Hi !
I make a weekly backup of my computer on an external HDD.
When I was using Backintime, the cron generated a popup to remind me to plug my HDD.
With Timeshift, no such alert.
How could I achieve having one ?
Hi !
just cron
this:
0 0 1 * * /usr/bin/backup-alert.sh
where /usr/bin/backup-alert.sh
contains:
#!/bin/sh
export DISPLAY=:0.0
export XAUTHORITY=/home/nam1962/.Xauthority
notify-send --urgency=LOW --icon=face-devilish "Insert the backup disk!!!" &&
Nice one !
I’ll keep it.
It won’t launch Timeshift once HDD plugged, though (as backintime does)
Conky is a brilliant software.
Mainly it just gives me a great alternative clock, but also it shoves an info window in my face for a few seconds when it launches…
I launch with this script:
#!/bin/bash
if pgrep -x "conky"
then killall conky
else
conky -d -c ~/Dropbox/Admin/conky/c0-time.conky
conky -d -c ~/Dropbox/Admin/conky/c1-date.conky
conky -d -c ~/Dropbox/Admin/conky/c2-network.conky
conky -d -c ~/Dropbox/Admin/conky/c3-proc.conky
conky -d -c ~/Dropbox/Admin/conky/c4-info.conky
fi
Info conky runs for only ten seconds, read it and it is gone.
proc conky is also temporary (runs for 2 minutes I think)
conky.config = {
-- Conky settings
background = true,
update_interval = 1,
double_buffer = true,
no_buffers = true,
-- Window specifications
gap_x = 20,
gap_y = 30,
alignment = 'top_right',
own_window = true,
own_window_type = 'dock',
own_window_transparent = true,
own_window_argb_visual = true,
own_window_argb_value = 70,
own_window_hints = 'above, undecorated,sticky,skip_taskbar,skip_pager',
own_window_class = 'conky',
draw_outline = true,
default_outline_color = '#333',
use_xft = true,
xftalpha = 0.5,
font = 'Droid Sans:size=10',
text_buffer_size = 256,
override_utf8_locale = true,
useful = 'shortenings',
short_units = true,
pad_percents = 2,
top_name_width = 30,
color = 'scheme',
default_color = '#ebdbb2',
color1 = '#FFFFFF',
color2 = '#2dcba5',-- teal
color3 = '#fe6767',-- Sweet
color4 = '#c8b481',--Gruv
color5 = '#89cf8c',
color6 = '#fec838',
color7 = '#444',
color8 = '#A9CFF4',--Nord
color9 = '#bf0610',
color9 = '#87880d',
color9 = '#cd8913', -- #347476 #a14a74 #689d6a #ebdbb2
conky.text = [[
${alignc}${color4}${font arial rounded mt bold:size=32}${time %H:%M}${font arial rounded mt:size=12}
conky.config = {
background = true,
no_buffers = true,
update_interval = 2,
imlib_cache_size = 10,
border_width = 3,
out_to_x = true,
-- Window specifications #
alignment = 'top_left',
gap_x = 40,
gap_y = 30,
minimum_width = 200, minimum_height = 0,
maximum_width = 800,
own_window = true,
own_window_transparent = false,
own_window_argb_visual = false,
own_window_argb_value = 200,
own_window_hints = 'below,undecorated,sticky,skip_taskbar,skip_pager',
uppercase = false,
use_spacer = 'none',
use_xft = true,
-- Graphics settings #
draw_borders = true,
draw_graph_borders = true,
-- Text settings #
use_xft = true,
xftalpha = 0,
font = 'comfortaa :size=10',
-- Useful shortenings #
short_units = true,
pad_percents = 2,
-- Color scheme #
own_window_colour = '#1d2021',
default_color = '#888',
color1 = '#35aa35', -- green
color2 = '#e0d9bf', --creamy paper
color3 = '#A9CFF4', --Nord blue
color4 = '#2b303a', --Nord background
color5 = '#ffaa7f', --Gruv bright
color6 = '#888888',
total_run_times =400,
conky.text = [[
$color1${font :size=12}$nodename - $kernel $color $alignr Uptime:$color1 $uptime
$color3
${goto 50}lsb-release:
${font :size=9}${execi 5000 cat /etc/lsb-release}
$color5${execi 5000 plasmashell --version && qmake-qt5 --version} $color
Load:$color2 $loadavg $color $alignr Frequency (in GHz):$color2 $freq_g $color
Processes:$color2 $processes $color Running:$color2 $running_processes $color $alignr Swap Use:$color2 $swap/$swapmax $color
${font :size=8}$color6
${execi 5000 df -h --total /mnt/*}
$color
${alignc }Latest Timeshift Snapshot:$color2 ${execi 250 ls -r -l /mnt/T3/timeshift/snapshots | sed -n '2p'| cut -c 29-40}
You’ll need to edit the path to the snapshot folder to get the info to show up.
Tweak the line total_run_times =400,
to set how long you have before it disappears.
Then bind the conky launch script to a shortcut/mouse gesture - it’s a toggle (launch or kill).
Ah, you need a udev
rule for that, so check logs and see which rule is fired when that HDD is inserted and then:
sleep 3
/bin/timeshift
at the end (or whatever the command for timeshift is, as I’m on borg
I can use Vorta.
What backup tool do you recommend ?
(my constraint : I install a lot of friends previously using W$ : the solution has to be automatic or as simple as possible (i.e : a popup as reminder)
Don’t know that.
Any that works, but I’m on this system:
