oct 08 12:30:45 curtis-laptop kernel: wlp2s0: RX AssocResp from 10:05:ca:ba:18:9f (capab=0x1111 status=0 aid=39)
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: Associated with 10:05:ca:ba:18:9f
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-EAP-STARTED EAP authentication started
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=GB
Oct 08 12:30:45 curtis-laptop kernel: wlp2s0: associated
Oct 08 12:30:45 curtis-laptop kernel: ath: EEPROM regdomain: 0x833a
Oct 08 12:30:45 curtis-laptop kernel: ath: EEPROM indicates we should expect a country code
Oct 08 12:30:45 curtis-laptop kernel: ath: doing EEPROM country->regdmn map search
Oct 08 12:30:45 curtis-laptop kernel: ath: country maps to regdmn code: 0x37
Oct 08 12:30:45 curtis-laptop kernel: ath: Country alpha2 being used: GB
Oct 08 12:30:45 curtis-laptop kernel: ath: Regpair used: 0x37
Oct 08 12:30:45 curtis-laptop kernel: ath: regdomain 0x833a dynamically updated by country element
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=25
Oct 08 12:30:45 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-EAP-METHOD EAP vendor 0 method 25 (PEAP) selected
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9759] device (wlp2s0): supplicant interface state: associating -> associated
Oct 08 12:30:45 curtis-laptop NetworkManager[860]: <info> [1602156645.9759] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> associated
[NM lines removed]
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: EAP-MSCHAPV2: Authentication succeeded
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: EAP-TLV: TLV Result - Success - EAP-TLV/Phase2 Completed
Oct 08 12:30:46 curtis-laptop kernel: wlp2s0: Limiting TX power to 17 dBm as advertised by 10:05:ca:ba:18:9f
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-EAP-SUCCESS EAP authentication completed successfully
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: wlp2s0: PMKSA-CACHE-ADDED 10:05:ca:ba:18:9f 0
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: wlp2s0: WPA: Key negotiation completed with 10:05:ca:ba:18:9f [PTK=CCMP GTK=CCMP]
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 10:05:ca:ba:18:9f completed [id=0 id_str=]
Oct 08 12:30:46 curtis-laptop kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
Oct 08 12:30:46 curtis-laptop NetworkManager[860]: <info> [1602156646.0816] device (wlp2s0): supplicant interface state: associated -> completed
Oct 08 12:30:46 curtis-laptop NetworkManager[860]: <info> [1602156646.0816] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "eduroam"
Oct 08 12:30:46 curtis-laptop NetworkManager[860]: <info> [1602156646.0816] device (p2p-dev-wlp2s0): supplicant management interface state: associated -> completed
Oct 08 12:30:46 curtis-laptop NetworkManager[860]: <info> [1602156646.0817] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:46 curtis-laptop NetworkManager[860]: <info> [1602156646.0819] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Oct 08 12:30:46 curtis-laptop kernel: EXT4-fs error (device dm-0): ext4_lookup:1703: inode #263401: comm NetworkManager: deleted inode referenced: 262425
Oct 08 12:30:46 curtis-laptop avahi-daemon[857]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::cd1a:1c44:bbae:6a04.
Oct 08 12:30:46 curtis-laptop avahi-daemon[857]: New relevant interface wlp2s0.IPv6 for mDNS.
Oct 08 12:30:46 curtis-laptop avahi-daemon[857]: Registering new address record for fe80::cd1a:1c44:bbae:6a04 on wlp2s0.*.
Oct 08 12:30:46 curtis-laptop wpa_supplicant[1069]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-65 noise=-98 txrate=6000
Oct 08 12:30:47 curtis-laptop kernel: EXT4-fs error (device dm-0): ext4_lookup:1703: inode #263401: comm NetworkManager: deleted inode referenced: 262425
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <warn> [1602156647.1089] dhcp4 (wlp2s0): error saving lease to /var/lib/NetworkManager/internal-ac7a83c7-d085-41e5-93f2-f0db8ed15737-wlp2s0.lease: Failed to rename file “/var/lib/NetworkManager/internal-ac7a83c7-d085-41e5-93f2-f0db8ed15737-wlp2s0.lease.G6Q6R0” to “/var/lib/NetworkManager/internal-ac7a83c7-d085-41e5-93f2-f0db8ed15737-wlp2s0.lease”: g_rename() failed: Structure needs cleaning
Oct 08 12:30:47 curtis-laptop avahi-daemon[857]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 10.14.196.211.
[NM lines removed]
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option expiry => '1602160246'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option ip_address => '10.14.196.211'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_broadcast_address => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_domain_name => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_domain_name_servers => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_domain_search => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_host_name => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_interface_mtu => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_ms_classless_static_routes => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1090] dhcp4 (wlp2s0): option requested_nis_domain => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_nis_servers => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_ntp_servers => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_rfc3442_classless_static_routes => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_root_path => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_routers => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_static_routes => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_subnet_mask => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_time_offset => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option requested_wpad => '1'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option routers => '10.14.199.254'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): option subnet_mask => '255.255.252.0'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1091] dhcp4 (wlp2s0): state changed unknown -> bound
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1101] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:47 curtis-laptop systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 08 12:30:47 curtis-laptop dbus-daemon[859]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 08 12:30:47 curtis-laptop systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 08 12:30:47 curtis-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop kernel: audit: type=1130 audit(1602156647.120:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1277] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1279] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1282] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1296] manager: NetworkManager state is now CONNECTED_SITE
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1297] policy: set 'eduroam' (wlp2s0) as default for IPv4 routing and DNS
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.1298] device (wlp2s0): Activation: successful, device activated.
