Difficulty: ★★☆☆☆
There are USB sticks and SD cards (and ssd) in circulation that are not of the specified size. Often you only notice this when you have lost data. But there is a way to test it. This is not laborious, but time-consuming!
- Choose one of your USB sticks with USB2 or 3 (A 64GB USB stick is used in the examples below)
- Install the
f3package from the AUR:
pamac install f3
test the USB stick for the real size:
Insert the USB stick and see what kind of device ID it got. The easiest tool to use is: lsblk:
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931,5G 0 disk
├─sda1 8:1 0 953M 0 part /boot/efi
├─sda2 8:2 0 900G 0 part /var/spool
└─sda3 8:3 0 28,1G 0 part
sdb 8:16 0 476,9G 0 disk
├─sdb1 8:17 0 512M 0 part
└─sdb2 8:18 0 476,4G 0 part
sdz 8:32 1 59,5G 0 disk
nvme0n1 259:0 0 1,9T 0 disk
├─nvme0n1p1 259:1 0 1G 0 part
├─nvme0n1p2 259:2 0 1M 0 part
├─nvme0n1p3 259:3 0 900G 0 part
└─nvme0n1p4 259:4 0 1006,7G 0 part
PLEASE check again that /dev/sdz is really your USB stick and not part of your Manjaro system.
- Safely remove the device
- Unplug
- Plug it back in
- Test with
lsblkagain!
The USB stick must have disappeared from the list!
- Unplug
- Plug it back in
- Test with
lsblkagain!
The device should have reappeared. If you are not sure then stop here: If you enter the wrong device with the next command, you will wreck your whole system because you write your disk 100% full !
Those who checked well can now test the USB stick.
sudo f3probe --time-ops /dev/sdz
F3 probe 8.0
Copyright (C) 2010 Digirati Internet LTDA.
This is free software; see the source for copying conditions.
WARNING: Probing normally takes from a few seconds to 15 minutes, but
it can take longer. Please be patient.
Good news: The device `/dev/sdz' is the real thing
Device geometry:
*Usable* size: 59.53 GB (124846080 blocks)
Announced size: 59.53 GB (124846080 blocks)
Module: 64.00 GB (2^36 Bytes)
Approximate cache size: 0.00 Byte (0 blocks), need-reset=no
Physical block size: 512.00 Byte (2^9 Bytes)
Probe time: 3'53"
Operation: total time / count = avg time
Read: 5.39s / 4816 = 1.1ms
Write: 3'46" / 4192321 = 54us
Reset: 0us / 1 = 0us
I hope your stick is as good as mine
Good news: The device ‘/dev/sdz’ is the real thing
And the Usable size: 59.53 GB (124846080 blocks) is as advertised
Test the stick for data security and speed
- Use gparted to format the stick as a single partition with exfat (about 59GiB) and name “test”. The USB stick will be deleted !!! (So save data that you still need beforehand)
- unplug,
- plug in,
- Mount the USB sick (the stick now is empty)
For me, the stick ends up in/run/media/andreas/test/. You have to adapt this to your mount point.
Now we fill the stick completely with data.
Warning:
This takes a really long time. For me it was about 2 hours with USB2 and 64 GB and also 2 hours with USB3 and 128 GB
Writing the stick this way will shorten the life of your USB stick through wear leveling, so don’t do it to often.
f3write /run/media/andreas/test
F3 write 8.0
Free space: 59.53 GB
Creating file 1.h2w ... OK!
Creating file 2.h2w ... OK!
Creating file 59.h2w ... OK!
Creating file 60.h2w ... OK!
Free space: 0.00 Byte
Average writing speed: 7.75 MB/s (USB2)
Average writing speed: 16.25 MB/s (USB3)
Now we just have to read the data again and compare. Warning: it takes a really long time.
With USB2 and 64 GB it was also almost 2 hours.
f3read /run/media/andreas/test
F3 read 8.0
SECTORS ok/corrupted/changed/overwritten
Validating file 1.h2w ... 2097152/ 0/ 0/ 0
Validating file 2.h2w ... 2097152/ 0/ 0/ 0
Validating file 3.h2w ... 2097152/ 0/ 0/ 0
Validating file 4.h2w ... 2097152/ 0/ 0/ 0
Validating file 58.h2w ... 2097152/ 0/ 0/ 0
Validating file 59.h2w ... 2097152/ 0/ 0/ 0
Validating file 60.h2w ... 1103104/ 0/ 0/ 0
Data OK: 59.53 GB (124835072 sectors)
Data LOST: 0.00 Byte (0 sectors)
Corrupted: 0.00 Byte (0 sectors)
Slightly changed: 0.00 Byte (0 sectors)
Overwritten: 0.00 Byte (0 sectors)
Average reading speed: 12.48 MB/s
usb3:
Data OK: 116.43 GB (244167680 sectors)
Average reading speed: 24.36 MB/s
Data LOST: 0.00 bytes (0 sectors)
Note: The full instructions for f3 can be found here
- my USB-stick was good
- my USB-stick had errors
- my USB-stick is a fake (much smaller then advertised)
