How to Configure UEFI so that computer with Elite V7 Home Core i7-12700 CPU can boot from my Manjaro Linux ISO USB?
(My apologies if this this the wrong category for this question.)
I have desktop tower computer built with an Elite Core V3 Home Core i7-127000 CPU. Windows 11 has been installed on that PC and I want to install Manjaro Linux in its place.
However, I was unable to find, in the UEFI screens, how to boot that computer from my Manjaro Linux ISO USB drive. After several unsuccessful attempts, the computer now boots straight to Windows 11 without even allowng me to use the UEFI interface.
Can anyone advise me. firstly, how to find the UEFI screens again and, when I do, how to set them so I can boot up from my bootable Manjaro Linux USB drive?
Right now I am using a friend’s Windows 11 computer, so I may not be able to respond quickly to any responses here.
Thank you for your your attention.
daggett
Look in your systems manual.
I did not get a systems manual when I recently purchased this computer.
Perhaps the vendor has a web site?
If not you need to ask the vendor how?
There is no universal answer to your question.
Firstly, the BIOS prompt is probably not appearing because of Windows fast boot. Boot into Windows and turn that off.
https://www.centrecom.com.au/centre-com-elite-v3-home-core-i7-12700-desktop-pc
Specs are there, motherboard is MSI PRO H610M-G WIFI DDR4 M-ATX. Documentation for that is at
https://www.msi.com/Motherboard/PRO-H610M-G-WIFI-DDR4/support
Assuming it’s the standard MSI BIOS then you just need to find Secure Boot and turn it off as per
https://wiki.manjaro.org/index.php/UEFI_-_Install_Guide
Then save + exit BIOS, press F11 at the BIOS prompt to enter boot menu, and choose your USB drive.
Thank you linux-aarhus, MrLavender.
After jumping through many hoops, I have managed to install Windows 11.
Luckily, I could get my code from Micro$oft through an e-mail I read from a tablet I had recently purchased. Without that tablet I would have been stuck.
I could not receive the code on my mobile phone as I lost it about 4 days ago and am awaiting a SIM card to activate my new replacement mobile phone. I have no other working computer in my house other that new computer on which I am about to replace Windows 11 with Manjaro Linux.
More soon.
daggett
If you want a Microsoft activation code then look on Groupon or similar sites you’ll get an OEM license/key immediately and a lot cheaper
Apologies, It seems I ticked a box which said my problem was solved. It has not been solved. If that can’t be corrected I might have to make a new post.
Right now, I am trying to work from a screen which is labeled “MSI Click BIOS” on the top left-hand corner. Could that be the UEFI (previously ‘BIOS’) screen?.
(I could try to re-create it with text if anyone thinks that could help me explain it better.)
I have put the bootable Manjaro ISO USB into both the blue-coloured USB slot (on the front left-hand side) and the black-coloured USB slot (on the right).
When I press F12 which seems to be the right button, I get the message:
Blockquote
No USB Device is found
Please plug USB dongle then try again
What’s a dongle?
Am I anywhere close to the right path?
Yes that is the UEFI BIOS.
https://www.msi.com/Landing/msi-click-bios-intel-amd-motherboard
First you need to disable Secure Boot. Read the “Function Introduction” page at the link above which shows you how to search for BIOS settings. Basically you click the search icon in top left of screen and type secure boot. Disable it and then F10 to save + exit which will reboot.
After reboot instead of pressing DEL to enter that BIOS screen press F11 for boot menu and choose the device you want to boot from.
Per default Win11 wants to control you PC boot with Secure Boot but Manjaro don’t support Secure Boot because we prefer freedom instead chains.
If you still want to stick to Win11, its possible that you may need to reinstall Win11, i personally prefer Win10 (even when i use Linux to 99,5% of my time) that don’t require TPM/Secure Boot, but with Rufus (media creation tool for your iso) you can install win11 without any shady Hardware Dongle.
Thank you Kobold, but I don’t know where you got the impression that I wanted to run Windows 11 or even Windows 10… I am trying to find out how to remove Windows 11 from my computer and Install Manjaro Linux in its place, most likely, from a bootable ISO on a USB stick…
(Right now there are quite a few other posts and links to resources that I haven’t yet followed properly, so I will do that now.)
:point_down:
Just now, on the UEFI screen, I tried to change the boot order so that it would fiirst boot off what looked to be 2 USB drives before the internal disk.