Oct 08 12:30:47 curtis-laptop dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=860 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 08 12:30:47 curtis-laptop dbus-daemon[859]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.2101] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 08 12:30:47 curtis-laptop NetworkManager[860]: <info> [1602156647.3498] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Oct 08 12:30:47 curtis-laptop dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.236' (uid=0 pid=3878 comm="/usr/bin/sudo -n /usr/bin/iwlist wlp2s0 scan " label="unconfined")
Oct 08 12:30:47 curtis-laptop dbus-daemon[859]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 08 12:30:47 curtis-laptop sudo[3878]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 08 12:30:47 curtis-laptop audit[3878]: USER_ACCT pid=3878 uid=965 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="prey" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop sudo[3878]: prey : TTY=unknown ; PWD=/opt/prey-node-client ; USER=root ; COMMAND=/usr/bin/iwlist wlp2s0 scan
Oct 08 12:30:47 curtis-laptop audit[3878]: CRED_REFR pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop kernel: audit: type=1101 audit(1602156647.506:138): pid=3878 uid=965 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="prey" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop kernel: audit: type=1110 audit(1602156647.506:139): pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop sudo[3878]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Oct 08 12:30:47 curtis-laptop audit[3878]: USER_START pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:47 curtis-laptop kernel: audit: type=1105 audit(1602156647.510:140): pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:49 curtis-laptop dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=860 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 08 12:30:49 curtis-laptop dbus-daemon[859]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Oct 08 12:30:51 curtis-laptop systemd-timesyncd[639]: Initial synchronization to time server 178.62.250.107:123 (3.manjaro.pool.ntp.org).
Oct 08 12:30:53 curtis-laptop dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=860 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 08 12:30:53 curtis-laptop dbus-daemon[859]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Oct 08 12:30:55 curtis-laptop sudo[3878]: pam_unix(sudo:session): session closed for user root
Oct 08 12:30:55 curtis-laptop audit[3878]: USER_END pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:55 curtis-laptop audit[3878]: CRED_DISP pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:55 curtis-laptop kernel: audit: type=1106 audit(1602156655.417:141): pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
Oct 08 12:30:55 curtis-laptop kernel: audit: type=1104 audit(1602156655.417:142): pid=3878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
And here’s my inxi output:
System: Host: curtis-laptop Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.19.5
Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Inspiron 14 5401 v: N/A serial: <superuser/root required>
Mobo: Dell model: 03GNVW v: A00 serial: <superuser/root required> UEFI: Dell v: 1.4.3 date: 08/14/2020
Battery: ID-1: BAT0 charge: 37.1 Wh condition: 53.0/53.0 Wh (100%) model: BYD DELL TXD0307 status: Charging
CPU: Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23968
Speed: 1777 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1777 2: 3228 3: 3432 4: 1872 5: 2184 6: 2667 7: 3360
8: 2334
Graphics: Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX330] driver: nvidia v: 450.66 bus ID: 01:00.0
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 3-6:3
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.67-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
port: 3000 bus ID: 02:00.0
IF: wlp2s0 state: up mac: 28:cd:c4:c6:36:a7
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 3-10:4
Drives: Local Storage: total: 476.94 GiB used: 24.57 GiB (5.2%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB
Partition: ID-1: / size: 459.50 GiB used: 24.50 GiB (5.3%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 299.4 MiB used: 69.6 MiB (23.2%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) dev: /dev/dm-1
Sensors: System Temperatures: cpu: 60.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 246 Uptime: 12m Memory: 7.55 GiB used: 2.51 GiB (33.2%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1318 Shell: Bash v: 5.0.18 inxi: 3.1.05
I’m using mhwd’s video-hybrid-intel-nvidia-450xx-prime for Optimus on the laptop, and as I mentioned earlier, have been trying different kernel parameters, in case it was an ACPI issue, but to no avail so far. I’ve tried 'Windows 2020', 'Windows 2019’ and Linux so far. Here’s my current GRUB_CMDLINE_LINUX_DEFAULT:
GRUB_CMDLINE_LINUX_DEFAULT="acpi_osi=! acpi_osi='Windows 2019' acpi_rev_override=1 acpi_backlight=vendor mem_sleep_default=deep quiet cryptdevice=UUID=21ff733c-9741-4616-b5d9-d41496f34322:luks-21ff733c-9741-4616-b5d9-d41496f34322 root=/dev/mapper/luks-21ff733c-9741-4616-b5d9-d41496f34322 apparmor=1 security=apparmor resume=/dev/mapper/luks-cf849d49-e236-4224-a49e-608c47e9387d udev.log_priority=3"
If anyone has any further suggestions, I’d greatly appreciate it! I’m a tad stuck at the moment.
Thanks very much.
