Craft
27 October 2023 16:57
1
Tell me, please, how to install the “long-lasting” Firefox-ESR v115 instead of the usual Firefox 118 ?
Found it in AUR:
First of all, I uninstalled the preinstalled Firefox 118th, it was completed without problems.
Then I started installing ESR. But it turned out that he was not settling down, but getting ready.
Okay, I click “Build”, I agree with the PGP key.
The assembly continues for quite a long time, and at the end the following error appears
Help me Firefox-ESR v.115, please!
Wollie
27 October 2023 17:00
2
Please, be aware that this package is from AUR. AUR is not supported here. If files are missing maybe the packager did not maintain the package properly, so this is not a Manjaro issue at all. Have you updated your system upfront? If not, run:
sudo pacman-mirrors -f && sudo pacman -Syyu base-devel git
and try again.
Craft
27 October 2023 17:34
3
Ok, but why then do I see AUR and Firefox in my Manjaro in the lists applications?
Thanks, I’ll try to update now
Wollie
27 October 2023 17:37
4
It’s a voluntary service of Pamac to allow using AUR - but you should understand the principles of AUR before using it.
Hi.
Firefox-ESR do not conflict with regular firefox. You can install both.
If you want to run installation from the command line, use pamac build firefox-esr.
From your post in Russian I guess you have ARM, so the error might be connected to that.
Craft
27 October 2023 17:53
6
I made an update at your command.
Unfortunately, the same error remains
What else should I do?
What is unclear about ERROR: firefox-esr is not available for the aarch64 architecture? It’s for x86_64 systems only and will not build on ARM64.
Your immediate error is you need to add ‘aarch64’ to this line in the PKGBUILD:
arch=('x86_64' 'aarch64')
That will get you past that but you may run into issues later on down the line. Seems like at some version change there was issues getting it to compile for arm.
Craft
27 October 2023 20:37
10
Ok, I edited the PKGBUILD file:
arch = ('x86_64' 'aarch64')
Unfortunately, the result was sad…
What else needs to be fixed to successfully build Firefox ESR?
build 'aarch64'
Preparing...
Cloning firefox-esr build files...
Generating firefox-esr information...
Checking firefox-esr dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building firefox-esr...
==> Making package: firefox-esr 115.4.0-1 (Fri 27 Oct 2023 09:53:40 PM CEST)
==> Retrieving sources...
-> Downloading firefox-115.4.0esr.source.tar.xz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
1 481M 1 8959k 0 0 8574k 0 0:00:57 0:00:01 0:00:56 8574k
4 481M 4 19.8M 0 0 9952k 0 0:00:49 0:00:02 0:00:47 9951k
6 481M 6 30.9M 0 0 10.1M 0 0:00:47 0:00:03 0:00:44 10.1M
8 481M 8 42.0M 0 0 10.3M 0 0:00:46 0:00:04 0:00:42 10.3M
11 481M 11 52.9M 0 0 10.4M 0 0:00:45 0:00:05 0:00:40 10.5M
12 481M 12 62.4M 0 0 10.3M 0 0:00:46 0:00:06 0:00:40 10.7M
15 481M 15 73.6M 0 0 10.4M 0 0:00:46 0:00:07 0:00:39 10.7M
17 481M 17 84.5M 0 0 10.5M 0 0:00:45 0:00:08 0:00:37 10.7M
19 481M 19 95.4M 0 0 10.5M 0 0:00:45 0:00:09 0:00:36 10.6M
22 481M 22 106M 0 0 10.5M 0 0:00:45 0:00:10 0:00:35 10.6M
24 481M 24 117M 0 0 10.6M 0 0:00:45 0:00:11 0:00:34 10.9M
26 481M 26 128M 0 0 10.6M 0 0:00:45 0:00:12 0:00:33 10.9M
28 481M 28 139M 0 0 10.6M 0 0:00:45 0:00:13 0:00:32 10.9M
31 481M 31 150M 0 0 10.6M 0 0:00:44 0:00:14 0:00:30 10.9M
33 481M 33 160M 0 0 10.6M 0 0:00:45 0:00:15 0:00:30 10.8M
35 481M 35 170M 0 0 10.6M 0 0:00:45 0:00:16 0:00:29 10.6M
37 481M 37 181M 0 0 10.6M 0 0:00:45 0:00:17 0:00:28 10.6M
40 481M 40 192M 0 0 10.6M 0 0:00:45 0:00:18 0:00:27 10.6M
42 481M 42 203M 0 0 10.6M 0 0:00:44 0:00:19 0:00:25 10.6M
44 481M 44 214M 0 0 10.7M 0 0:00:44 0:00:20 0:00:24 10.8M
46 481M 46 225M 0 0 10.7M 0 0:00:44 0:00:21 0:00:23 10.9M
49 481M 49 236M 0 0 10.7M 0 0:00:44 0:00:22 0:00:22 10.9M
51 481M 51 247M 0 0 10.7M 0 0:00:44 0:00:23 0:00:21 11.0M
53 481M 53 258M 0 0 10.7M 0 0:00:44 0:00:24 0:00:20 11.0M
56 481M 56 269M 0 0 10.7M 0 0:00:44 0:00:25 0:00:19 11.0M
58 481M 58 279M 0 0 10.7M 0 0:00:44 0:00:26 0:00:18 10.7M
60 481M 60 290M 0 0 10.7M 0 0:00:44 0:00:27 0:00:17 10.7M
62 481M 62 301M 0 0 10.7M 0 0:00:44 0:00:28 0:00:16 10.7M
65 481M 65 312M 0 0 10.7M 0 0:00:44 0:00:29 0:00:15 10.7M
67 481M 67 323M 0 0 10.7M 0 0:00:44 0:00:30 0:00:14 10.7M
69 481M 69 334M 0 0 10.7M 0 0:00:44 0:00:31 0:00:13 11.0M
71 481M 71 345M 0 0 10.7M 0 0:00:44 0:00:32 0:00:12 11.0M
73 481M 73 355M 0 0 10.7M 0 0:00:44 0:00:33 0:00:11 10.7M
76 481M 76 365M 0 0 10.7M 0 0:00:44 0:00:34 0:00:10 10.5M
78 481M 78 376M 0 0 10.7M 0 0:00:44 0:00:35 0:00:09 10.4M
80 481M 80 387M 0 0 10.7M 0 0:00:44 0:00:36 0:00:08 10.4M
82 481M 82 398M 0 0 10.7M 0 0:00:44 0:00:37 0:00:07 10.5M
84 481M 84 408M 0 0 10.7M 0 0:00:44 0:00:38 0:00:06 10.5M
87 481M 87 419M 0 0 10.7M 0 0:00:44 0:00:39 0:00:05 10.7M
89 481M 89 428M 0 0 10.7M 0 0:00:44 0:00:40 0:00:04 10.4M
91 481M 91 438M 0 0 10.6M 0 0:00:45 0:00:41 0:00:04 10.1M
93 481M 93 449M 0 0 10.6M 0 0:00:45 0:00:42 0:00:03 10.1M
95 481M 95 460M 0 0 10.6M 0 0:00:45 0:00:43 0:00:02 10.3M
97 481M 97 471M 0 0 10.6M 0 0:00:44 0:00:44 --:--:-- 10.3M
100 481M 100 481M 0 0 10.6M 0 0:00:44 0:00:44 --:--:-- 10.6M
-> Downloading firefox-115.4.0esr.source.tar.xz.asc...
100 833 100 833 0 0 9311 0 --:--:-- --:--:-- --:--:-- 9255
-> Found firefox-esr.desktop
-> Found identity-icons-brand.svg
-> Downloading firefox-esr-i18n-115.4.0-ach.xpi...
49 430k 49 214k 0 0 252k 0 0:00:01 --:--:-- 0:00:01 252k
100 430k 100 430k 0 0 323k 0 0:00:01 0:00:01 --:--:-- 324k
-> Downloading firefox-esr-i18n-115.4.0-af.xpi...
16 393k 16 66224 0 0 125k 0 0:00:03 --:--:-- 0:00:03 125k
100 393k 100 393k 0 0 706k 0 --:--:-- --:--:-- --:--:-- 706k
-> Downloading firefox-esr-i18n-115.4.0-an.xpi...
41 471k 41 196k 0 0 233k 0 0:00:02 --:--:-- 0:00:02 233k
100 471k 100 471k 0 0 457k 0 0:00:01 0:00:01 --:--:-- 457k
-> Downloading firefox-esr-i18n-115.4.0-ar.xpi...
100 536k 100 536k 0 0 734k 0 --:--:-- --:--:-- --:--:-- 735k
-> Downloading firefox-esr-i18n-115.4.0-ast.xpi...
