This thread belongs to [HowTo] modulejail
I wrote a small script that adds the desired modules to the modulejail whitelist. It only adds the modules mentioned in the provided journal excerpt.
It avoids duplicate entries and modifies the existing whitelist only by appending the new lines.
Since Java is the only language I know well enough, it is a Java program. However, it can be easily executed (provided Java 25 is installed).
The following text should be saved as “whitelist.java”. last updated 2026-06-11
/// @author andreas kielkopf
/// @throws IOException
/// @date 2026-06-11
/// @license GPL V3
static void main(String[] args_) throws IOException {
System.err.println();
final var whiteListedModules=new ArrayList<String>();
final var whitelistPath=Path.of("/etc/modulejail/whitelist.conf");
if (whitelistPath.toFile().isFile())
for (final String s:Files.readAllLines(whitelistPath, StandardCharsets.UTF_8)) {
System.err.println(s);
if (s.startsWith("#") || s.isBlank())
whiteListedModules.add(s); // Retain comments and blank lines, even if lines are duplicates
if (!whiteListedModules.contains(s))
whiteListedModules.add(s); // Retain existing modules, but filter out duplicates
else
System.err.println(whitelistPath + " was not found");
final var additionalModules=new ArrayList<String>();
additionalModules.add("");
var pattern=Pattern.compile("blocked: (\\w+)");
long timeout=System.currentTimeMillis() + 5000;
while (System.currentTimeMillis() < timeout)
if (System.in.available() > 0 && IO.readln() instanceof final String sl) {
timeout=System.currentTimeMillis() + 1000;
if (sl.contains("modulejail")// modulejail only
&& pattern.matcher(sl) instanceof Matcher m && m.find() // find
&& m.group(1) instanceof String moduleName // extract
&& !additionalModules.contains(moduleName) // Already added
&& !whiteListedModules.contains(moduleName)// Already in the whitelist
&& !whiteListedModules.contains("# " + moduleName) // blacklisted ;-)
additionalModules.add(moduleName);
System.err.println(sl);
} else
Thread.onSpinWait();
for (final String string:additionalModules)
IO.println(string); // Output newly found modules
It can then be executed as follows:
Usage:
List the existing whitelist for modulejail
java whitelist.java
Check which additional modules should be added to the whitelist
last updated 2026-06-12
journalctl -r -t modulejail | java whitelist.java
Append the identified modules to the end of the whitelist (this needs sudo)
journalctl -r -t modulejail | java whitelist.java | sudo tee -a /etc/modulejail/whitelist.conf
After you have updated the whitelist, you can edit it and comment out — using "# " in front of the line — any modules you definitely do not want included; such modules will not be suggested for the whitelist in the future.
After modifying the whitelist, you naturally need to run modulejail again.
sudo modulejail
If there are dependencies between modules, the easiest approach is to repeat the sequence — whitelist, modulejail, reboot — until no further modules are suggested.
