I got a Zbook with Quatro T500 but unfortunately every Arch distro I have tried to install including Manjaro is not working properly.
Most of the times it freezes because of the Graphic Card Issues.
I have tried and install different drivers but no luck. if you have any ideas of what to do let me know.
However I have tried and install MX Linux and everything is working fine smooth and fast.
How comes that MX Linux is working fine and not an arch based distro???
I wanted to install Manjaro but it seems that is impossible …
If you have any ideas or things to try please let me know
@wolfyrion Unfortunately, you didn’t read the information at the link. There is a simple command, which provides common necessary information. In general one need the chipID for example. So I can’t help you here…
This is the command in short form:
inxi -Fazy
The problem is not the hybrid card, but must be the intel (i915) driver (just a guess). I would rather think that a function on the newest drivers does not play well with your intel gpu. A journal log or kernel messages could say more:
# 0 is the current boot and -1 the previous and so on
journalctl --boot 0 --no-pager
sudo dmesg
However… nobody can say anything without information.
Keep in mind, ArchLinux and therefore also Manjaro have bleeding edge software what means that older hardware could need some exceptions to work properly.
