Hello,
Im not a fan from applications permanently running in background that im not really need and since im daily close them. Every time i load my Desktop i asked myself why are this Applications are not listed in Background Service and why are they hidden to get rid of them and prevent them to run all the time in background?
Is there a easy way to disable this two apps from autostarting?
It’s less about being hidden and more about only providing a tray icon, which is only shown when relevant, e.g. when they notify the user. You can also configure them to always show in the tray.
Beware: it’s not because clicking on them opens a GUI application that the latter is actually in the background. Those two tray icons are actually not part of the GUI application opening, they “merely” launch it. You can check that in your favorite process manager.
Also, speaking of applications “in the background”, you’ll be surprised how many Services are currently running on your system without showing anything on screen:
Although if you don’t intent to use them, you can outright remove them as @stasadev first suggested.
But i think you’ll still want to keep them running…
