Moderation - add disclaimer
Disclaimer
- Custom packages are unsupported on Manjaro.
- Do not use AUR unless familiar with the build process.
/Moderation - add disclaimer
Hello Everyone!
I have figured out how to install Minecraft Java on a Raspberry Pi and i wanted to share the instructions with the community. I took inspiration from:
got-minecraft-java-edition-to-run-on-a-pi/155020
“ars” = Add Remove Software
- Update your system in “ars”
- Enable AUR in the “ars” settings
- Search in “ars” for PolyMC
4.Before you install it edit the config files
4.a Find a line that says: arch=(‘x86_64’), change it to: arch=(‘any’)
4.b Click Save and install (Installing PolyMC will take a long time) - meanwhile you are gonna download LWJGL 3.2.3 from this website: lwjgl-org/customize
5.a You want to change the “Version” to 3.2.3 and the “Natives” to Linux arm64
5.b download the zip file.
5.c Extract the file to Folder like documents - To start the app correctly you have to type in terminal:
a. MESA_GL_VERSION_OVERRIDE=4.3
b. MESA_GL_VERSION_OVERRIDE=4.3 polymc
- Open the app and create an 1.18 instance (As of writting this there is probably a new 1.19 version)
- Edit the instance And click “Add to minecraft.jar” and select all jar files from the LWJGL library that you have extracted.
- Now run minecraft! If you had any trouble contact me and i will likely to help you!
