Hello,
I know AV is unnecessary for Linux. I have installed Bitdefender from AUR, but can’t find a way to start it. Please, help.
Hello,
According to the PKGBUILD file, you can run bdgui
in a terminal window to launch the application.
The package also installs a .desktop file called bdgui.desktop
, which means that you should be able to search it in your menu in order to launch it from there.
bdgui gives:
(bdgui:9855): Gtk-WARNING **: 11:38:43.384: Unable to locate theme engine in module_path: “murrine”,
Segmentation fault (core dumped)
There is noting in the menu.
For AV I recommend you try NOD32 for Linux. It’s in the AUR. It can run in the background scanning which most of AV for Linux can’t.
Thank you!
A post was merged into an existing topic: NOD32 - is it in the AUR or not?
