Sorry total noob here. This is like day 3 on any linux distro for me, ever. Im currently running a stable release of manjaro plasma, PC is the minisforum UM350. I see a new stable release just came out but I have no idea how to update. Been searching quite a bit online but no clear instructions.
Manjaro is a rolling release. This means that when you keep your system current updated you should have the latest release already. Simply open Pamac (Add / Remove Software) and check if updates are available. Packages gives you the info on our branches we support. You can simply search for manjaro-release in the package manager or issue a cat /etc/lsb-release and check if you match the given release versions.
