Here is the script I had on Ubuntu that installed my Cannon LBP6200 and if is possible to convert to work on Manjaro / Arc Linux
Script down below:
#!/bin/bash
#Version 3.3 updated on September 13, 2019
#Check if we are running as root
[ $USER != 'root' ] && exec sudo "$0"
#Current user
LOGIN_USER=$(logname)
[ -z "$LOGIN_USER" ] && LOGIN_USER=$(who | head -1 | awk '{print $1}')
#Load the file containing the path to the desktop
if [ -f ~/.config/user-dirs.dirs ]; then
source ~/.config/user-dirs.dirs
else
XDG_DESKTOP_DIR="$HOME/Desktop"
fi
#Driver version
DRIVER_VERSION='2.71-1'
DRIVER_VERSION_COMMON='3.21-1'
#Links to driver packages
declare -A URL_DRIVER=([amd64_common]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-common_3.21-1_amd64.deb' \
[amd64_capt]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-capt_2.71-1_amd64.deb' \
[i386_common]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-common_3.21-1_i386.deb' \
[i386_capt]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/cndrvcups-capt_2.71-1_i386.deb')
#Links to autoshutdowntool
declare -A URL_ASDT=([amd64]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/autoshutdowntool_1.00-1_amd64_deb.tar.gz' \
[i386]='https://github.com/hieplpvip/canon_printer/raw/master/Packages/autoshutdowntool_1.00-1_i386_deb.tar.gz')
#ppd files and printer models mapping
declare -A LASERSHOT=([LBP-810]=1120 [LBP1120]=1120 [LBP1210]=1210 \
[LBP2900]=2900 [LBP3000]=3000 [LBP3010]=3050 [LBP3018]=3050 [LBP3050]=3050 \
[LBP3100]=3150 [LBP3108]=3150 [LBP3150]=3150 [LBP3200]=3200 [LBP3210]=3210 \
[LBP3250]=3250 [LBP3300]=3300 [LBP3310]=3310 [LBP3500]=3500 [LBP5000]=5000 \
[LBP5050]=5050 [LBP5100]=5100 [LBP5300]=5300 [LBP6000]=6018 [LBP6018]=6018 \
[LBP6020]=6020 [LBP6020B]=6020 [LBP6200]=6200 [LBP6300n]=6300n [LBP6300]=6300 \
[LBP6310]=6310 [LBP7010C]=7018C [LBP7018C]=7018C [LBP7200C]=7200C [LBP7210C]=7210C \
[LBP9100C]=9100C [LBP9200C]=9200C)
#Sort printer names
NAMESPRINTERS=$(echo "${!LASERSHOT[@]}" | tr ' ' '\n' | sort -n -k1.4)
#Models supported by autoshutdowntool
declare -A ASDT_SUPPORTED_MODELS=([LBP6020]='MTNA002001 MTNA999999' \
[LBP6020B]='MTMA002001 MTMA999999' [LBP6200]='MTPA00001 MTPA99999' \
[LBP6310]='MTLA002001 MTLA999999' [LBP7010C]='MTQA00001 MTQA99999' \
[LBP7018C]='MTRA00001 MTRA99999' [LBP7210C]='MTKA002001 MTKA999999')
#OS architecture
if [ "$(uname -m)" == 'x86_64' ]; then
ARCH='amd64'
else
ARCH='i386'
fi
#Determine the init system
if [[ $(ps -p1 | grep systemd) ]]; then
INIT_SYSTEM='systemd'
else
INIT_SYSTEM='upstart'
fi
#Move to the current directory
cd "$(dirname "$0")"
function valid_ip() {
local ip=$1
local stat=1
if [[ $ip =~ ^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}$ ]]; then
ip=($(echo "$ip" | tr '.' ' '))
[[ ${ip[0]} -le 255 && ${ip[1]} -le 255 && ${ip[2]} -le 255 && ${ip[3]} -le 255 ]]
stat=$?