66 466k 66 311k 0 0 323k 0 0:00:01 --:--:-- 0:00:01 322k
100 466k 100 466k 0 0 446k 0 0:00:01 0:00:01 --:--:-- 446k
-> Downloading firefox-esr-i18n-115.4.0-az.xpi...
100 459k 100 459k 0 0 1055k 0 --:--:-- --:--:-- --:--:-- 1056k
-> Downloading firefox-esr-i18n-115.4.0-be.xpi...
10 631k 10 68985 0 0 139k 0 0:00:04 --:--:-- 0:00:04 139k
100 631k 100 631k 0 0 776k 0 --:--:-- --:--:-- --:--:-- 776k
-> Downloading firefox-esr-i18n-115.4.0-bg.xpi...
11 550k 11 66227 0 0 103k 0 0:00:05 --:--:-- 0:00:05 103k
100 550k 100 550k 0 0 792k 0 --:--:-- --:--:-- --:--:-- 791k
-> Downloading firefox-esr-i18n-115.4.0-bn.xpi...
100 545k 100 545k 0 0 907k 0 --:--:-- --:--:-- --:--:-- 908k
-> Downloading firefox-esr-i18n-115.4.0-br.xpi...
100 521k 100 521k 0 0 740k 0 --:--:-- --:--:-- --:--:-- 740k
-> Downloading firefox-esr-i18n-115.4.0-bs.xpi...
0 430k 0 2055 0 0 5521 0 0:01:19 --:--:-- 0:01:19 5524
100 430k 100 430k 0 0 750k 0 --:--:-- --:--:-- --:--:-- 750k
-> Downloading firefox-esr-i18n-115.4.0-ca-valencia.xpi...
89 509k 89 454k 0 0 663k 0 --:--:-- --:--:-- --:--:-- 663k
100 509k 100 509k 0 0 697k 0 --:--:-- --:--:-- --:--:-- 697k
-> Downloading firefox-esr-i18n-115.4.0-ca.xpi...
100 532k 100 532k 0 0 751k 0 --:--:-- --:--:-- --:--:-- 752k
-> Downloading firefox-esr-i18n-115.4.0-cak.xpi...
100 551k 100 551k 0 0 994k 0 --:--:-- --:--:-- --:--:-- 993k
-> Downloading firefox-esr-i18n-115.4.0-cs.xpi...
100 578k 100 578k 0 0 1152k 0 --:--:-- --:--:-- --:--:-- 1154k
-> Downloading firefox-esr-i18n-115.4.0-cy.xpi...
52 551k 52 287k 0 0 297k 0 0:00:01 --:--:-- 0:00:01 297k
100 551k 100 551k 0 0 494k 0 0:00:01 0:00:01 --:--:-- 494k
-> Downloading firefox-esr-i18n-115.4.0-da.xpi...
22 541k 22 121k 0 0 154k 0 0:00:03 --:--:-- 0:00:03 154k
100 541k 100 541k 0 0 478k 0 0:00:01 0:00:01 --:--:-- 479k
-> Downloading firefox-esr-i18n-115.4.0-de.xpi...
80 561k 80 450k 0 0 693k 0 --:--:-- --:--:-- --:--:-- 693k
100 561k 100 561k 0 0 772k 0 --:--:-- --:--:-- --:--:-- 772k
-> Downloading firefox-esr-i18n-115.4.0-dsb.xpi...
34 575k 34 199k 0 0 236k 0 0:00:02 --:--:-- 0:00:02 236k
100 575k 100 575k 0 0 526k 0 0:00:01 0:00:01 --:--:-- 527k
-> Downloading firefox-esr-i18n-115.4.0-el.xpi...
13 648k 13 86904 0 0 106k 0 0:00:06 --:--:-- 0:00:06 106k
100 648k 100 648k 0 0 470k 0 0:00:01 0:00:01 --:--:-- 470k
-> Downloading firefox-esr-i18n-115.4.0-en-CA.xpi...
1 507k 1 5503 0 0 14755 0 0:00:35 --:--:-- 0:00:35 14753
100 507k 100 507k 0 0 550k 0 --:--:-- --:--:-- --:--:-- 550k
-> Downloading firefox-esr-i18n-115.4.0-en-GB.xpi...
0 518k 0 3335 0 0 9015 0 0:00:58 --:--:-- 0:00:58 9013
100 518k 100 518k 0 0 474k 0 0:00:01 0:00:01 --:--:-- 474k
-> Downloading firefox-esr-i18n-115.4.0-en-US.xpi...
100 511k 100 511k 0 0 466k 0 0:00:01 0:00:01 --:--:-- 466k
-> Downloading firefox-esr-i18n-115.4.0-eo.xpi...
100 543k 100 543k 0 0 702k 0 --:--:-- --:--:-- --:--:-- 703k
-> Downloading firefox-esr-i18n-115.4.0-es-AR.xpi...
100 555k 100 555k 0 0 780k 0 --:--:-- --:--:-- --:--:-- 780k
-> Downloading firefox-esr-i18n-115.4.0-es-CL.xpi...
4 555k 4 26562 0 0 68237 0 0:00:08 --:--:-- 0:00:08 68107
100 555k 100 555k 0 0 591k 0 --:--:-- --:--:-- --:--:-- 591k
-> Downloading firefox-esr-i18n-115.4.0-es-ES.xpi...
0 548k 0 5503 0 0 13411 0 0:00:41 --:--:-- 0:00:41 13389
100 548k 100 548k 0 0 490k 0 0:00:01 0:00:01 --:--:-- 490k
-> Downloading firefox-esr-i18n-115.4.0-es-MX.xpi...
0 552k 0 5503 0 0 15471 0 0:00:36 --:--:-- 0:00:36 15501
100 552k 100 552k 0 0 729k 0 --:--:-- --:--:-- --:--:-- 729k
-> Downloading firefox-esr-i18n-115.4.0-et.xpi...
12 504k 12 66226 0 0 131k 0 0:00:03 --:--:-- 0:00:03 131k
100 504k 100 504k 0 0 813k 0 --:--:-- --:--:-- --:--:-- 812k
-> Downloading firefox-esr-i18n-115.4.0-eu.xpi...
8 538k 8 44400 0 0 59028 0 0:00:09 --:--:-- 0:00:09 59042
100 538k 100 538k 0 0 390k 0 0:00:01 0:00:01 --:--:-- 390k
-> Downloading firefox-esr-i18n-115.4.0-fa.xpi...
0 551k 0 3333 0 0 8679 0 0:01:05 --:--:-- 0:01:05 8679
100 551k 100 551k 0 0 788k 0 --:--:-- --:--:-- --:--:-- 787k
-> Downloading firefox-esr-i18n-115.4.0-ff.xpi...
7 446k 7 34746 0 0 52988 0 0:00:08 --:--:-- 0:00:08 52966
100 446k 100 446k 0 0 297k 0 0:00:01 0:00:01 --:--:-- 297k
-> Downloading firefox-esr-i18n-115.4.0-fi.xpi...
21 538k 21 117k 0 0 115k 0 0:00:04 0:00:01 0:00:03 115k
100 538k 100 538k 0 0 379k 0 0:00:01 0:00:01 --:--:-- 379k
-> Downloading firefox-esr-i18n-115.4.0-fr.xpi...
99 566k 99 564k 0 0 810k 0 --:--:-- --:--:-- --:--:-- 810k
100 566k 100 566k 0 0 798k 0 --:--:-- --:--:-- --:--:-- 797k
-> Downloading firefox-esr-i18n-115.4.0-fy-NL.xpi...
100 551k 100 551k 0 0 954k 0 --:--:-- --:--:-- --:--:-- 956k
-> Downloading firefox-esr-i18n-115.4.0-ga-IE.xpi...
100 443k 100 443k 0 0 695k 0 --:--:-- --:--:-- --:--:-- 695k
-> Downloading firefox-esr-i18n-115.4.0-gd.xpi...
100 553k 100 553k 0 0 1262k 0 --:--:-- --:--:-- --:--:-- 1264k
-> Downloading firefox-esr-i18n-115.4.0-gl.xpi...
100 552k 100 552k 0 0 783k 0 --:--:-- --:--:-- --:--:-- 784k
-> Downloading firefox-esr-i18n-115.4.0-gn.xpi...
0 564k 0 2747 0 0 6573 0 0:01:27 --:--:-- 0:01:27 6571
100 564k 100 564k 0 0 670k 0 --:--:-- --:--:-- --:--:-- 669k
-> Downloading firefox-esr-i18n-115.4.0-gu-IN.xpi...
