I get this message all the time when I have shutoff the mullvadclient:
I have even uninstalled the mullvad app, but the popup message still appears
How to make it disappear forever ?
What desktop environment is that? Is it Plasma? If so, did you have that application set up to automatically start on login?
Check the following in System SettingsâŚ
Workspace â Startup and Shutdown â Autostart
If you see that application in there, delete the entry. Also, remove anything to do with that application fromâŚ
~/.local
~/.config
~/.cache
Thread tentatively moved to #desktop-environments:Plasma.
I use Manjaro original Xfce
Did you have that application set up to automatically start on login ? YES !
Well, then at least this here below still appliesâŚ
Iâm sure XFCE also has a settings page for automatically starting applications on login, so check that, and also make sure there isnât a hidden directory (âfolderâ) with the name of the application in your $HOME
Thread moved to #desktop-environments:XFCE.
Got this from the manual :
To launch custom applications when Xfce starts up, click the Applications Menu > Settings > Settings Manager and then choose the Session and Startup option and click the tab Application Autostart . You will see a list of programs that get launched on startup. To add an entry, click the Add button and fill out the form, specifying the path to an executable you want to run.
Autostart applications are stored as name.desktop
in ~/.config/autostart/
Alternatively, add the commands you wish to run (including setting environment variables) to xinitrc (or [xprofile] when a [display manager] is being used).
Tip: Sometimes it might be useful to delay the startup of an application . Note that specifying under Application > Autostart a command such as sleep 3 && command
does not work; a workaround is to use the syntax sh -c "sleep 3 && command"
How did you install it to begin with and which package?
Found this:
/home/philip/.config/Mullvad VPN/
Will erase the mullvad catalog and see if it disappears.
Installed with Pamac and Mullvad package
Whatâs the output of:
pacman -Qs mullvad
Nope, removed the Mullvad VPN catalog but the message still popsup
[philip@Acer ~]$ pacman -Qs mullvad
[philip@Acer ~]$
[philip@Acer ~]$ sudo pacman -Qs mullvad
[sudo] password for philip:
[philip@Acer ~]$
Nothing âŚ
Which package did you install to begin with?
⯠pamac search mullvad
polybar-mullvad-git r10.3eeff2f-1 AUR
A module for showing connection status of the Mullvad VPN service.
gnome-shell-extension-mullvad-indicator [Installed] 3-1
GNOME extension to track Mullvad connectivity
chrome-extension-mullvad-connectivity-checker [Installed] 1.4-1
Browser extension that checks if you are connected to a Mullvad VPN server
amimullvad [Installed] 1.1-1 AUR
Utility to check for a Mullvad VPN connection status
mullvad-vpn-cli 2020.6-1 AUR
The Mullvad VPN client cli
mullvad-vpn-bin 2020.6-1 AUR
The Mullvad VPN client app for desktop
mullvad-vpn-beta-bin 2020.7.beta1-1 AUR
The Mullvad VPN client app for desktop (latest/beta release)
mullvad-vpn 2020.6-1 AUR
mullvad-tray 0.3-1 AUR
Mullvad VPN connection status in system tray.
mullvad-vpn-beta [Installed] 2020.7.beta1-1 AUR
I think it was that package âŚ
In Pamac everything Mullvad is uninstalled.
Very strange that I get the poppup message still.
Is it something local in the networkmanager that is wrong ?
grep -a mullvad /var/log/pacman.log
[philip@Acer ~]$ grep -a mullvad /var/log/pacman.log
[2020-02-27T22:34:42+0100] [ALPM] installed mullvad-tray (0.3-1)
[2020-02-27T22:56:52+0100] [ALPM] installed mullvad-vpn (2020.3-3)
[2020-02-27T22:56:52+0100] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service â /usr/lib/systemd/system/mullvad-daemon.service.
[2020-05-15T00:06:41+0200] [ALPM] upgraded mullvad-vpn (2020.3-3 -> 2020.4-1)
[2020-05-15T00:18:14+0200] [ALPM] removed mullvad-tray (0.3-1)
[2020-05-15T00:18:16+0200] [ALPM-SCRIPTLET] Removed /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service.
[2020-05-15T00:18:16+0200] [ALPM] removed mullvad-vpn (2020.4-1)
[2020-05-15T00:18:16+0200] [ALPM-SCRIPTLET] sudo rm -rf /var/log/mullvad-vpn/
[2020-05-15T00:18:16+0200] [ALPM-SCRIPTLET] sudo rm -rf /var/cache/mullvad-vpn/
[2020-05-15T00:18:16+0200] [ALPM-SCRIPTLET] sudo rm -rf /etc/mullvad-vpn
[2020-05-15T00:26:58+0200] [ALPM] installed mullvad-vpn-cli (2020.4-1)
[2020-05-15T00:26:58+0200] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service â /usr/lib/systemd/system/mullvad-daemon.service.
[2020-05-24T22:18:22+0200] [ALPM-SCRIPTLET] Removed /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service.