fi
return $stat
function check_error() {
if [ $2 -ne 0 ]; then
case $1 in
'WGET') echo "Error while downloading file $3"
[ -n "$3" ] && [ -f "$3" ] && rm "$3";;
'PACKAGE') echo "Error installing package $3";;
*) echo 'Error';;
esac
echo 'Press any key to exit'
read -s -n1
exit 1
fi
function canon_unistall() {
if [ -f /usr/sbin/ccpdadmin ]; then
installed_model=$(ccpdadmin | grep LBP | awk '{print $3}')
if [ -n "$installed_model" ]; then
echo "Found printer $installed_model"
echo "Closing captstatusui"
killall captstatusui 2> /dev/null
echo 'Stopping ccpd'
service ccpd stop
echo 'Removing the printer from the ccpd daemon configuration file'
ccpdadmin -x $installed_model
echo 'Removing the printer from CUPS'
lpadmin -x $installed_model
fi
fi
echo 'Removing driver packages'
dpkg --purge cndrvcups-capt
dpkg --purge cndrvcups-common
echo 'Removing unused libraries and packages'
apt-get -y autoremove
echo 'Deleting settings'
[ -f /etc/init/ccpd-start.conf ] && rm /etc/init/ccpd-start.conf
[ -f /etc/udev/rules.d/85-canon-capt.rules ] && rm /etc/udev/rules.d/85-canon-capt.rules
[ -f "${XDG_DESKTOP_DIR}/captstatusui.desktop" ] && rm "${XDG_DESKTOP_DIR}/captstatusui.desktop"
[ -f /usr/bin/autoshutdowntool ] && rm /usr/bin/autoshutdowntool
[ $INIT_SYSTEM == 'systemd' ] && update-rc.d -f ccpd remove
echo 'Uninstall completed'
read -s -n1
return 0
function canon_install() {
echo
PS3='Please choose your priter: '
select NAMEPRINTER in $NAMESPRINTERS
do
[ -n "$NAMEPRINTER" ] && break
done
echo "Selected printer: $NAMEPRINTER"
echo
PS3='How is the printer connected to the computer: '
select CONECTION in 'Via USB' 'Through network (LAN, NET)'
do
if [ "$REPLY" == "1" ]; then
CONECTION="usb"
while true
do
#Looking for a device connected to the USB port
NODE_DEVICE=$(ls -1t /dev/usb/lp* 2> /dev/null | head -1)
if [ -n "$NODE_DEVICE" ]; then
#Find the serial number of that device
PRINTER_SERIAL=$(udevadm info --attribute-walk --name=$NODE_DEVICE | sed '/./{H;$!d;};x;/ATTRS{product}=="Canon CAPT USB \(Device\|Printer\)"/!d;' | awk -F'==' '/ATTRS{serial}/{print $2}')
#If the serial number is found, that device is a Canon printer
[ -n "$PRINTER_SERIAL" ] && break
fi
echo -ne "Turn on the printer and plug in USB cable\r"
sleep 2
done
PATH_DEVICE="/dev/canon$NAMEPRINTER"
break
elif [ "$REPLY" == "2" ]; then
CONECTION="lan"
read -p 'Enter the IP address of the printer: ' IP_ADDRES
until valid_ip "$IP_ADDRES"
do
echo 'Invalid IP address format, enter four decimal numbers'
echo -n 'from 0 to 255, separated by dots: '
read IP_ADDRES
done
PATH_DEVICE="net:$IP_ADDRES"
echo 'Turn on the printer and press any key'
read -s -n1
sleep 5
break
fi
done
echo '************Driver Installation************'
COMMON_FILE=cndrvcups-common_${DRIVER_VERSION_COMMON}_${ARCH}.deb
CAPT_FILE=cndrvcups-capt_${DRIVER_VERSION}_${ARCH}.deb
if [ ! -f $COMMON_FILE ]; then
sudo -u $LOGIN_USER wget -O $COMMON_FILE ${URL_DRIVER[${ARCH}_common]}
check_error WGET $? $COMMON_FILE
fi
if [ ! -f $CAPT_FILE ]; then
sudo -u $LOGIN_USER wget -O $CAPT_FILE ${URL_DRIVER[${ARCH}_capt]}
check_error WGET $? $CAPT_FILE
fi
apt-get -y update
apt-get -y install libglade2-0 libcanberra-gtk-module
check_error PACKAGE $?