13 494k 13 66217 0 0 136k 0 0:00:03 --:--:-- 0:00:03 136k
100 494k 100 494k 0 0 832k 0 --:--:-- --:--:-- --:--:-- 831k
-> Downloading firefox-esr-i18n-115.4.0-he.xpi...
83 560k 83 467k 0 0 640k 0 --:--:-- --:--:-- --:--:-- 640k
100 560k 100 560k 0 0 759k 0 --:--:-- --:--:-- --:--:-- 759k
-> Downloading firefox-esr-i18n-115.4.0-hi-IN.xpi...
100 526k 100 526k 0 0 760k 0 --:--:-- --:--:-- --:--:-- 761k
-> Downloading firefox-esr-i18n-115.4.0-hr.xpi...
100 519k 100 519k 0 0 865k 0 --:--:-- --:--:-- --:--:-- 865k
-> Downloading firefox-esr-i18n-115.4.0-hsb.xpi...
5 571k 5 29688 0 0 45485 0 0:00:12 --:--:-- 0:00:12 45464
78 571k 78 448k 0 0 292k 0 0:00:01 0:00:01 --:--:-- 292k
100 571k 100 571k 0 0 359k 0 0:00:01 0:00:01 --:--:-- 359k
-> Downloading firefox-esr-i18n-115.4.0-hu.xpi...
100 575k 100 575k 0 0 662k 0 --:--:-- --:--:-- --:--:-- 663k
-> Downloading firefox-esr-i18n-115.4.0-hy-AM.xpi...
96 565k 96 543k 0 0 556k 0 0:00:01 --:--:-- 0:00:01 556k
100 565k 100 565k 0 0 575k 0 --:--:-- --:--:-- --:--:-- 574k
-> Downloading firefox-esr-i18n-115.4.0-ia.xpi...
100 540k 100 540k 0 0 1093k 0 --:--:-- --:--:-- --:--:-- 1095k
-> Downloading firefox-esr-i18n-115.4.0-id.xpi...
1 525k 1 10178 0 0 25017 0 0:00:21 --:--:-- 0:00:21 25007
100 525k 100 525k 0 0 405k 0 0:00:01 0:00:01 --:--:-- 405k
-> Downloading firefox-esr-i18n-115.4.0-is.xpi...
100 547k 100 547k 0 0 650k 0 --:--:-- --:--:-- --:--:-- 650k
-> Downloading firefox-esr-i18n-115.4.0-it.xpi...
100 495k 100 495k 0 0 1076k 0 --:--:-- --:--:-- --:--:-- 1075k
-> Downloading firefox-esr-i18n-115.4.0-ja.xpi...
18 619k 18 113k 0 0 174k 0 0:00:03 --:--:-- 0:00:03 174k
100 619k 100 619k 0 0 614k 0 0:00:01 0:00:01 --:--:-- 615k
-> Downloading firefox-esr-i18n-115.4.0-ka.xpi...
82 596k 82 490k 0 0 756k 0 --:--:-- --:--:-- --:--:-- 756k
100 596k 100 596k 0 0 823k 0 --:--:-- --:--:-- --:--:-- 823k
-> Downloading firefox-esr-i18n-115.4.0-kab.xpi...
20 549k 20 109k 0 0 119k 0 0:00:04 --:--:-- 0:00:04 119k
100 549k 100 549k 0 0 423k 0 0:00:01 0:00:01 --:--:-- 423k
-> Downloading firefox-esr-i18n-115.4.0-kk.xpi...
10 624k 10 66221 0 0 122k 0 0:00:05 --:--:-- 0:00:05 122k
100 624k 100 624k 0 0 729k 0 --:--:-- --:--:-- --:--:-- 729k
-> Downloading firefox-esr-i18n-115.4.0-km.xpi...
91 496k 91 452k 0 0 711k 0 --:--:-- --:--:-- --:--:-- 711k
100 496k 100 496k 0 0 775k 0 --:--:-- --:--:-- --:--:-- 775k
-> Downloading firefox-esr-i18n-115.4.0-kn.xpi...
52 462k 52 241k 0 0 267k 0 0:00:01 --:--:-- 0:00:01 267k
100 462k 100 462k 0 0 443k 0 0:00:01 0:00:01 --:--:-- 444k
-> Downloading firefox-esr-i18n-115.4.0-ko.xpi...
100 586k 100 586k 0 0 1029k 0 --:--:-- --:--:-- --:--:-- 1032k
-> Downloading firefox-esr-i18n-115.4.0-lij.xpi...
100 452k 100 452k 0 0 1051k 0 --:--:-- --:--:-- --:--:-- 1050k
-> Downloading firefox-esr-i18n-115.4.0-lt.xpi...
100 535k 100 535k 0 0 1199k 0 --:--:-- --:--:-- --:--:-- 1200k
-> Downloading firefox-esr-i18n-115.4.0-lv.xpi...
1 440k 1 5503 0 0 14681 0 0:00:30 --:--:-- 0:00:30 14674
100 440k 100 440k 0 0 676k 0 --:--:-- --:--:-- --:--:-- 676k
-> Downloading firefox-esr-i18n-115.4.0-mk.xpi...
5 459k 5 25230 0 0 44489 0 0:00:10 --:--:-- 0:00:10 44497
100 459k 100 459k 0 0 333k 0 0:00:01 0:00:01 --:--:-- 333k
-> Downloading firefox-esr-i18n-115.4.0-mr.xpi...
100 498k 100 498k 0 0 599k 0 --:--:-- --:--:-- --:--:-- 599k
-> Downloading firefox-esr-i18n-115.4.0-ms.xpi...
1 421k 1 5503 0 0 20170 0 0:00:21 --:--:-- 0:00:21 20157
100 421k 100 421k 0 0 1244k 0 --:--:-- --:--:-- --:--:-- 1242k
-> Downloading firefox-esr-i18n-115.4.0-my.xpi...
100 482k 100 482k 0 0 1027k 0 --:--:-- --:--:-- --:--:-- 1027k
-> Downloading firefox-esr-i18n-115.4.0-nb-NO.xpi...
49 536k 49 265k 0 0 779k 0 --:--:-- --:--:-- --:--:-- 778k
100 536k 100 536k 0 0 1097k 0 --:--:-- --:--:-- --:--:-- 1096k
-> Downloading firefox-esr-i18n-115.4.0-ne-NP.xpi...
17 458k 17 82936 0 0 99k 0 0:00:04 --:--:-- 0:00:04 99k
100 458k 100 458k 0 0 369k 0 0:00:01 0:00:01 --:--:-- 369k
-> Downloading firefox-esr-i18n-115.4.0-nl.xpi...
33 546k 33 184k 0 0 356k 0 0:00:01 --:--:-- 0:00:01 356k
100 546k 100 546k 0 0 802k 0 --:--:-- --:--:-- --:--:-- 801k
-> Downloading firefox-esr-i18n-115.4.0-nn-NO.xpi...
100 539k 100 539k 0 0 1050k 0 --:--:-- --:--:-- --:--:-- 1052k
-> Downloading firefox-esr-i18n-115.4.0-oc.xpi...
0 558k 0 3335 0 0 8366 0 0:01:08 --:--:-- 0:01:08 8358
100 558k 100 558k 0 0 519k 0 0:00:01 0:00:01 --:--:-- 520k
-> Downloading firefox-esr-i18n-115.4.0-pa-IN.xpi...
100 611k 100 611k 0 0 641k 0 --:--:-- --:--:-- --:--:-- 640k
-> Downloading firefox-esr-i18n-115.4.0-pl.xpi...
100 566k 100 566k 0 0 705k 0 --:--:-- --:--:-- --:--:-- 705k
-> Downloading firefox-esr-i18n-115.4.0-pt-BR.xpi...
0 550k 0 4125 0 0 13128 0 0:00:42 --:--:-- 0:00:42 13136
100 550k 100 550k 0 0 1188k 0 --:--:-- --:--:-- --:--:-- 1186k
-> Downloading firefox-esr-i18n-115.4.0-pt-PT.xpi...
100 555k 100 555k 0 0 933k 0 --:--:-- --:--:-- --:--:-- 935k
-> Downloading firefox-esr-i18n-115.4.0-rm.xpi...
100 545k 100 545k 0 0 948k 0 --:--:-- --:--:-- --:--:-- 947k
-> Downloading firefox-esr-i18n-115.4.0-ro.xpi...
12 512k 12 63549 0 0 120k 0 0:00:04 --:--:-- 0:00:04 120k
100 512k 100 512k 0 0 538k 0 --:--:-- --:--:-- --:--:-- 538k
-> Downloading firefox-esr-i18n-115.4.0-ru.xpi...
