Today, I download and installed latest Manjaro KDE(manjaro-kde-23.1.4-240406-linux66) to my laptop.
How ever, I cannot do anything. I think Manjaro Linux is most difficult OS.
thank you.
# pacman -Syu
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
Packages (2) linux66-6.6.26-1 xorg-xwayland-23.2.6-0
Total Installed Size: 137.50 MiB
Net Upgrade Size: -0.05 MiB
(2/2) checking keys in keyring [####################################] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
# pacman-key --init
/usr/bin/pacman-key: line 31: /usr/share/makepkg/util/message.sh: No such file or directory
/usr/bin/pacman-key: line 32: /usr/share/makepkg/util/parseopts.sh: No such file or directory
/usr/bin/pacman-key: line 631: parseopts: command not found
6.6.25-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Apr 4 20:32:38 UTC 2024 x86_64 GNU/Linux
works just fine. Can always add --ignore-missing as an option in case of the sha* file containing multiple checksums, such as is the case with Linux Mint.
I don’t know about the Windows/WSL side of things.
At least with Ventoy, the above method can be used to verify the .ISO on the actual stick, as well. Just have the sha* file in the same directory for simplicity.
clean install for / , /boot/efi partition. but /home did not full clean.
And UEFI mode , secure and fast boot mode desabled.
I do not know how to fix this message. yes, I had with on root user.
I wrote top of this thread, after finished install, I try to sudo pacman -Syu but appear this error.
# pacman -Syu
core is up to date
extra is up to date
next, I tried this command pacman-key --init.
# pacman-key --init
I too, would recommend using a Ventoy USB. The following information describes how to create one in Linux - but you can also make one in Windows - the relevant information is on the Ventoy site.
Ventoy USB
Using a Ventoy USB allows to boot any bootable ISO you choose; all from one USB. The beauty of using Ventoy is that nothing else is needed.
Boot with a Ventoy USB, and ISO files are automatically listed in the Ventoy menu, and can be booted directly. A 32GB (minimum) capacity USB should allow ample space to store several ISOs of your choice.
Ventoy is available from the official Manjaro extra repository:
sudo pacman -S ventoy
Type ventoy (without arguments) to see usage information:
Usage: Ventoy2Disk.sh CMD [ OPTION ] /dev/sdX
CMD:
-i install Ventoy to sdX (fails if disk already installed with Ventoy)
-I force install Ventoy to sdX (no matter if installed or not)
-u update Ventoy in sdX
-l list Ventoy information in sdX
OPTION: (optional)
-r SIZE_MB preserve some space at the bottom of the disk (only for install)
-s/-S enable/disable secure boot support (default is enabled)
-g use GPT partition style, default is MBR (only for install)
-L Label of the 1st exfat partition (default is Ventoy)
-n try non-destructive installation (only for install)
Write the Ventoy system to an empty USB drive;
use /dev/sdX to target the device itself (not a partition).
This is the command I might normally use:
sudo sh ventoy -i -r 100 -S -g -L VOLUME /dev/sdX
Substitute VOLUME for a volume label name to use.
Substitute /dev/sdX for the location of your USB device.
Preserve some space on the target device (example allows 100mb).