echo 'Installing common module for CUPS driver'
dpkg -i $COMMON_FILE
check_error PACKAGE $? $COMMON_FILE
echo 'Installing CAPT Printer Driver Module'
dpkg -i $CAPT_FILE
check_error PACKAGE $? $CAPT_FILE
#Replace /etc/init.d/ccpd
echo '#!/bin/bash
# startup script for Canon Printer Daemon for CUPS (ccpd)
### BEGIN INIT INFO
# Provides: ccpd
# Required-Start: $local_fs $remote_fs $syslog $network $named
# Should-Start: $ALL
# Required-Stop: $syslog $remote_fs
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Description: Start Canon Printer Daemon for CUPS
### END INIT INFO
# If the CUPS print server is not running, wait until it starts
if [ `ps awx | grep cupsd | grep -v grep | wc -l` -eq 0 ]; then
while [ `ps awx | grep cupsd | grep -v grep | wc -l` -eq 0 ]
do
sleep 3
done
sleep 5
fi
ccpd_start ()
echo -n "Starting ${DAEMON}: "
start-stop-daemon --start --quiet --oknodo --exec ${DAEMON}
ccpd_stop ()
echo -n "Shutting down ${DAEMON}: "
start-stop-daemon --stop --quiet --oknodo --retry TERM/30/KILL/5 --exec ${DAEMON}
DAEMON=/usr/sbin/ccpd
case $1 in
start)
ccpd_start
stop)
ccpd_stop
status)
echo "${DAEMON}:" $(pidof ${DAEMON})
restart)
while true
do
ccpd_stop
ccpd_start
# if the ccpd process does not appear after 5 seconds, we restart it again
for (( i = 1 ; i <= 5 ; i++ ))
do
sleep 1
set -- $(pidof ${DAEMON})
[ -n "$1" -a -n "$2" ] && exit 0
done
done
echo "Usage: ccpd {start|stop|status|restart}"
exit 1
esac
exit 0' > /etc/init.d/ccpd
#Installation utilities for managing AppArmor
apt-get -y install apparmor-utils
#Set AppArmor security profile for cupsd to complain mode
aa-complain /usr/sbin/cupsd
echo 'Restarting CUPS'
service cups restart
if [ $ARCH == 'amd64' ]; then
echo 'Installing 32-bit libraries required to run 64-bit printer driver'
apt-get -y install libatk1.0-0:i386 libcairo2:i386 libgtk2.0-0:i386 libpango1.0-0:i386 libstdc++6:i386 libpopt0:i386 libxml2:i386 libc6:i386
fi
echo 'Installing the printer in CUPS'
/usr/sbin/lpadmin -p $NAMEPRINTER -P /usr/share/cups/model/CNCUPSLBP${LASERSHOT[$NAMEPRINTER]}CAPTK.ppd -v ccp://localhost:59687 -E
echo "Setting $NAMEPRINTER as the default printer"
/usr/sbin/lpadmin -d $NAMEPRINTER
echo 'Registering the printer in the ccpd daemon configuration file'
/usr/sbin/ccpdadmin -p $NAMEPRINTER -o $PATH_DEVICE
#Verify printer installation
installed_printer=$(ccpdadmin | grep $NAMEPRINTER | awk '{print $3}')
if [ -n "$installed_printer" ]; then
if [ "$CONECTION" == "usb" ]; then
echo 'Creating a rule for the printer'
#A rule is created to provides an alternative name (a symbolic link) to our printer so as not to depend on the changing values of lp0, lp1,...
echo 'KERNEL=="lp[0-9]*", SUBSYSTEMS=="usb", ATTRS{serial}=='$PRINTER_SERIAL', SYMLINK+="canon'$NAMEPRINTER'"' > /etc/udev/rules.d/85-canon-capt.rules
#Update the rules
udevadm control --reload-rules
#Check the created rule
until [ -e $PATH_DEVICE ]
do
echo -ne "Turn off the printer, wait 2 seconds, then turn on the printer\r"
sleep 2
done
fi
echo -e "\e[2KRunning ccpd"
service ccpd restart
#Autoload ccpd
if [ $INIT_SYSTEM == 'systemd' ]; then
update-rc.d ccpd defaults
else
echo 'description "Canon Printer Daemon for CUPS (ccpd)"
author "LinuxMania <customer@linuxmania.jp>"
start on (started cups and runlevel [2345])
stop on runlevel [016]
expect fork
respawn
exec /usr/sbin/ccpd start' > /etc/init/ccpd-start.conf
fi
#Create captstatusui shortcut on desktop
echo '#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Name='$NAMEPRINTER'
GenericName=Status monitor for Canon CAPT Printer
Exec=captstatusui -P '$NAMEPRINTER'
Terminal=false
Type=Application
Icon=/usr/share/icons/Humanity/devices/48/printer.svg' > "${XDG_DESKTOP_DIR}/$NAMEPRINTER.desktop"
chmod 775 "${XDG_DESKTOP_DIR}/$NAMEPRINTER.desktop"
chown $LOGIN_USER:$LOGIN_USER "${XDG_DESKTOP_DIR}/$NAMEPRINTER.desktop"
#Install autoshutdowntool for supported models
if [[ "${!ASDT_SUPPORTED_MODELS[@]}" =~ "$NAMEPRINTER" ]]; then
SERIALRANGE=(${ASDT_SUPPORTED_MODELS[$NAMEPRINTER]})
SERIALMIN=${SERIALRANGE[0]}
SERIALMAX=${SERIALRANGE[1]}
if [[ ${#PRINTER_SERIAL} -eq ${#SERIALMIN} && $PRINTER_SERIAL > $SERIALMIN && $PRINTER_SERIAL < $SERIALMAX || $PRINTER_SERIAL == $SERIALMIN || $PRINTER_SERIAL == $SERIALMAX ]]; then
echo "Installing the autoshutdowntool utility"
ASDT_FILE=autoshutdowntool_1.00-1_${ARCH}_deb.tar.gz
if [ ! -f $ASDT_FILE ]; then
wget -O $ASDT_FILE ${URL_ASDT[$ARCH]}
check_error WGET $? $ASDT_FILE
fi
tar --gzip --extract --file=$ASDT_FILE --totals --directory=/usr/bin
fi
fi
#Start captstatusui
if [[ -n "$DISPLAY" ]] ; then
sudo -u $LOGIN_USER nohup captstatusui -P $NAMEPRINTER > /dev/null 2>&1 &
sleep 5
fi
echo 'Installation completed. Press any key to exit'
read -s -n1
exit 0
else
echo 'Driver for $NAMEPRINTER is not installed!'