86 636k 86 549k 0 0 854k 0 --:--:-- --:--:-- --:--:-- 854k
100 636k 100 636k 0 0 924k 0 --:--:-- --:--:-- --:--:-- 924k
-> Downloading firefox-esr-i18n-115.4.0-si.xpi...
100 555k 100 555k 0 0 936k 0 --:--:-- --:--:-- --:--:-- 938k
-> Downloading firefox-esr-i18n-115.4.0-sk.xpi...
100 575k 100 575k 0 0 1012k 0 --:--:-- --:--:-- --:--:-- 1012k
-> Downloading firefox-esr-i18n-115.4.0-sl.xpi...
11 549k 11 64821 0 0 128k 0 0:00:04 --:--:-- 0:00:04 128k
100 549k 100 549k 0 0 633k 0 --:--:-- --:--:-- --:--:-- 632k
-> Downloading firefox-esr-i18n-115.4.0-son.xpi...
100 391k 100 391k 0 0 701k 0 --:--:-- --:--:-- --:--:-- 703k
-> Downloading firefox-esr-i18n-115.4.0-sq.xpi...
14 551k 14 81725 0 0 83356 0 0:00:06 --:--:-- 0:00:06 83307
100 551k 100 551k 0 0 364k 0 0:00:01 0:00:01 --:--:-- 364k
-> Downloading firefox-esr-i18n-115.4.0-sr.xpi...
10 599k 10 66237 0 0 134k 0 0:00:04 --:--:-- 0:00:04 134k
100 599k 100 599k 0 0 1079k 0 --:--:-- --:--:-- --:--:-- 1078k
-> Downloading firefox-esr-i18n-115.4.0-sv-SE.xpi...
82 547k 82 448k 0 0 541k 0 0:00:01 --:--:-- 0:00:01 541k
100 547k 100 547k 0 0 614k 0 --:--:-- --:--:-- --:--:-- 614k
-> Downloading firefox-esr-i18n-115.4.0-ta.xpi...
30 477k 30 147k 0 0 167k 0 0:00:02 --:--:-- 0:00:02 167k
100 477k 100 477k 0 0 418k 0 0:00:01 0:00:01 --:--:-- 419k
-> Downloading firefox-esr-i18n-115.4.0-te.xpi...
9 523k 9 49656 0 0 69892 0 0:00:07 --:--:-- 0:00:07 69839
100 523k 100 523k 0 0 368k 0 0:00:01 0:00:01 --:--:-- 368k
-> Downloading firefox-esr-i18n-115.4.0-th.xpi...
0 617k 0 2747 0 0 6746 0 0:01:33 --:--:-- 0:01:33 6749
100 617k 100 617k 0 0 1192k 0 --:--:-- --:--:-- --:--:-- 1191k
-> Downloading firefox-esr-i18n-115.4.0-tl.xpi...
12 499k 12 64767 0 0 96839 0 0:00:05 --:--:-- 0:00:05 96811
100 499k 100 499k 0 0 448k 0 0:00:01 0:00:01 --:--:-- 449k
-> Downloading firefox-esr-i18n-115.4.0-tr.xpi...
11 559k 11 66223 0 0 118k 0 0:00:04 --:--:-- 0:00:04 118k
100 559k 100 559k 0 0 643k 0 --:--:-- --:--:-- --:--:-- 643k
-> Downloading firefox-esr-i18n-115.4.0-trs.xpi...
17 468k 17 82830 0 0 138k 0 0:00:03 --:--:-- 0:00:03 138k
100 468k 100 468k 0 0 744k 0 --:--:-- --:--:-- --:--:-- 744k
-> Downloading firefox-esr-i18n-115.4.0-uk.xpi...
14 629k 14 92144 0 0 98k 0 0:00:06 --:--:-- 0:00:06 98k
100 629k 100 629k 0 0 457k 0 0:00:01 0:00:01 --:--:-- 457k
-> Downloading firefox-esr-i18n-115.4.0-ur.xpi...
84 526k 84 446k 0 0 691k 0 --:--:-- --:--:-- --:--:-- 691k
100 526k 100 526k 0 0 743k 0 --:--:-- --:--:-- --:--:-- 743k
-> Downloading firefox-esr-i18n-115.4.0-uz.xpi...
20 450k 20 96240 0 0 129k 0 0:00:03 --:--:-- 0:00:03 129k
100 450k 100 450k 0 0 385k 0 0:00:01 0:00:01 --:--:-- 386k
-> Downloading firefox-esr-i18n-115.4.0-vi.xpi...
11 581k 11 66223 0 0 118k 0 0:00:04 --:--:-- 0:00:04 118k
100 581k 100 581k 0 0 940k 0 --:--:-- --:--:-- --:--:-- 939k
-> Downloading firefox-esr-i18n-115.4.0-xh.xpi...
100 393k 100 393k 0 0 1111k 0 --:--:-- --:--:-- --:--:-- 1113k
-> Downloading firefox-esr-i18n-115.4.0-zh-CN.xpi...
10 581k 10 64821 0 0 114k 0 0:00:05 --:--:-- 0:00:05 114k
100 581k 100 581k 0 0 466k 0 0:00:01 0:00:01 --:--:-- 467k
-> Downloading firefox-esr-i18n-115.4.0-zh-TW.xpi...
100 583k 100 583k 0 0 873k 0 --:--:-- --:--:-- --:--:-- 872k
==> Validating source files with sha512sums...
firefox-115.4.0esr.source.tar.xz ... Passed
firefox-115.4.0esr.source.tar.xz.asc ... Skipped
firefox-esr.desktop ... Passed
identity-icons-brand.svg ... Passed
firefox-esr-i18n-115.4.0-ach.xpi ... Passed
firefox-esr-i18n-115.4.0-af.xpi ... Passed
firefox-esr-i18n-115.4.0-an.xpi ... Passed
firefox-esr-i18n-115.4.0-ar.xpi ... Passed
firefox-esr-i18n-115.4.0-ast.xpi ... Passed
firefox-esr-i18n-115.4.0-az.xpi ... Passed
firefox-esr-i18n-115.4.0-be.xpi ... Passed
firefox-esr-i18n-115.4.0-bg.xpi ... Passed
firefox-esr-i18n-115.4.0-bn.xpi ... Passed
firefox-esr-i18n-115.4.0-br.xpi ... Passed
firefox-esr-i18n-115.4.0-bs.xpi ... Passed
firefox-esr-i18n-115.4.0-ca-valencia.xpi ... Passed
firefox-esr-i18n-115.4.0-ca.xpi ... Passed
firefox-esr-i18n-115.4.0-cak.xpi ... Passed
firefox-esr-i18n-115.4.0-cs.xpi ... Passed
firefox-esr-i18n-115.4.0-cy.xpi ... Passed
firefox-esr-i18n-115.4.0-da.xpi ... Passed
firefox-esr-i18n-115.4.0-de.xpi ... Passed
firefox-esr-i18n-115.4.0-dsb.xpi ... Passed
firefox-esr-i18n-115.4.0-el.xpi ... Passed
firefox-esr-i18n-115.4.0-en-CA.xpi ... Passed
firefox-esr-i18n-115.4.0-en-GB.xpi ... Passed
firefox-esr-i18n-115.4.0-en-US.xpi ... Passed
firefox-esr-i18n-115.4.0-eo.xpi ... Passed
firefox-esr-i18n-115.4.0-es-AR.xpi ... Passed
firefox-esr-i18n-115.4.0-es-CL.xpi ... Passed
firefox-esr-i18n-115.4.0-es-ES.xpi ... Passed
firefox-esr-i18n-115.4.0-es-MX.xpi ... Passed
firefox-esr-i18n-115.4.0-et.xpi ... Passed
firefox-esr-i18n-115.4.0-eu.xpi ... Passed
firefox-esr-i18n-115.4.0-fa.xpi ... Passed
firefox-esr-i18n-115.4.0-ff.xpi ... Passed
firefox-esr-i18n-115.4.0-fi.xpi ... Passed
firefox-esr-i18n-115.4.0-fr.xpi ... Passed
firefox-esr-i18n-115.4.0-fy-NL.xpi ... Passed
firefox-esr-i18n-115.4.0-ga-IE.xpi ... Passed
firefox-esr-i18n-115.4.0-gd.xpi ... Passed
firefox-esr-i18n-115.4.0-gl.xpi ... Passed
firefox-esr-i18n-115.4.0-gn.xpi ... Passed
firefox-esr-i18n-115.4.0-gu-IN.xpi ... Passed
firefox-esr-i18n-115.4.0-he.xpi ... Passed
firefox-esr-i18n-115.4.0-hi-IN.xpi ... Passed
firefox-esr-i18n-115.4.0-hr.xpi ... Passed
firefox-esr-i18n-115.4.0-hsb.xpi ... Passed
firefox-esr-i18n-115.4.0-hu.xpi ... Passed
firefox-esr-i18n-115.4.0-hy-AM.xpi ... Passed
firefox-esr-i18n-115.4.0-ia.xpi ... Passed
