How to fix "Failed to start Load Kernel Modules" error and complete full system upgrade?
Hello dear all,
The question is coming from a complete newbie corner, so please forgive me if I ask dumb questions :roll_eyes:
  • I’ve tried to do a full system upgrade on a laptop which I was not using for quite a while, using sudo pacman -Syu.
  • Upgrade failed (please refer to a screenshot).
  • I’ve made slight attempt to delete this python thingy package (so that I could get rid of this issue), but after seeing that pacman itself depends on it, I hesitated to do so
  • Also, I forgot to plugin my charger so laptop did shutdown quite abruptly. After turning it back on I’ve bumped into an issue - it cannot fully start, it fails with [FAILED] Failed to start Load Kernel Modules
  • Thankfully, I was able to login using terminal (by pressing ctrl+alt+f2) and get some system information (please refer below)
  • After some googling and inspecting journalctl -b 0 output, I’ve bumped into some complaints regarding nvidia. So I decided to delete packages (see screenshot on this as well), but it seemed to make things only worse as now I don’t even see “Failed to start Load Kernel Modules” error in console, only MSI logo remains on the screen.
  • But I still was able to get to a console by doing ctrl+alt+f2 and get another output of journalctl -b 0, please see below as well
At this point I decided to stop any further attempts while I’m able to get to a console :angel:
I’m hoping you could help me achieve 2 things, would really appreciate it:
  1. Fix system start - so it actually starts so I can get to GUI
  2. Solve this package dependency issues and finish full system upgrade
Please help and also please let me know if there is some additional information I can provide
p.s. While googling I’ve bumped into journalctl -b 0 command, hopefully it will help to diagnose an issue (yes, there is some personal information disclosed, hopefully no harm could come out of it). I’ve found those Load Kernel Modules errors there, but couldn’t understand how to fix them…
Attachment: First system upgrade failure:
Attachment: inxi --admin --verbosity=7 --filter --no-host --width output:
  Kernel: 5.4.72-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=f03a99b3-8753-47be-a685-ef1b6a432e9b rw quiet
  resume=UUID=7dc4c251-fe04-4b4d-9cc1-b11c968ffb08
  Console: tty 2 Distro: Manjaro Linux
  Type: Laptop System: Micro-Star product: GT72S 6QF v: REV:1.0
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Micro-Star model: MS-1783 v: REV:1.0 serial: <filter>
  UEFI: American Megatrends v: E1783IMS.11D date: 10/14/2016
  ID-1: BAT1 charge: 6.3 Wh condition: 8.6/86.6 Wh (10%) volts: 12.2/11.1
  model: MSI BIF0_9 type: Li-ion serial: N/A status: Charging
  RAM: total: 31.32 GiB used: 257.4 MiB (0.8%)
  Topology: Quad Core model: Intel Core i7-6820HK bits: 64 type: MT MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
  L2 cache: 8192 KiB bogomips: 43214
  Speed: 800 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 802 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: NVIDIA GM204M [GeForce GTX 980 Mobile] vendor: Micro-Star MSI
  driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0
  chip ID: 10de:161a
  Display: server: X.org 1.20.9 driver: nvidia tty: 240x67
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: Intel 100 Series/C230 Series Family HD Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  chip ID: 8086:a170
  Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb
  Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  bus ID: 1-1.3:6 chip ID: 046d:0825 serial: <filter>
  Sound Server: ALSA v: k5.4.72-1-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: d000
  bus ID: 03:00.0 chip ID: 168c:003e
  IF: wlp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
  vendor: Micro-Star MSI driver: alx v: kernel port: c000 bus ID: 05:00.0
  chip ID: 1969:e0a1
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
  bus ID: 1-10:5 chip ID: 0cf3:e300
  Local Storage: total: 1.03 TiB used: 489.06 GiB (46.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVPV128HDGM-00000
  size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: BXW7300Q scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Samsung model: MZVPV128HDGM-00000
  ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 4B6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BU20N rev: 1.00
  dev-links: cdrom
  ID-1: / raw size: 112.88 GiB size: 110.61 GiB (97.99%)
  used: 66.47 GiB (60.1%) fs: ext4 dev: /dev/nvme1n1p2 label: N/A
  uuid: f03a99b3-8753-47be-a685-ef1b6a432e9b
  ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%)
  used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 label: N/A uuid: A6BA-85CA
  ID-3: /mnt/drive_d raw size: 673.18 GiB size: 673.18 GiB (100.00%)
  used: 364.40 GiB (54.1%) fs: ntfs dev: /dev/sda5 label: DATA2
  uuid: 3C9263A95FF7EC53
  ID-4: /mnt/ssd2 raw size: 119.24 GiB size: 119.24 GiB (100.00%)
  used: 58.19 GiB (48.8%) fs: ntfs dev: /dev/nvme0n1p1 label: SSD2
  uuid: 7DB9C20A1176736A
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme1n1p3 label: N/A uuid: 7dc4c251-fe04-4b4d-9cc1-b11c968ffb08
