So, my main drive which i have Manjaro installed has like 50 gb’s of space… and i wanna keep that for the os, but whenever i install a package it defaults to the drive Manjaro is installed… and i would like to install the packages in a separate drive i made for those installation files… but how can i do that??? pls help
Hi @Chris5112, and welcome!
Please see
Hope this helps!
Edit:
In short, it’s not really possible. At least not easily. I wouldn’t attempt it. But going through those tutorials might give you a better idea of what you can do safely.
Package are part of the OS. Also 50GB is plenty enough.
What you may need to do is rather some cleaning: Pamac - Manjaro
If that does clear enough space, you can use an utility to analyze where space is taken: List of applications - ArchWiki
It is very simple - You cannot.
Only a few applications are self-contained but usually applications are not taking much space. It is user data which is taking space.
If your is caused by an excessive use of snaps - eg. from curiosity - testing - learning - you first need to learn how to maintain your system.
Thanks for the reply… i understand now lol
thanks for the reply tho…
thanks for the reply… i get it now