firefox-esr-i18n-115.4.0-id.xpi ... Passed
firefox-esr-i18n-115.4.0-is.xpi ... Passed
firefox-esr-i18n-115.4.0-it.xpi ... Passed
firefox-esr-i18n-115.4.0-ja.xpi ... Passed
firefox-esr-i18n-115.4.0-ka.xpi ... Passed
firefox-esr-i18n-115.4.0-kab.xpi ... Passed
firefox-esr-i18n-115.4.0-kk.xpi ... Passed
firefox-esr-i18n-115.4.0-km.xpi ... Passed
firefox-esr-i18n-115.4.0-kn.xpi ... Passed
firefox-esr-i18n-115.4.0-ko.xpi ... Passed
firefox-esr-i18n-115.4.0-lij.xpi ... Passed
firefox-esr-i18n-115.4.0-lt.xpi ... Passed
firefox-esr-i18n-115.4.0-lv.xpi ... Passed
firefox-esr-i18n-115.4.0-mk.xpi ... Passed
firefox-esr-i18n-115.4.0-mr.xpi ... Passed
firefox-esr-i18n-115.4.0-ms.xpi ... Passed
firefox-esr-i18n-115.4.0-my.xpi ... Passed
firefox-esr-i18n-115.4.0-nb-NO.xpi ... Passed
firefox-esr-i18n-115.4.0-ne-NP.xpi ... Passed
firefox-esr-i18n-115.4.0-nl.xpi ... Passed
firefox-esr-i18n-115.4.0-nn-NO.xpi ... Passed
firefox-esr-i18n-115.4.0-oc.xpi ... Passed
firefox-esr-i18n-115.4.0-pa-IN.xpi ... Passed
firefox-esr-i18n-115.4.0-pl.xpi ... Passed
firefox-esr-i18n-115.4.0-pt-BR.xpi ... Passed
firefox-esr-i18n-115.4.0-pt-PT.xpi ... Passed
firefox-esr-i18n-115.4.0-rm.xpi ... Passed
firefox-esr-i18n-115.4.0-ro.xpi ... Passed
firefox-esr-i18n-115.4.0-ru.xpi ... Passed
firefox-esr-i18n-115.4.0-si.xpi ... Passed
firefox-esr-i18n-115.4.0-sk.xpi ... Passed
firefox-esr-i18n-115.4.0-sl.xpi ... Passed
firefox-esr-i18n-115.4.0-son.xpi ... Passed
firefox-esr-i18n-115.4.0-sq.xpi ... Passed
firefox-esr-i18n-115.4.0-sr.xpi ... Passed
firefox-esr-i18n-115.4.0-sv-SE.xpi ... Passed
firefox-esr-i18n-115.4.0-ta.xpi ... Passed
firefox-esr-i18n-115.4.0-te.xpi ... Passed
firefox-esr-i18n-115.4.0-th.xpi ... Passed
firefox-esr-i18n-115.4.0-tl.xpi ... Passed
firefox-esr-i18n-115.4.0-tr.xpi ... Passed
firefox-esr-i18n-115.4.0-trs.xpi ... Passed
firefox-esr-i18n-115.4.0-uk.xpi ... Passed
firefox-esr-i18n-115.4.0-ur.xpi ... Passed
firefox-esr-i18n-115.4.0-uz.xpi ... Passed
firefox-esr-i18n-115.4.0-vi.xpi ... Passed
firefox-esr-i18n-115.4.0-xh.xpi ... Passed
firefox-esr-i18n-115.4.0-zh-CN.xpi ... Passed
firefox-esr-i18n-115.4.0-zh-TW.xpi ... Passed
==> Verifying source file signatures with gpg...
==> Extracting sources...
-> Extracting firefox-115.4.0esr.source.tar.xz with bsdtar
==> Starting prepare()...
firefox-esr-i18n-115.4.0-ach.xpi firefox-esr-i18n-115.4.0-af.xpi firefox-esr-i18n-115.4.0-an.xpi firefox-esr-i18n-115.4.0-ar.xpi firefox-esr-i18n-115.4.0-ast.xpi firefox-esr-i18n-115.4.0-az.xpi firefox-esr-i18n-115.4.0-be.xpi firefox-esr-i18n-115.4.0-bg.xpi firefox-esr-i18n-115.4.0-bn.xpi firefox-esr-i18n-115.4.0-br.xpi firefox-esr-i18n-115.4.0-bs.xpi firefox-esr-i18n-115.4.0-ca-valencia.xpi firefox-esr-i18n-115.4.0-ca.xpi firefox-esr-i18n-115.4.0-cak.xpi firefox-esr-i18n-115.4.0-cs.xpi firefox-esr-i18n-115.4.0-cy.xpi firefox-esr-i18n-115.4.0-da.xpi firefox-esr-i18n-115.4.0-de.xpi firefox-esr-i18n-115.4.0-dsb.xpi firefox-esr-i18n-115.4.0-el.xpi firefox-esr-i18n-115.4.0-en-CA.xpi firefox-esr-i18n-115.4.0-en-GB.xpi firefox-esr-i18n-115.4.0-en-US.xpi firefox-esr-i18n-115.4.0-eo.xpi firefox-esr-i18n-115.4.0-es-AR.xpi firefox-esr-i18n-115.4.0-es-CL.xpi firefox-esr-i18n-115.4.0-es-ES.xpi firefox-esr-i18n-115.4.0-es-MX.xpi firefox-esr-i18n-115.4.0-et.xpi firefox-esr-i18n-115.4.0-eu.xpi firefox-esr-i18n-115.4.0-fa.xpi firefox-esr-i18n-115.4.0-ff.xpi firefox-esr-i18n-115.4.0-fi.xpi firefox-esr-i18n-115.4.0-fr.xpi firefox-esr-i18n-115.4.0-fy-NL.xpi firefox-esr-i18n-115.4.0-ga-IE.xpi firefox-esr-i18n-115.4.0-gd.xpi firefox-esr-i18n-115.4.0-gl.xpi firefox-esr-i18n-115.4.0-gn.xpi firefox-esr-i18n-115.4.0-gu-IN.xpi firefox-esr-i18n-115.4.0-he.xpi firefox-esr-i18n-115.4.0-hi-IN.xpi firefox-esr-i18n-115.4.0-hr.xpi firefox-esr-i18n-115.4.0-hsb.xpi firefox-esr-i18n-115.4.0-hu.xpi firefox-esr-i18n-115.4.0-hy-AM.xpi firefox-esr-i18n-115.4.0-ia.xpi firefox-esr-i18n-115.4.0-id.xpi firefox-esr-i18n-115.4.0-is.xpi firefox-esr-i18n-115.4.0-it.xpi firefox-esr-i18n-115.4.0-ja.xpi firefox-esr-i18n-115.4.0-ka.xpi firefox-esr-i18n-115.4.0-kab.xpi firefox-esr-i18n-115.4.0-kk.xpi firefox-esr-i18n-115.4.0-km.xpi firefox-esr-i18n-115.4.0-kn.xpi firefox-esr-i18n-115.4.0-ko.xpi firefox-esr-i18n-115.4.0-lij.xpi firefox-esr-i18n-115.4.0-lt.xpi firefox-esr-i18n-115.4.0-lv.xpi firefox-esr-i18n-115.4.0-mk.xpi firefox-esr-i18n-115.4.0-mr.xpi firefox-esr-i18n-115.4.0-ms.xpi firefox-esr-i18n-115.4.0-my.xpi firefox-esr-i18n-115.4.0-nb-NO.xpi firefox-esr-i18n-115.4.0-ne-NP.xpi firefox-esr-i18n-115.4.0-nl.xpi firefox-esr-i18n-115.4.0-nn-NO.xpi firefox-esr-i18n-115.4.0-oc.xpi firefox-esr-i18n-115.4.0-pa-IN.xpi firefox-esr-i18n-115.4.0-pl.xpi firefox-esr-i18n-115.4.0-pt-BR.xpi firefox-esr-i18n-115.4.0-pt-PT.xpi firefox-esr-i18n-115.4.0-rm.xpi firefox-esr-i18n-115.4.0-ro.xpi firefox-esr-i18n-115.4.0-ru.xpi firefox-esr-i18n-115.4.0-si.xpi firefox-esr-i18n-115.4.0-sk.xpi firefox-esr-i18n-115.4.0-sl.xpi firefox-esr-i18n-115.4.0-son.xpi firefox-esr-i18n-115.4.0-sq.xpi firefox-esr-i18n-115.4.0-sr.xpi firefox-esr-i18n-115.4.0-sv-SE.xpi firefox-esr-i18n-115.4.0-ta.xpi firefox-esr-i18n-115.4.0-te.xpi firefox-esr-i18n-115.4.0-th.xpi firefox-esr-i18n-115.4.0-tl.xpi firefox-esr-i18n-115.4.0-tr.xpi firefox-esr-i18n-115.4.0-trs.xpi firefox-esr-i18n-115.4.0-uk.xpi firefox-esr-i18n-115.4.0-ur.xpi firefox-esr-i18n-115.4.0-uz.xpi firefox-esr-i18n-115.4.0-vi.xpi firefox-esr-i18n-115.4.0-xh.xpi firefox-esr-i18n-115.4.0-zh-CN.xpi firefox-esr-i18n-115.4.0-zh-TW.xpi
==> Starting build()...
