I am a newbie to Manjaro and still learning from its awesome wiki.
I use a Manjaro Gnome 21 dual booted with windows 10 and it is working fantastically .
I just have one issue though.
I want to have a working system with switchable graphics. I have tried using optimus manager but without success. Also, someone guided me to use System76 power. How to install it? and does it work properly.
I need help in rectifying this.
Anyway, thanks to the Manjaro Team for this awesome distro.
linub
10 October 2021 18:13
2
you can read here
i would have helped more,but i use KDE and i see there are special instructions for Gnome that i didn’t have to go through.
at the end of the page there’s a section about optimus manager-qt which gives a panel icon to easily switch between Gpus (after you’ve installed optimus manager.)
I installed using the guide but I keep getting a message that I am not using gdm-prime while I am using it. How to fix it?
I want to have a working system with switchable graphics. I have tried using optimus manager and I installed it using the guide but I keep getting a message that I am not using gdm-prime while I am using it. How to fix it?
Hello,
Please do not cross-posts
If you build/installed gdm-prime from AUR please make sure you also had the system updated and rebooted. Share your system information as described here How to provide good information and the exact errors you get.
I apologize for my mistake for cross-posting. I have installed gdm-prime from AUR and rebooted my system, then I also installed the optimus manager extension for Gnome and tested switching the graphics. It is working perfectly fine
I just have one issue, that I get a notification from time to time that I am not using gdm-prime. It does not affect my work at all but I just wanted to know about the reason and remove the issue.
Thank you for your response and your link on how to give proper information about the system.
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=59f12a96-0e53-4e09-bf3c-5731722a07b4 rw rootflags=subvol=@ quiet
resume=UUID=9369602f-d62c-4910-9154-104c9d7abbc4 udev.log_priority=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 81SY v: Lenovo Legion Y540-15IRH-PG0
serial: <filter> Chassis: type: 10 v: Lenovo Legion Y540-15IRH-PG0
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <filter>
UEFI: LENOVO v: BHCN42WW date: 05/21/2021
ID-1: BAT0 charge: 43.3 Wh (86.9%) condition: 49.8/52.5 Wh (94.8%)
volts: 12.0 min: 11.3 model: LGC L17L3PG1 type: Li-poly serial: <filter>
status: Discharging cycles: 578
RAM: total: 15.51 GiB used: 4.64 GiB (29.9%)
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 8 MiB bogomips: 38408
Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 04ca:7070 class-ID: 0e02
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 11.88 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HBHQ-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3L1QEXH7 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
type: HDD rpm: 5400 serial: <filter> rev: 1A05 scheme: MBR
ID-1: / raw-size: 310 GiB size: 310 GiB (100.00%) used: 11.85 GiB (3.8%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: Manjaro
uuid: 59f12a96-0e53-4e09-bf3c-5731722a07b4
ID-2: /boot/efi raw-size: 1.23 GiB size: 1.23 GiB (99.80%)
used: 25.9 MiB (2.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: EACF-CD81
ID-3: /home raw-size: 310 GiB size: 310 GiB (100.00%) used: 11.85 GiB (3.8%)
ID-4: /run/timeshift/backup raw-size: 310 GiB size: 310 GiB (100.00%)
used: 11.85 GiB (3.8%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: Manjaro
ID-5: /var/cache raw-size: 310 GiB size: 310 GiB (100.00%)
ID-6: /var/log raw-size: 310 GiB size: 310 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 9369602f-d62c-4910-9154-104c9d7abbc4
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 232.25 GiB fs: ntfs
label: Windows-SSD uuid: 7AACD06BACD02383
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: EC5CD0C35CD08A2A
ID-4: /dev/sda1 maj-min: 8:1 size: 311.51 GiB fs: ntfs label: New Volume
uuid: 92F24EC7F24EAEF3
ID-5: /dev/sda2 maj-min: 8:2 size: 310 GiB fs: ntfs label: New Volume
uuid: AE2AC7422AC705F5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:2 info: Lenovo Wireless KB_Mouse KN100 WW type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 98mA
chip-ID: 17ef:609f class-ID: 0301
Device-2: 1-6:3 info: Lite-On Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04ca:7070
class-ID: 0e02
Device-3: 1-9:4 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c100 class-ID: 0301
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 299 Uptime: 1d 22h 6m wakeups: 37 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1107 pacman: 1093 lib: 310
flatpak: 14 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.07