As a consequence, the computer now won’t boot at all. When I turn it on, the screen remains blank.
I am now left with no choice but to take the computer back to where I bought it from and ask the technician::
  1. Can he just make it boot up at all, whether to the UEFI screen or to Windows 11? and
  2. If he can find a way to make it boot up, could he make changes on the UEFI screen so that I can boot it up from my Manjaro Linux ISO USB stick in one of the 2 USB ports at the front?
Perhaps, in hindsight, I should have paid extra to have him remove Windows 11 from that computer.
Sorry, I didn’t actually install Windows 11. I just enabled the Windows 11 that was already installed after jumping through quite a few hoops.
I enabled Windows 11 so that I could turn of fast boot. It seems that I succeeded in turning of fast boot, but I still could not work out how to make the computer boot off my bootable Manjaro ISO USB stick.
… and as I said elsewhere, my latest efforts seem to have caused my computer not to be able to boot up at all, so I am left with no choice but to take it back to the store where I bought it from to ask for help.
vs…
W11 comes as default. Yes? No?
It functions normally. Yes? No?
vs.
The info you provided, are fragmented and contradictory.
Perhaps you should terminate this thread, and start a new post with more consistent + relevant info.
If my understanding is correct:
a. You are not seeking dual boot (W11 and Manjaro).
b. You want to install only Manjaro.
c. You want to remove W11.
Assuming you’re computer novice, I would recommend you to use the following installation guide:
  1. While in W11 environment, download Ventoy app, and use Ventoy to format your USB drive.
  2. Download your preferred Manjaro ISO version, and copy it to the USB drive.
  3. While leaving your USB drive attached to your PC, reboot, and enter BIOS of your PC.
  4. Turn off Secure Boot in your BIOS setting, and select your USB drive as 1st boot drive.
  5. Save the changes and restart.
  6. You should be able to boot from your USB drive now. Ventoy would prompt you to choose which OS (if you have multiple iso on Ventoy drive) to boot.
  7. Follow the on-screen instructions to install Manjaro.
As user Wind77 said already, your info’s are contradictory.
I wrote a Guide in Steam for people like you who wanted to switch from Windows to Linux… even if you not a gamer, it still helps you to find your way to get warm with Linux.
You will have a horrible Linux experience, when you just delete Windows instantly and going all in with Linux…
Replace your program’s one after another and give yourself time to breath.
My apologies for the confusion that I have caused to some by the way I have tried to explain my circumstances, but I still think the title I gave my post explains fairly well what I was trying to find out:
I had expected that I could just boot off my bootable Manjaro Linux ISO file on a USB stick by from my input into the UEFI screen, but I was advised here that I needed to first disable secure boot from within Windows 11. So to do that, I had to go to the trouble of enabling Windows - by entering my name, e-mail address, phone number, … whilst trying to avoid all sorts of traps set by Microsoft - when I had expected that I would not have to use Windows 11 at all. Apologies for having mistakenly used the word ‘install’ ather than ‘ensable’ on at least one occasion.
I have been using Linux in pereference to Microsoft since about 2000 I think.
I still think the way that Windows has been installed with fast boot on my computer could probably have also confused quite a few others who were not complete Linux novices.
Anyway as I said, my computer screen now won’t turn on so I see no choice but to take my computer back to the computer dealer. Hopefully he can fix it and remove Windows 11 for me.
The 1st person who advised you on Secure Boot, was MrLavender, who mentioned that:
Kobold iwas the 2nd person who mentioned about Secure Boot, and he provided you with the alternative to disable Secure Boot while continue to use W11.
There is essentially no one here, who has been telling you to “disable secure boot from within Windows 11
:point_down:
I will stop here - perhaps your own technician can better assist you.
I have no better way to contribute to help you, other than my guide :point_down:
You can’t enter your UEFI BIOS with “del” key?
If you don’t get any picture at all, you could also reset your Bios settings with a jumper on your Mainboard… but something is telling me, you probably not this deep into this technical understanding.
Removing Win11 should no big deal… you only need to Boot into the Manjaro Bootstick, that you can prepare with a Media Creation Tool like Ventus/Rufus/Etcher… but i linked you my guide already and my Linux Steam Guide also said disable secure boot and fast boot inside your BIOS.
When you don’t want to use Windows anymore, you don’t need any adjustments inside Windows, simple as that.
