Every time my RPi4 boots, a swapfile is created in /dev/zram0. I don’t want that.
The swapoff
command did not help.
Here is my fstab
file:
# <file system> <dir> <type> <options> <dump> <pass>
PARTUUID=b99d8715-01 /boot vfat defaults 0 0
Strit
2
It’s not a swapfile. It’s compressed RAM used for swap.
Disable the service:
sudo systemctl disable --now zswap-arm.service
Optionally, uninstall the package afterwards:
sudo pacman -R zswap-arm
system
Closed
3