  ID-1: /dev/sda1 size: 128.0 MiB fs: <superuser/root required> label: N/A
  uuid: N/A
  ID-2: /dev/sda2 size: 300.0 MiB fs: vfat label: SYSTEM uuid: 76E9-4C21
  ID-3: /dev/sda3 size: 237.18 GiB fs: ntfs label: OS_Install
  uuid: 4ED85E1BCBD7F987
  ID-4: /dev/sda4 size: 900.0 MiB fs: ntfs label: WinRE tools
  uuid: 39A9C41A8F60D8B6
  ID-5: /dev/sda6 size: 19.85 GiB fs: ntfs label: BIOS_RVY
  uuid: 7FA52BEB1EBA3F15
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Hub: 1-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip ID: 0bda:5411
  Device-1: 1-1.2:4 info: Logitech M-U0007 [Corded Mouse M500] type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  chip ID: 046d:c069
  Device-2: 1-1.3:6 info: Logitech Webcam C270 type: Video,Audio
  Device-3: 1-1.4:7 info: SiGma Micro Keyboard type: Keyboard,HID
  chip ID: 1c4f:0026
  Device-4: 1-7:3 info: MSI steel series rgb keyboard type: HID driver: usbhid
  interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 1770:ff00 serial: <filter>
  Device-5: 1-10:5 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  chip ID: 0cf3:e300
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003
  Hub: 2-2:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip ID: 0bda:0411
  System Temperatures: cpu: 69.0 C mobo: N/A
  Processes: 179 Uptime: 1m Init: systemd v: 246 Compilers: gcc: 10.2.0
  clang: 10.0.1 Packages: pacman: 1410 lib: 400 flatpak: 0 Shell: Bash
  v: 5.0.18 running in: tty 2 inxi: 3.1.05
Attachment: Part of the journalctl -b 0 after first failed boot which I think is relevant
Oct 17 19:42:31 sergey-pc kernel: nvidia: disagrees about version of symbol module_layout
Oct 17 19:42:31 sergey-pc kernel: usb 1-1.3: New USB device found, idVendor=046d, idProduct=0825, bcdDevice= 0.10
Oct 17 19:42:31 sergey-pc kernel: usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Oct 17 19:42:31 sergey-pc kernel: usb 1-1.3: SerialNumber: 1B125350
Oct 17 19:42:31 sergey-pc systemd-modules-load[281]: Failed to insert module 'nvidia': Exec format error
Oct 17 19:42:31 sergey-pc systemd[1]: Finished Flush Journal to Persistent Storage.
Oct 17 19:42:31 sergey-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 17 19:42:31 sergey-pc kernel: audit: type=1130 audit(1634488951.468:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 17 19:42:31 sergey-pc systemd[1]: Started Rule-based Manager for Device Events and Files.
Oct 17 19:42:31 sergey-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 17 19:42:31 sergey-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 17 19:42:31 sergey-pc systemd[1]: Started LVM2 metadata daemon.
Oct 17 19:42:31 sergey-pc kernel: audit: type=1130 audit(1634488951.484:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 17 19:42:31 sergey-pc kernel: audit: type=1130 audit(1634488951.484:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 17 19:42:31 sergey-pc systemd-modules-load[281]: Failed to insert module 'nvidia_drm': Exec format error
Oct 17 19:42:31 sergey-pc systemd-modules-load[281]: Inserted module 'uinput'
Oct 17 19:42:31 sergey-pc kernel: fbcon: Taking over console
Oct 17 19:42:31 sergey-pc kernel: audit: type=1130 audit(1634488951.544:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 17 19:42:31 sergey-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 17 19:42:31 sergey-pc systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Oct 17 19:42:31 sergey-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Oct 17 19:42:31 sergey-pc systemd[1]: Failed to start Load Kernel Modules.
Deletion of nvidia packages:
Attachment: Part of the journalctl -b 0 after deletion of nvidia packages which I think is relevant
Oct 17 20:25:25 sergey-pc systemd-modules-load[275]: Failed to find module 'nvidia'
Oct 17 20:25:25 sergey-pc systemd-modules-load[275]: Failed to find module 'nvidia-drm'
if you can boot on USB manjaro live or if you can get TTY on your system
for chroot open a terminal and a browser on this topic
sudo manjaro-chroot -a
pacman -Syy ( check network is ok )
pacman -Rs lib32-libcanberra libcanberra
pacman -Sy pacman ( upgrade first pacman )
pacman -Syyu
if all mkinicpio ok ( no error )
exit (end chroot )
if you have a fail in mkinitcpio DO NOT REBOOT
return all errors message here
According to the system upgrade log, have a look here:
Looks like your video drivers are broken, and you are affecting them outside of mhwd.
Please list, remove, reinstall drivers as needed.
Information can be found on the forums and the wiki such as here:
https://wiki.manjaro.org/index.php?title=Manjaro_Hardware_Detection_Overview
@cscs @megavolt your replies helped to solve the issue :man_dancing:. I used these steps to recover my system:
  1. I did pamac update which first complained about yaourt but I removed it as suggested by pamac, and in the end it worked and my system was updated to the latest state (no more complaints on python thingy)
  2. Then I’ve installed mhwd and other nvidia packages that I’ve removed (refer to a screenshot in the post)
After that system starts as expected and I’m writing this from it. Thank you guys!!
p.s. @stephane I was too scared to run suggested commands :slight_smile: But anyways thank you for willingness to help
