Dear forum,
I have on old Lenovo Yoga Laptop (with defective internal screen) that is now connected to my PC monitor via HDMI.
inxi --admin --verbosity=7 --filter --no-host
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=7a89bf17-e9f1-40c3-989f-7ca0650cfd94 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 80R6 v: Lenovo Yoga 500-15ISK
serial: <superuser required> Chassis: type: 10 v: Lenovo Yoga 500-15ISK
Mobo: LENOVO model: Lenovo Yoga 500-15ISK v: SDK0J40700 WIN
serial: <superuser required> UEFI: LENOVO v: D3CN39WW date: 06/26/2018
ID-1: BAT0 charge: 21.5 Wh (94.7%) condition: 22.7/30.0 Wh (75.6%)
volts: 8.0 min: 7.4 model: SMP L14M2P21 type: Li-poly serial: <filter>
status: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1
model: Logitech K370s/K375s Multi-Device Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 7.56 GiB used: 3.26 GiB (43.1%)
RAM Report:
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2001 high: 2005 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 2000 3: 2005
4: 2000 bogomips: 19204
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel ports: active: HDMI-A-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Philips PHL 243V7
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:3166 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-8:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 223.57 GiB used: 41.38 GiB (18.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apacer model: AS340 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2PE0 scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 41.38 GiB (18.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 7a89bf17-e9f1-40c3-989f-7ca0650cfd94
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: F3CF-2849
ID-1: swap-1 type: file size: 4 GiB used: 768 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-8:3 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 63.0 C pch: 48.5 C mobo: 30.0 C
Processes: 221 Uptime: 2d 17h 14m wakeups: 69 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1319
lib: 355 flatpak: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
In standard settings, just after connection, the colors on the monitor are quite pale. In Windows this can be solved by enabling YCbCr mode in the Graphics Command Center as described here
Unfortunately I was not able to reproduce this in Manjaro. I assume it may be set in some .conf file, but all information I could find seems to be above my current skill level. By experience, tinkering with graphic settings in config files is not my strongest suit, so I hope that I can find some help here.
One easy workaround is to set the Gamma settings in KDE Plasma display settings to 0.85 (standard: 1.00), but this solves the problem only about half way.
In case you need other outputs, please advise the necessary command.
Thank you very much.
