So, I’m starting to finish up my Manjaro installation, however one very annoying issue I’m currently facing is that some programs always open up on the wrong monitor, notably Dolphin, which opens in the furthest corner of my second monitor.
I’ve already tried a few fixes to this issue that I had found, however they ended up either doing nothing or messing other things up. I’m wondering if there’s any fix that would help here.
Since you’re a new user, I’d recommend you take a look at the link below:
Another tip. Do not edit your OP just to say that you’ve found a solution. Preferably, reply to your own post and write your solution there.
That way, you can mark the thread as solved yourself by clicking on the hamburger menu at the bottom of every post (the solution option is hidden there). Adding a Solved on the thread title is discouraged as per forum rules under the section “How to Post”.
edit your question by pressing the 3 dots and the pencil icon
make it into a real question
cut and paste the solution into a reply to your own question
click the 3 dots below your own answer to mark a solution like this:
so that the next person that has the exact same problem you just had will benefit from your post as your question will now be in the “solved” status.
I solved the issue. I needed to uncheck “Allow apps to remember the positions of their own windows, if they support it” in Window Management > Window Behavior > Advanced.
