only for my steam games so every thing runs smooth
So …
You have an AMDGPU card … you play games … and you just ‘want the best experience’ and you think those things will give it to you?
I rather doubt thats the case.
I suggest you take a read of this recent post … amdgpu-pro is unsupported and generally performs worse … but if there are components of it you want to add to amdgpu … you can install those packages from the AUR.
Ok thanks i will do that
but in the mean time can u please just tell me how to install the man redean software
or u are saying i dont need it ?
im new
AMD is opensource.
You should already be running the correct drivers.
If you want to check … take a look in mhwd
or Manjaro Settings Manager.
Wiki: Configure Graphics Cards - Manjaro Linux
You can also share your info as shown here: How to provide good information
Kernel: 5.9.0-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=1dd6274d-6eeb-4816-9988-d223653e01a2 rw quiet
cryptdevice=UUID=e81c2e76-d8e7-4342-9254-71585b6b14a3:luks-e81c2e76-d8e7-4342-9254-71585b6b14a3
root=/dev/mapper/luks-e81c2e76-d8e7-4342-9254-71585b6b14a3
resume=/dev/mapper/luks-d34438a8-7ea9-443d-a1ae-99af57fdfe20
udev.log_priority=3
Desktop: bspwm 0.9.7-2-g342c2e3 info: lemonbar dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: MPG Z490 GAMING EDGE WIFI (MS-7C79)
v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.10 date: 05/21/2020
Topology: 8-Core model: Intel Core i7-10700K bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A5 (165) stepping: 5 microcode: CA L2 cache: 16.0 MiB
bogomips: 121639
Speed: 1800 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 1800 2: 1800
3: 1800 4: 1800 5: 1800 6: 1800 7: 1800 8: 1801 9: 1800 10: 1800 11: 1800
12: 1800 13: 1800 14: 1800 15: 1800 16: 1800
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
Display: x11 server: X.org 1.20.8 compositor: picom v: git-e553e
driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: <xdpyinfo missing>
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:06c8
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aaf0
Device-3: Corsair CORSAIR VOID ELITE Wireless Gaming Dongle type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-7:4 chip ID: 1b1c:0a55
Sound Server: ALSA v: k5.9.0-1-MANJARO
Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:06f0
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: 3000 bus ID: 04:00.0 chip ID: 10ec:8125
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 2.96 TiB used: 68.80 GiB (2.3%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS250G2B0C-00PXH0
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 211070WD scheme: MBR
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 250GB
lanes: 4 serial: <filter> rev: 2B2QEXM7 scheme: GPT
ID-3: /dev/sda vendor: Toshiba model: HDWD130 size: 2.73 TiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: ACF0 scheme: GPT
ID-1: / raw size: 223.79 GiB size: 219.27 GiB (97.98%)
used: 68.80 GiB (31.4%) fs: ext4 dev: /dev/dm-0
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 38 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1267
Processes: 426 Uptime: 7h 57m Memory: 31.28 GiB used: 3.62 GiB (11.6%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: 1306 pacman: 1302
lib: 391 flatpak: 4 Shell: Zsh v: 5.8 running in: server inxi: 3.1.05
Take @cscs advice, you really don’t need those things for gaming.
Those files are archives, if you extract them you’ll probably find readme files.
What are you trying to do with gparted?
