Hey guys I’ve got a 15 inch HP laptop with a Ryzen 5300u and Radeon graphics but when you shut the lid and wake it the screen will either be black or lock up the lock screen or desktop and go back to a black screen. I’ve tried both kernel 5.15 LTS which it came with and kernel 6.0.6 but it’s basically still the same issue
Would you guys like any extra information and is this a known issue?
I think I might of found a fix to the issue and it did have to do with cstate
You will need to add these Kernel flags
open up /etc/default/grub with nano or with whatever text editor as root and add amd_iommu=on iommu=pt processor.max_cstate=5 rcu_nocbs=0_11 in the GRUB_CMDLINE_LINUX_DEFAULT line in the “”
than do sudo update-grub
And that should fix it
I hope this helps everyone on Manjaro running into this issue
