Wollie
6 February 2022 19:30
1
I have a new /etc/fonts/fonts.conf.pacnew:
<?xml version="1.0"?>
<!DOCTYPE fontconfig SYSTEM "urn:fontconfig:fonts.dtd">
<!-- /etc/fonts/fonts.conf file to configure system font access -->
<fontconfig>
<description>Default configuration file</description>
compared to existing /etc/fonts/fonts.conf:
<!DOCTYPE fontconfig SYSTEM "fonts.dtd">
<fontconfig>
<its:rules xmlns:its="http://www.w3.org/2005/11/its" version="1.0">
<its:translateRule translate="no" selector="/fontconfig/*[not(self::description)]"/>
</its:rules>
Any suggestion how to merge?
Jaypee
6 February 2022 19:44
2
All I see is its:rules section removed from the middle, and urn:fontconfig added under SYSTEM. Seems straightforward enough
mbb
8 February 2022 09:20
3
Use a diff program, like diffuse for example. Itâs much easier. You just have to call it with pacdiff:
DIFFPROG=diffuse pacdiff
Zesko
8 February 2022 11:47
4
Kompare is a diff GUI wrapper that allows users to view differences between files and also merge them.
Some of its features include:
Supports multiple diff formats
Supports comparison of directories
Supports reading diff files
Customizable interface
Creating and applying patches to source files
ydar
8 February 2022 13:58
5
I like and mostly use Kompare, but kdiff3 is also nice.
DAC324
8 February 2022 15:19
6
meld is another alternative for comparing and merging files.
The question is not âwhich program should I use for comparing and merging â but âif Iâll do any damage if I delete/change those lines â.
I personally stick to this:
DO NOT EDIT THIS FILE.
IT WILL BE REPLACED WHEN FONTCONFIG IS UPDATED.
LOCAL CHANGES BELONG IN âlocal.confâ.
And mine looks like the 1st box already, donât remember if I had to merge it though
Wollie
8 February 2022 18:15
8
Exactly, @tuxmanjarino , I know how to do it but was not sure if the block
</its:rules>
from old config should be kept or not. I will then keep the new pacnew version and store the old one as backup just in case neededâŚ
Edit: After using the pacnew version as new config I did not see any issue. Thanks, everybody!
If you are not sure about this one code block you could comment out the deprecated bit in the .conf file instead of removing it
<fontconfig>
<!-- <its:rules xmlns:its="http://www.w3.org/2005/11/its" version="1.0">
</its:rules> -->
I use a BASH script that creates a backup copy of the .conf file before loading it in meld to merge with the .pacnew
for i in $(/usr/bin/pacdiff --output); do
/usr/bin/cp "${i/.pacnew/}" "${i/.pacnew/}.old"
done
Wollie
Closed
12 February 2022 06:25
10
