My main question is: Is there a way to use Manjaro-tools to create a bare-bones manjaro system?
I was wondering if anyone has used Manjaro-tools to create an Manjaro Architect ISO?
I am going to try to kick the tires on this during the weekend in a virtual env, it looks like it was updated 5 years ago.
I will update my findings if I get anywhere with it…
Take a look here. It my be helpful:
Build Manjaro ISO
Prerequisites
lots of diskspace (skip this if your root is sufficiently large)
installing the tools
tools configuration
building
Diskspace
You need a lot diskspace - 15-20G per iso you intend to build
The tools
Install the manjaro-tools needed for building an ISO
sudo pacman -Syu git manjaro-tools-iso-git
Configure tools
With the tools installed copy the default tools configuration to your home
cp -R /etc/manjaro-tools ~/.config
Modify the tools configuration to poin…
Also these:
https://forum.manjaro.org/tag/buildiso
There is an iso profile for it - so yes you can create such iso - the script itself is maintained by a community member - I don’t recall who - but searching something like maintainer manjaro architect would bring up a couple of topics
The script itself is largely working - still in the repo as manjaro-architect .