read -s -n1
exit 1
fi
function canon_help {
clear
echo 'Installation Notes
If you have already installed driver for this series,
uninstall it before using this script.
If the driver packages are not found, they will be automatically
downloaded from the Internet and saved in the script folder.
To update the driver, first uninstall the old version using this script,
then install a new one.
Notes on printing problems:
If the printer stops printing, run captstatusui via the shortcut
on desktop or from terminal: captstatusui -P <printer_name>
The captstatusui window shows the current status of the printer.
If an error occurs, its description is displayed.
Here you can try pressing button "Resume Job" to continue printing
or "Cancel Job" button to cancel the job.
If this does not help, try running canon_restart.sh
Printer configuration command: cngplp
Additional settings command: captstatusui -P <printer_name>
Turn on auto-off (not for all models): autoshutdowntool
To log the installation process, run the script like this:
logsave log.txt ./canon_lbp_setup.sh
clear
echo 'Installing the Linux CAPT Printer Driver v'${DRIVER_VERSION}' for Canon LBP printers on Ubuntu (both 32-bit and 64-bit)
Supported printers:'
echo "$NAMESPRINTERS" | sed ':a; /$/N; s/\n/, /; ta' | fold -s
PS3='Please enter your choice: '
select opt in 'Install' 'Uninstall' 'Help' 'Exit'
do
if [ "$opt" == 'Install' ]; then
canon_install
break
elif [ "$opt" == 'Uninstall' ]; then
canon_unistall
break
elif [ "$opt" == 'Help' ]; then
canon_help
elif [ "$opt" == 'Exit' ]; then
break
fi
done
What the script does is essentially the same as the steps I listed in my post
(which are taken from the Arch wiki, which refers back to the Ubuntu wiki and this very package …)
plus a udev-rule to persistently name the device using it’s serial number.
The latter part is interesting and helps to refer to the correct printer if you have more than one printer.
But it doesn’t create a systemd service for ccpd - this is handeled differently in Ubuntu.
It’s created from the files which are put into /etc/rc.d using their tool update-rc.d
The Arch CanonCapt driver does this directly - it provides the service file.
Thanks for the info but i am not a programmer so for me (Linux Noob) if someone can rewrite this script working on Manjaro it would be much appreciate.
Or make a step by step walk thru because the “steps I listed in my post” [Nachlese] did not work for me. I could doing something wrong.
the Arch guide also mentions that a different port number for the ccpd.service might be needed …
or it doesn’t work because you have (apparently, from your screenshots) two printers
and the device name (/dev/usb/lp0) is not the correct one (this is more likely)
… that’s where the udev-rule would help
It creates a uniquely named device node
this is in your script - but not in the Arch wiki
I have not implemented this myself - don’t need it - I only have this one printer
Maybe I will, some day - but not in the near future.
Because it works for me …
But maybe someone else is interested in doing that now.
the creation of the udev rule is somewhere in the script
line 280 and down
… but I won’t do it, won’t try to implement it now
partly because I can’t test it, partly because I don’t need it
You could disconnect your dymo label printer - then /dev/usb/lp0 should be your Canon printer - or assign /dev/usb/lp1 to the Canon printer
this could also work
don’t know
don’t need it
can’t test whether whatever I came up with here would work
Sorry!
The device node is created when the printer is connected.
It goes away when it is disconnected.
You can look and see what happens before, when, and after it is connected.
That way you don’t just blindly try and hope you get it right - you see what happens and can proceed with known good data
via: watch ls -l /dev/usb
then connect the printer and see what it’s device node is
This device name needs to be in the DevicePath statement in /etc/ccpd.conf
If the printer isn’t working when you use that - it is still not correctly configured.
Use ccpdadmin -x
and lpadmin -x
to uninstall printer and start anew.
Here
and Here
you can find a udev rule to persistently name your printer
you can then use /dev/lp/by-id/some_long_name
or /dev/lp/by-path/some_even_longer_name
to refer to the printer instead of /dev/usb/lpx
The person who posted it said that this was only good for one printer at a time.
I’m totally not sure about that, whether it is correct or not.
I have only one printer - that’s quite enough for me.
So I cannot verify that.
