Hello friends
I recently had a problem after updating to the latest version of Manjaro.
It stays on a black screen when I turn on the laptop!
I have to manually turn off the laptop and turn it on again to log in.
I tried to install Grub and searched the internet and YouTube but I did not find any results! ![]()
Help me please.
Thankful.
Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=6ea57d30-795b-481a-997c-4ddf125f1e24 rw "acpi_osi=Windows
2017quiet" apparmor=1 security=apparmor
resume=UUID=dc1ccf8a-515b-4b19-bc77-1fafead52150 udev.log_priority=3
Desktop: GNOME 3.36.5 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N552VW v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N552VW v: 1.0 serial: <filter>
UEFI: American Megatrends v: N552VW.304 date: 05/08/2019
ID-1: BAT0 charge: 27.9 Wh condition: 33.0/48.2 Wh (68%) volts: 14.4/14.4
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 765
RAM: total: 7.67 GiB used: 1.79 GiB (23.3%)
RAM Report:
Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
L2 cache: 6144 KiB bogomips: 41621
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 801
3: 800 4: 800 5: 800 6: 800 7: 801 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:139b
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-4:3 chip ID: 13d3:5666 serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: gnome-shell
driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k5.7.19-2-MANJARO
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000
bus ID: 02:00.0 chip ID: 8086:095a
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.1
chip ID: 10ec:8168
IF: enp3s0f1 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 32.37 GiB (3.5%)
ID-1: /dev/sda vendor: Toshiba model: MQ02ABD100H size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1J scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: cdrom
ID-1: / raw size: 422.51 GiB size: 414.87 GiB (98.19%)
used: 13.23 GiB (3.2%) fs: ext4 dev: /dev/sda4 label: N/A
uuid: 6ea57d30-795b-481a-997c-4ddf125f1e24
ID-2: /boot/efi raw size: 1024.0 MiB size: 1022.0 MiB (99.80%)
used: 296 KiB (0.0%) fs: vfat dev: /dev/sda1 label: N/A uuid: FF39-1B3A
ID-3: /home raw size: 500.00 GiB size: 491.15 GiB (98.23%)
used: 19.13 GiB (3.9%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 2c5f6b84-7c2a-4729-8c95-c65678edb48e
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 label: N/A
uuid: dc1ccf8a-515b-4b19-bc77-1fafead52150
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: MosArt Wireless Keyboard/Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 062a:4101
Device-2: 1-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:5666
serial: <filter>
Device-3: 1-9:4 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2a
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 44.5 C mobo: N/A gpu: nouveau temp: 39 C
Fan Speeds (RPM): cpu: 2100
Processes: 282 Uptime: 12m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1241 pacman: 1230 lib: 345 flatpak: 4 snap: 7 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