Building instrumented browser...
Collecting glean-sdk==52.7.0
Downloading glean-sdk-52.7.0.tar.gz (2.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.3/2.3 MB 5.3 MB/s eta 0:00:00
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting semver>=2.13.0
Downloading semver-3.0.2-py3-none-any.whl (17 kB)
Requirement already satisfied: glean_parser~=7.1 in ./third_party/python/glean_parser (from glean-sdk==52.7.0) (7.2.1)
Requirement already satisfied: appdirs>=1.4 in ./third_party/python/appdirs (from glean_parser~=7.1->glean-sdk==52.7.0) (1.4.4)
Requirement already satisfied: Click>=7 in ./third_party/python/click (from glean_parser~=7.1->glean-sdk==52.7.0) (7.1.2)
Requirement already satisfied: diskcache>=4 in ./third_party/python/diskcache (from glean_parser~=7.1->glean-sdk==52.7.0) (4.1.0)
Requirement already satisfied: Jinja2>=2.10.1 in ./third_party/python/Jinja2 (from glean_parser~=7.1->glean-sdk==52.7.0) (2.11.3)
Requirement already satisfied: MarkupSafe<=2.0.1,>=1.1.1 in ./third_party/python/MarkupSafe/src (from glean_parser~=7.1->glean-sdk==52.7.0) (2.0.1)
Requirement already satisfied: jsonschema>=3.0.2 in ./third_party/python/jsonschema (from glean_parser~=7.1->glean-sdk==52.7.0) (4.17.3)
Requirement already satisfied: PyYAML>=5.3.1 in ./third_party/python/PyYAML/lib3 (from glean_parser~=7.1->glean-sdk==52.7.0) (5.4.1)
Requirement already satisfied: attrs>=17.4.0 in ./third_party/python/attrs (from jsonschema>=3.0.2->glean_parser~=7.1->glean-sdk==52.7.0) (23.1.0)
Requirement already satisfied: pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0 in ./third_party/python/pyrsistent (from jsonschema>=3.0.2->glean_parser~=7.1->glean-sdk==52.7.0) (0.16.0)
Requirement already satisfied: six in ./third_party/python/six (from pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0->jsonschema>=3.0.2->glean_parser~=7.1->glean-sdk==52.7.0) (1.13.0)
Building wheels for collected packages: glean-sdk
Building wheel for glean-sdk (setup.py): started
Building wheel for glean-sdk (setup.py): still running...
Building wheel for glean-sdk (setup.py): finished with status 'done'
Created wheel for glean-sdk: filename=glean_sdk-52.7.0-cp36-abi3-linux_aarch64.whl size=8440273 sha256=d980bbd2fc713518f1621391083076231345b060290ef1daec303a3583fb42ce
Stored in directory: /home/user/.cache/pip/wheels/12/e1/41/f11bcde48dbe9538598f98fc756d0dd3b67e87144530ebee13
Successfully built glean-sdk
Installing collected packages: semver, glean-sdk
Successfully installed glean-sdk-52.7.0 semver-3.0.2
Collecting psutil<=5.9.4,>=5.4.2
Downloading psutil-5.9.4.tar.gz (485 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 485.8/485.8 kB 4.4 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Building wheels for collected packages: psutil
Building wheel for psutil (pyproject.toml): started
Building wheel for psutil (pyproject.toml): finished with status 'done'
Created wheel for psutil: filename=psutil-5.9.4-cp311-abi3-linux_aarch64.whl size=279465 sha256=c1a36c268511b270482fcce063eb2157760eec99ccb686109496a8d35115895e
Stored in directory: /home/user/.cache/pip/wheels/8a/1e/ad/6603c49d4802a689d24cbdea92450a70666ef00baab3f5d59b
Successfully built psutil
Installing collected packages: psutil
Successfully installed psutil-5.9.4
Collecting zstandard<=0.19.0,>=0.11.1
Downloading zstandard-0.19.0-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (2.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.3/2.3 MB 8.1 MB/s eta 0:00:00
Installing collected packages: zstandard
Successfully installed zstandard-0.19.0
Creating local state directory: /var/tmp/pamac-build-user/firefox-esr/src/mozbuild/srcdirs/firefox-115.4.0-e9e05ffbd2d2
Site not up-to-date reason: "/var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/obj/_virtualenvs/build" does not exist
0:04.28 Clobber not needed.
0:04.96 Using Python 3.11.5 from /var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/obj/_virtualenvs/build/bin/python
0:04.96 Adding configure options from /var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/.mozconfig
0:04.96 --enable-application=browser
0:04.96 --prefix=/usr
0:04.96 --enable-release
0:04.96 --enable-hardening
0:04.96 --enable-optimize
0:04.96 --enable-rust-simd
0:04.96 --enable-linker=lld
0:04.96 --disable-elf-hack
0:04.96 --disable-bootstrap
0:04.96 --with-wasi-sysroot=/usr/share/wasi-sysroot
0:04.96 --enable-official-branding
0:04.96 --enable-update-channel=release
0:04.96 --with-distribution-id=org.archlinux
0:04.96 --with-unsigned-addon-scopes=app,system
0:04.96 --allow-addon-sideload
0:04.96 --with-app-name=firefox-esr
0:04.96 --with-google-location-service-api-keyfile=/var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/google-api-key
0:04.96 --with-google-safebrowsing-api-keyfile=/var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/google-api-key
0:04.96 --with-mozilla-api-keyfile=/var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/mozilla-api-key
0:04.96 --with-system-nspr
0:04.96 --with-system-nss
0:04.96 --enable-alsa
0:04.96 --enable-jack
0:04.96 --enable-crashreporter
0:04.96 --disable-updater
0:04.96 --disable-tests
0:04.96 --enable-profile-generate=cross
0:04.96 MOZ_APP_PROFILE=mozilla/firefox-esr
0:04.96 MOZILLA_OFFICIAL=1
0:04.96 MOZ_APP_REMOTINGNAME=firefox-esr
0:04.96 checking for vcs source checkout... no
0:05.15 checking for a shell... /usr/bin/sh
0:05.29 checking for host system type... aarch64-unknown-linux-gnu
0:05.29 checking for target system type... aarch64-unknown-linux-gnu
0:07.12 checking whether cross compiling... no
0:08.07 checking for Python 3... /var/tmp/pamac-build-user/firefox-esr/src/firefox-115.4.0/obj/_virtualenvs/build/bin/python (3.11.5)
0:08.12 checking for wget... /usr/bin/wget
0:08.13 checking for ccache... not found
0:08.14 checking for the target C compiler... /usr/bin/clang
0:08.48 checking whether the target C compiler can be used... yes
0:08.48 checking the target C compiler version... 16.0.6
0:08.55 checking the target C compiler works... yes
0:08.55 checking for the target C++ compiler... /usr/bin/clang++
0:08.69 checking whether the target C++ compiler can be used... yes
0:08.69 checking the target C++ compiler version... 16.0.6
0:08.78 checking the target C++ compiler works... yes
0:08.78 checking for the host C compiler... /usr/bin/clang
0:08.79 checking whether the host C compiler can be used... yes
0:08.79 checking the host C compiler version... 16.0.6
0:08.79 checking the host C compiler works... yes
0:08.79 checking for the host C++ compiler... /usr/bin/clang++
0:08.79 checking whether the host C++ compiler can be used... yes
0:08.79 checking the host C++ compiler version... 16.0.6
0:08.80 checking the host C++ compiler works... yes
0:08.93 checking for target linker... lld
0:09.08 checking for host linker... lld
0:09.17 checking for 64-bit OS... yes
0:09.26 checking for new enough STL headers from libstdc++... yes
0:09.34 checking for the assembler... /usr/bin/clang
0:09.41 checking for ar... /usr/bin/llvm-ar
0:09.47 checking for host_ar... /usr/bin/llvm-ar
0:09.54 checking for nm... /usr/bin/llvm-nm
0:09.54 checking for pkg_config... /usr/bin/pkg-config
0:09.55 checking for pkg-config version... 1.8.1
0:09.55 checking whether pkg-config is pkgconf... yes
0:09.77 checking for strndup... yes
0:09.98 checking for posix_memalign... yes
0:10.19 checking for memalign... yes
0:10.38 checking for malloc_usable_size... yes
0:10.47 checking for stdint.h... yes
0:10.56 checking for inttypes.h... yes
0:10.66 checking for malloc.h... yes
0:10.74 checking for alloca.h... yes
