How to Configure UEFI so that computer with Elite V7 Home Core i7-12700 CPU can boot from my Manjaro Linux ISO USB?
You were not. I advised you to disable Fast Boot from Windows because you said you couldn’t get into the UEFI BIOS. That is not the same thing as Secure Boot.
Go back into the UEFI BIOS screen the same way you did before. Press F6 to load default settings. Press F10 to save and exit. Your PC is now exactly as it was at the start.
Now read the link below. Manjaro is NOT suitable for absolute beginners and I’m sorry, but someone who has this much trouble booting a USB stick is an absolute beginner. I’d suggest looking at Ubuntu or Mint instead for an easier Linux experience.
wind77 wrote:
There is essentially no one here, who has been telling you to “disable secure boot from within Windows 11
So, as a Windows novice, it seems that I confused “secure boot” with “fast boot.”
Still, MrLavender write, near the start of this discussion wrote:
Firstly, the BIOS prompt is probably not appearing because of Windows fast boot. Boot into Windows and turn that off.
Because of that advice, I put myself to the trouble of enabling Windows 11 on my PC. I gave Microsoft a considerable amount of information about myself that I would have preferred not to have given them, agreed to Windows 11’s voluminous “Terms of Use” agreeement, etc.
As I said, I have been using Linux since prior to 2000. Prior to that I worked as programmer from 1989 until 1996. I have since got a tertiary IT degree, helped to establish one of the earlier rural dial-up ISPs and have worked as a contract Java programmer.
I am not working now as an IT professional because I was disabled 14 years ago when a car knocked my head as I was cycling to work.
I spite of that I have since been able to install Manjaro Linux, as well as Linux Mint, Ubuntu and others, on my own computer.
I had thought that, as currently number 6 on the distrowatch.com, as opposed to number 63 where Arch Linux is located, that Manjaro Linux was considered more suitable for less knowledgeable Linux users, even if it is not suitable for an “absolute beginner.”
From this experience it seems to me that the Windows 11 fast boot which came with my computer is a particularly diabolical feature and would cause grief to quite a few others who would want to run Linux on their PCs with Windows 11 pre-installed. The search terms Windows+11+Fast+Boot+and+Linux seem to have confirmed that to me.
That is why some of my posts may have contained mistakes and inconsitencies for which I have apologised.
Thank you, Kobold for your suggestion that I reset my BIOS settings with a jumper on the mainboard. I will try that later today.
My computer is fixed with Manjaro Linux fully installed.
A visiting friend fixed it for me.
He was able to make more sense of the motherboard documentation than I could.
He also made use of some of what was posted here, including Kobold’s suggestion.
When he explains to me again what he did I will post that explanation here, but I may not be able to for a while because I am going interstate for a few weeks.
Kobold’s suggestion that I reset the BIOS settings by short-circuiting a jumper (with 2 or 4 pins?) on the top right hand of the motherboard helped. The jumper[s] have a one (or two) labels:
JC11 JBAT1
So, thank you, all (and apologies again for any confusion I may have caused).
They would have had exactly the same problem with any USB install. The issues here was how to get the Computer to boot on the USB. To do that required getting to the BIOS Boot selector. To get there required getting Windows to exit FastBoot, and the easiest way in my experience is to simply hold down the power button to Force the computer to completely shutdown (Hard Shutdown). Then boot the computer and hold down the relevant Function key.
Im glad i could help :slight_smile:
Please mark the best answer as a solution, that this Topic can be closed.
True, but at least Ubuntu is signed so that removes the complication of turning off Secure Boot… and I was thinking more about what happens afterwards when it comes to system maintenance given what has happened so far…
