How to Disable and Delete a Swapfile?
Hello. I created a 16GB swap file according to the instructions here as my system kept on crashing with only 8GB of RAM. Now however, I’ve upgraded it to 24 GB, and I want to remove the swap file because I feel it’s too large. Could I know how I to go about this?
There is post that seems almost similar here, but the proferred solution within it does not apply to my situation.
sudo swapoff /swapfile
sudo rm /swapfile
then create a new one with the desired size and
sudo swapon /swapfile