[2020-05-24T22:18:23+0200] [ALPM] removed mullvad-vpn-cli (2020.4-1)
[2020-05-24T22:18:23+0200] [ALPM-SCRIPTLET] sudo rm -rf /var/log/mullvad-vpn/
[2020-05-24T22:18:23+0200] [ALPM-SCRIPTLET] sudo rm -rf /var/cache/mullvad-vpn/
[2020-05-24T22:18:23+0200] [ALPM-SCRIPTLET] sudo rm /etc/mullvad-vpn/settings.json
[2020-06-02T00:11:23+0200] [ALPM] installed mullvad-vpn-cli (2020.4-1)
[2020-06-02T00:11:23+0200] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service â /usr/lib/systemd/system/mullvad-daemon.service.
[2020-06-16T23:42:45+0200] [ALPM] upgraded mullvad-vpn-cli (2020.4-1 -> 2020.4-2)
[2020-07-05T04:26:13+0200] [ALPM-SCRIPTLET] Removed /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service.
[2020-07-05T04:26:14+0200] [ALPM] removed mullvad-vpn-cli (2020.4-2)
[2020-07-05T04:26:14+0200] [ALPM-SCRIPTLET] sudo rm -rf /var/log/mullvad-vpn/
[2020-07-05T04:26:14+0200] [ALPM-SCRIPTLET] sudo rm -rf /var/cache/mullvad-vpn/
[2020-07-05T04:26:14+0200] [ALPM-SCRIPTLET] sudo rm /etc/mullvad-vpn/settings.json
[2020-07-21T01:46:47+0200] [ALPM] installed mullvad-vpn (2020.5-1)
[2020-07-21T01:46:47+0200] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service â /usr/lib/systemd/system/mullvad-daemon.service.
[2020-10-21T22:38:40+0200] [ALPM-SCRIPTLET] Removed /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service.
[2020-10-21T22:38:42+0200] [ALPM] upgraded mullvad-vpn (2020.5-1 -> 2020.6-1)
[2020-10-21T22:38:42+0200] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service â /usr/lib/systemd/system/mullvad-daemon.service.
[2020-11-14T16:59:05+0100] [ALPM-SCRIPTLET] Removed /etc/systemd/system/multi-user.target.wants/mullvad-daemon.service.
[2020-11-14T16:59:05+0100] [ALPM] removed mullvad-vpn (2020.6-1)
[2020-11-14T16:59:05+0100] [ALPM-SCRIPTLET] sudo rm -rf /var/log/mullvad-vpn/
[2020-11-14T16:59:05+0100] [ALPM-SCRIPTLET] sudo rm -rf /var/cache/mullvad-vpn/
[2020-11-14T16:59:05+0100] [ALPM-SCRIPTLET] sudo rm -rf /etc/mullvad-vpn
[philip@Acer ~]$
The service is no longer running and youâve removed all leftover files, so the only thing left I can think of is rebooting.
No, reboot does not help.
Popup-message still coming up.
[philip@Acer ~]$ systemctl list-unit-files --state=enabled
UNIT FILE STATE VENDOR PRESET
var-lib-snapd-snap-bitwarden-26.mount enabled disabled
var-lib-snapd-snap-bitwarden-31.mount enabled disabled
var-lib-snapd-snap-chromium\x2dffmpeg-15.mount enabled disabled
var-lib-snapd-snap-chromium\x2dffmpeg-17.mount enabled disabled
var-lib-snapd-snap-core-10185.mount enabled disabled
var-lib-snapd-snap-core-9436.mount enabled disabled
var-lib-snapd-snap-core18-1885.mount enabled disabled
var-lib-snapd-snap-core18-1932.mount enabled disabled
var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-128.mount enabled disabled
var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount enabled disabled
var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1474.mount enabled disabled
var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1506.mount enabled disabled
var-lib-snapd-snap-signal\x2ddesktop-325.mount enabled disabled
var-lib-snapd-snap-signal\x2ddesktop-335.mount enabled disabled
var-lib-snapd-snap-snapd-8140.mount enabled disabled
var-lib-snapd-snap-snapd-9721.mount enabled disabled
org.cups.cupsd.path enabled disabled
apparmor.service enabled disabled
avahi-daemon.service enabled disabled
bluetooth.service enabled disabled
cronie.service enabled disabled
getty@.service enabled enabled
lines 1-23...skipping...
haveged.service enabled disabled
lightdm.service enabled disabled
linux-module-cleanup.service enabled disabled
ModemManager.service enabled disabled
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
org.cups.cupsd.service enabled disabled
snapd.apparmor.service enabled disabled
snapd.service enabled disabled
systemd-timesyncd.service enabled enabled
tlp.service enabled disabled
ufw.service enabled disabled
avahi-daemon.socket enabled disabled
org.cups.cupsd.socket enabled disabled
snapd.socket enabled disabled
remote-fs.target enabled enabled
fstrim.timer enabled disabled
pamac-cleancache.timer enabled disabled
pamac-mirrorlist.timer enabled disabled
42 unit files listed.
[philip@Acer ~]$
Can you not simply block this application in the notification settings?