0:10.82 checking for sys/byteorder.h... no
0:10.90 checking for getopt.h... yes
0:11.00 checking for unistd.h... yes
0:11.08 checking for nl_types.h... yes
0:11.16 checking for cpuid.h... no
0:11.26 checking for fts.h... yes
0:11.35 checking for sys/statvfs.h... yes
0:11.44 checking for sys/statfs.h... yes
0:11.52 checking for sys/vfs.h... yes
0:11.61 checking for sys/mount.h... yes
0:11.71 checking for sys/quota.h... yes
0:11.81 checking for linux/quota.h... yes
0:11.91 checking for linux/if_addr.h... yes
0:12.01 checking for linux/rtnetlink.h... yes
0:12.09 checking for sys/queue.h... yes
0:12.18 checking for sys/types.h... yes
0:12.27 checking for netinet/in.h... yes
0:12.36 checking for byteswap.h... yes
0:12.44 checking for memfd_create in sys/mman.h... yes
0:12.54 checking for linux/perf_event.h... yes
0:12.62 checking for perf_event_open system call... yes
0:12.70 checking whether the C compiler supports -Wbitfield-enum-conversion... yes
0:12.79 checking whether the C++ compiler supports -Wbitfield-enum-conversion... yes
0:12.87 checking whether the C++ compiler supports -Wdeprecated-this-capture... yes
0:12.94 checking whether the C compiler supports -Wformat-type-confusion... yes
0:13.01 checking whether the C++ compiler supports -Wformat-type-confusion... yes
0:13.09 checking whether the C compiler supports -Wshadow-field-in-constructor-modified... yes
0:13.18 checking whether the C++ compiler supports -Wshadow-field-in-constructor-modified... yes
0:13.26 checking whether the C compiler supports -Wtautological-constant-in-range-compare... yes
0:13.34 checking whether the C++ compiler supports -Wtautological-constant-in-range-compare... yes
0:13.42 checking whether the C compiler supports -Wno-error=tautological-type-limit-compare... yes
0:13.50 checking whether the C++ compiler supports -Wno-error=tautological-type-limit-compare... yes
0:13.58 checking whether the C compiler supports -Wunreachable-code-return... yes
0:13.67 checking whether the C++ compiler supports -Wunreachable-code-return... yes
0:13.75 checking whether the C compiler supports -Wunused-but-set-parameter... yes
0:13.83 checking whether the C++ compiler supports -Wunused-but-set-parameter... yes
0:13.92 checking whether the C compiler supports -Wclass-varargs... yes
0:14.00 checking whether the C++ compiler supports -Wclass-varargs... yes
0:14.08 checking whether the C++ compiler supports -Wempty-init-stmt... yes
0:14.17 checking whether the C compiler supports -Wfloat-overflow-conversion... yes
0:14.25 checking whether the C++ compiler supports -Wfloat-overflow-conversion... yes
0:14.31 checking whether the C compiler supports -Wfloat-zero-conversion... yes
0:14.40 checking whether the C++ compiler supports -Wfloat-zero-conversion... yes
0:14.48 checking whether the C compiler supports -Wloop-analysis... yes
0:14.55 checking whether the C++ compiler supports -Wloop-analysis... yes
0:14.63 checking whether the C compiler supports -Wno-range-loop-analysis... yes
0:14.70 checking whether the C++ compiler supports -Wno-range-loop-analysis... yes
0:14.77 checking whether the C++ compiler supports -Wc++2a-compat... yes
0:14.83 checking whether the C++ compiler supports -Wcomma-subscript... no
0:14.90 checking whether the C compiler supports -Wenum-compare-conditional... yes
0:14.98 checking whether the C++ compiler supports -Wenum-compare-conditional... yes
0:15.05 checking whether the C compiler supports -Wenum-float-conversion... yes
0:15.12 checking whether the C++ compiler supports -Wenum-float-conversion... yes
0:15.18 checking whether the C++ compiler supports -Wvolatile... no
0:15.26 checking whether the C++ compiler supports -Wno-error=deprecated... yes
0:15.33 checking whether the C++ compiler supports -Wno-error=deprecated-anon-enum-enum-conversion... yes
0:15.40 checking whether the C++ compiler supports -Wno-error=deprecated-enum-enum-conversion... yes
0:15.47 checking whether the C++ compiler supports -Wno-error=deprecated-pragma... yes
0:15.54 checking whether the C++ compiler supports -Wno-error=deprecated-this-capture... yes
0:15.62 checking whether the C++ compiler supports -Wcomma... yes
0:15.68 checking whether the C compiler supports -Wduplicated-cond... no
0:15.74 checking whether the C++ compiler supports -Wduplicated-cond... no
0:15.81 checking whether the C++ compiler supports -Wimplicit-fallthrough... yes
0:15.87 checking whether the C compiler supports -Wlogical-op... no
0:15.93 checking whether the C++ compiler supports -Wlogical-op... no
0:16.04 checking whether the C compiler supports -Wstring-conversion... yes
0:16.11 checking whether the C++ compiler supports -Wstring-conversion... yes
0:16.18 checking whether the C++ compiler supports -Wno-inline-new-delete... yes
0:16.24 checking whether the C compiler supports -Wno-error=maybe-uninitialized... no
0:16.31 checking whether the C++ compiler supports -Wno-error=maybe-uninitialized... no
0:16.38 checking whether the C compiler supports -Wno-error=deprecated-declarations... yes
0:16.45 checking whether the C++ compiler supports -Wno-error=deprecated-declarations... yes
0:16.52 checking whether the C compiler supports -Wno-error=array-bounds... yes
0:16.59 checking whether the C++ compiler supports -Wno-error=array-bounds... yes
0:16.66 checking whether the C compiler supports -Wno-error=free-nonheap-object... yes
0:16.74 checking whether the C++ compiler supports -Wno-error=free-nonheap-object... yes
0:16.81 checking whether the C compiler supports -Wno-multistatement-macros... no
0:16.87 checking whether the C++ compiler supports -Wno-multistatement-macros... no
0:16.93 checking whether the C compiler supports -Wno-error=class-memaccess... no
0:17.00 checking whether the C++ compiler supports -Wno-error=class-memaccess... no
0:17.07 checking whether the C compiler supports -Wno-error=atomic-alignment... yes
0:17.14 checking whether the C++ compiler supports -Wno-error=atomic-alignment... yes
0:17.21 checking whether the C compiler supports -Wno-error=deprecated-builtins... yes
0:17.29 checking whether the C++ compiler supports -Wno-error=deprecated-builtins... yes
0:17.36 checking whether the C compiler supports -Wformat... yes
0:17.43 checking whether the C++ compiler supports -Wformat... yes
0:17.50 checking whether the C compiler supports -Wformat-security... yes
0:17.57 checking whether the C++ compiler supports -Wformat-security... yes
0:17.64 checking whether the C compiler supports -Wformat-overflow=2... no
0:17.70 checking whether the C++ compiler supports -Wformat-overflow=2... no
0:17.84 checking whether the C compiler supports -Werror=implicit-function-declaration... yes
0:17.92 checking whether the C compiler supports -Wno-psabi... yes
0:17.99 checking whether the C++ compiler supports -Wno-psabi... yes
0:18.06 checking whether the C compiler supports -Wthread-safety... yes
0:18.14 checking whether the C++ compiler supports -Wthread-safety... yes
0:18.21 checking whether the C compiler supports -Wno-error=builtin-macro-redefined... yes
0:18.27 checking whether the C++ compiler supports -Wno-error=builtin-macro-redefined... yes
0:18.34 checking whether the C compiler supports -Wno-unknown-warning-option... yes
0:18.41 checking whether the C++ compiler supports -Wno-unknown-warning-option... yes
0:18.48 checking whether the C++ compiler supports -fno-sized-deallocation... yes
0:18.54 checking whether the C++ compiler supports -fno-aligned-new... yes
0:18.55 checking for llvm_profdata... /usr/bin/llvm-profdata
0:18.59 checking for alsa... yes
0:18.59 checking MOZ_ALSA_CFLAGS...
