No i Have reinstalled Manjareo and did the step by step guide and still did not work WTF
How can a printer work in Ubuntu but not in Manjaro??
Installation dig go well and everything is good except for printingā¦
sorry
This is not the printer model that I have and use
but the installation and configuration for this one is the same - of course you need to adapt the printer name and model, which is used to provide the correct ppd for the printer you have.
You canāt just copy the example that was made for a LBP2900.
If you want further help youād need to tell us exactly what you did and in which order.
(see your shell history ā¦)
If it works in Ubuntu but not here the very simple truth is that you did something wrong.
I reinstalled My KDE Manjaro and I did pamac build capt-src and Manjero find the printer and install it perfectly! I double check it i cups and all look good!
When I print it messages change from idel to sending data to printer and after that nothing happens
What the heck is wrong ???
Does anyone could help me to look were the problems is and what causes it
Obviously, it didnāt install it perfectly.
There are some more (manual) steps involved - you need to configure ccpd.service!
Automatic setup by the steps you described you did ā¦ simply doesnāt work.
Itās all in this thread (links).
Or - again: have a look at the Arch wiki on how to do it.
Nothing is wrong - you simply didnāt do the complete setup procedure.
probably in the hopes that it somehow would be as easy as that
ā¦ it isnāt
it is not complicated or hard or anything like that
in the end
itās just a procedure to follow
follow it - report eventual errors
I did follow the steps step by step but still the same that Cups sent data to printer but nothing happends.
And yes i did change from lp0 to LBP6200 and still nothing
I dd change the Port from standard to the recomended and still nothing
i did add my selt to sys
And i turn of the USB sleep funktion and still nothingā¦
i did the fif0 setup but nothingā¦
I feel its somthing beteen Cups comunication with USB printer.
Cups detect my printer and install it correct and i check the USB adress and its correkt
I cheek the cups was running, lsUSB,
sudo lpadmin -p LBP6200 -m CNCUPSLBP6200CAPTJ.ppd -v ccp://localhost:59687 -E
[sjostrand@AMDRyzen ~]$ systemctl status cups
ā cups.service - CUPS Scheduler
Loaded: loaded (/usr/lib/systemd/system/cups.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-06-22 23:54:37 CEST; 59min ago
TriggeredBy: ā cups.path
ā cups.socket
Docs: man:cupsd(8)
Main PID: 854 (cupsd)
Status: āScheduler is runningā¦ā
Tasks: 5 (limit: 77097)
Memory: 56.3M
CPU: 11.273s
CGroup: /system.slice/cups.service
āā 854 /usr/bin/cupsd -l
āā2776 /usr/lib/cups/notifier/dbus dbus://
āā3030 usb://Canon/LBP6200?serial=0000A1E29Nx8 56 sjostrand Test Page 1 job-uuid=urn:uuid:5554d74d-0a>
jun 22 23:54:37 AMDRyzen systemd[1]: Starting CUPS Schedulerā¦
jun 22 23:54:37 AMDRyzen systemd[1]: Started CUPS Scheduler.
AND
$ systemctl list-unit-files | grep cups
cups.path enabled disabled
cups-browsed.service disabled disabled
cups-lpd@.service static -
cups.service enabled disabled
cups-lpd.socket disabled disabled
cups.socket enabled disabled
AND
USB Canon id.
Bus 003 Device 008 ID 04a9:271b control = on, autosuspend_delay_ms = 2000 ā Canon, Inc. LBP6200 (usbfs)
And i did a lot more but nothing works so I ask the Proās to try to help me to make it work.
I just glanced at it.
Is ccpd enabled and running
I see no mention of it in what you posted.
ā¦ it still feels like you simply didnāt follow the necessary procedure ā¦ didnāt complete all the steps ā¦
ā¦ itās not just cups
itās also ccpd ā¦
I think id does running
[sjostrand@AMDRyzen ~]$ systemctl status ccpd
ā ccpd.service - Canon CAPT daemon
Loaded: loaded (/usr/lib/systemd/system/ccpd.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2021-06-23 11:19:26 CEST; 16min ago
Process: 1446 ExecStart=/usr/bin/ccpd (code=exited, status=0/SUCCESS)
Main PID: 1449 (ccpd)
Tasks: 1 (limit: 77097)
Memory: 1.5M
CPU: 13min 50.212s
CGroup: /system.slice/ccpd.service
āā1449 /usr/bin/ccpd
jun 23 11:19:26 AMDRyzen systemd[1]: Starting Canon CAPT daemonā¦
jun 23 11:19:26 AMDRyzen systemd[1]: Started Canon CAPT daemon.
I mange to make a print test but nothing else.
then i get this error: USB port busy; will retry in 30 seconds
What is CNUSB: becus only with this cnusb:/dev/usb/lp0 i can only make print test nothing else.