0:18.59 checking MOZ_ALSA_LIBS... -lasound
0:18.60 checking for jack... yes
0:18.60 checking MOZ_JACK_CFLAGS... -D_REENTRANT
0:18.60 checking MOZ_JACK_LIBS... -ljack
0:18.61 checking for libpulse... yes
0:18.61 checking MOZ_PULSEAUDIO_CFLAGS... -D_REENTRANT
0:18.61 checking MOZ_PULSEAUDIO_LIBS... -lpulse -pthread
0:18.62 checking for nspr >= 4.32... yes
0:18.62 checking NSPR_CFLAGS... -I/usr/include/nspr
0:18.63 checking NSPR_LIBS... -lplds4 -lplc4 -lnspr4
0:18.63 checking for rustc... /usr/bin/rustc
0:18.63 checking for cargo... /usr/bin/cargo
0:18.82 checking rustc version... 1.73.0
0:18.90 checking cargo version... 1.73.0
0:19.20 checking for rust host triplet... aarch64-unknown-linux-gnu
0:19.33 checking for rust target triplet... aarch64-unknown-linux-gnu
0:19.33 checking for rustdoc... /usr/bin/rustdoc
0:19.35 checking for cbindgen... /usr/bin/cbindgen
0:19.35 checking for rustfmt... /usr/bin/rustfmt
0:19.35 checking for clang for bindgen... /usr/bin/clang++
0:19.41 checking for libclang for bindgen... /usr/lib/libclang.so
0:19.55 checking that libclang is new enough... yes
0:19.55 checking bindgen cflags... -x c++ -fno-sized-deallocation -fno-aligned-new -DTRACING=1 -DIMPL_LIBXUL -DMOZILLA_INTERNAL_API -DRUST_BINDGEN -DOS_POSIX=1 -DOS_LINUX=1
0:19.63 checking for tm_zone and tm_gmtoff in struct tm... yes
0:19.80 checking for getpagesize... yes
0:19.96 checking for gmtime_r... yes
0:20.13 checking for localtime_r... yes
0:20.32 checking for gettid... yes
0:20.52 checking for setpriority... yes
0:20.69 checking for syscall... yes
0:20.85 checking for getc_unlocked... yes
0:21.06 checking for pthread_getname_np... yes
0:21.23 checking for pthread_get_name_np... no
0:21.39 checking for strerror... yes
0:21.57 checking for __cxa_demangle... yes
0:21.64 checking for unwind.h... yes
0:21.81 checking for _Unwind_Backtrace... yes
0:21.98 checking for _getc_nolock... no
0:22.19 checking for localeconv... yes
0:22.44 checking for nodejs... /usr/bin/node (20.8.1)
0:22.45 checking for gtk+-wayland-3.0 >= 3.14 xkbcommon >= 0.4.1... yes
0:22.55 checking MOZ_WAYLAND_CFLAGS... -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-6 -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/gio-unix-2.0 -I/usr/include/cloudproviders -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -pthread
0:22.56 checking MOZ_WAYLAND_LIBS... -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0 -lxkbcommon
0:22.56 checking for pango >= 1.22.0... yes
0:22.58 checking MOZ_PANGO_CFLAGS... -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-6 -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -pthread -I/usr/include/pixman-1
0:22.58 checking MOZ_PANGO_LIBS... -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lharfbuzz
0:22.59 checking for fontconfig >= 2.7.0... yes
0:22.59 checking _FONTCONFIG_CFLAGS... -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-6 -pthread
0:22.60 checking _FONTCONFIG_LIBS... -lfontconfig -lfreetype
0:22.60 checking for freetype2 >= 9.10.3... yes
0:22.61 checking _FT2_CFLAGS... -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-6 -pthread
0:22.61 checking _FT2_LIBS... -lfreetype
0:22.62 checking for tar... /usr/bin/tar
0:22.62 checking for unzip... /usr/bin/unzip
0:22.62 checking for the Mozilla API key... yes
0:22.62 checking for the Google Location Service API key... yes
0:22.62 checking for the Google Safebrowsing API key... yes
0:22.62 checking for the Bing API key... no
0:22.62 checking for the Adjust SDK key... no
0:22.62 checking for the Leanplum SDK key... no
0:22.62 checking for the Pocket API key... no
0:22.63 checking for x11 xcb xcb-shm x11-xcb xext xrandr >= 1.4.0 xcomposite xcursor xdamage xfixes xi xtst... yes
0:22.65 checking MOZ_X11_CFLAGS...
0:22.65 checking MOZ_X11_LIBS... -lxcb-shm -lX11-xcb -lX11 -lxcb -lXext -lXrandr -lXcomposite -lXcursor -lXdamage -lXfixes -lXi -lXtst
0:22.66 checking for ice sm... yes
0:22.66 checking MOZ_X11_SM_CFLAGS... -I/usr/include/uuid
0:23.16 checking for vld1_s16_x3 in arm_neon.h... yes
0:23.65 checking for vld1_u16_x2 in arm_neon.h... yes
0:24.15 checking for vld1q_u8_x4 in arm_neon.h... yes
0:24.15 Using wasi sysroot in /usr/share/wasi-sysroot
0:24.15 checking for the wasm C compiler... /usr/bin/clang
0:24.22 checking whether the wasm C compiler can be used... yes
0:24.22 checking the wasm C compiler version... 16.0.6
0:24.28 checking the wasm C compiler works... yes
0:24.35 checking the wasm C compiler can find wasi headers... yes
0:24.50 checking the wasm C linker can find wasi libraries...
0:24.50 DEBUG: Creating `/tmp/conftest.r797y0_7.c` with content:
0:24.50 DEBUG: | int
0:24.50 DEBUG: | main(void)
0:24.50 DEBUG: | {
0:24.50 DEBUG: |
0:24.50 DEBUG: | ;
0:24.50 DEBUG: | return 0;
0:24.50 DEBUG: | }
0:24.50 DEBUG: Executing: `/usr/bin/clang -std=gnu99 --target=wasm32-wasi /tmp/conftest.r797y0_7.c --sysroot=/usr/share/wasi-sysroot`
0:24.50 DEBUG: The command returned non-zero exit status 1.
0:24.50 DEBUG: Its error output was:
0:24.50 DEBUG: | wasm-ld: error: cannot open /usr/lib/clang/16/lib/wasi/libclang_rt.builtins-wasm32.a: No such file or directory
0:24.50 DEBUG: | clang-16: error: linker command failed with exit code 1 (use -v to see invocation)
0:24.50 ERROR: Cannot find wasi libraries or problem with the wasm linker. Please fix the problem. Or build with --without-wasm-sandboxed-libraries.
Config object not found by mach.
*** Fix above errors and then restart with "./mach build"
==> ERROR: A failure occurred in build().
Aborting...
Wollie
27 October 2023 20:52
11
Maybe there is a bug involved.
Maybe this fix could help:
@Wollie Are you sure? He’s trying to install it on an ARM64 device.
Arch does not support Firefox ESR no matter the architecture.
Enough technical knowledge and free time to fix the build errors…
Mozilla do distribute Firefox ESR for arm64 on Windows (and presumably macOS?) so I guess that is probably possible. The hard part is going to be finding someone with enough interest to do that work for free.
I have no interest but I am bored right now. I do not even want it on my computer. It is in the compiling stage right now. Lets see if it craps out before building the package.
5:15.55 Compiling proc-macro2 v1.0.66
5:19.20 accessible/basetypes
5:22.06 Compiling unicode-ident v1.0.6
5:22.65 Compiling quote v1.0.23
6:04.24 Compiling syn v1.0.107
6:10.84 accessible/generic
TIER: configure pre-export export compile misc libs tools
Here’s Firefox 115.4.0esr (x64) if the OP has a x64 system available.
Will you please read the thread before posting things like this.
I read the thread; and offered a possible alternative; albeit dependent on having an x86_64 system available.
What is it with you? Sometimes you offer very helpful information. And many other times it seems like you’re just posting to… post. Is it not obvious that the whole point of this thread is firefox-esr on arm64? If he had a x86 system then the aur build would have worked in the first place.
I refer you to my previous post. Have a great day.
Xephon
28 October 2023 09:35
20
Don’t you see what’s going on? C’mon.
That account is a chatGPT-powered account. It extracts keywords and runs them through search engines but it can’t really understand their meaning. That’s why it helpful on some occasions but most of the time it posts utter nonsense.
Someone is traning AI using this forum. I think that account should be banned immediately.
